btw, I will run the Fader Modules with Mackie Hui.
Will it cause problems with HUI if I deactivate 4 of the Faders, because I only need 20 in my Setup?
Answered the above question by myself... it works.
small update:
Today The Fader-board arrived, everything works fine from the first startup!
Tested it with the old original Fader, works in general, but it took me the whole day to figure out a good setting.
12v was way to strong, even though the motor is rated that high. I ended up using 6v... (as you said, Thorsten)
Its not that fast anymore, but it turned out that noise is a big problem... the best setting so far is MinDuty 15, MaxDuty 100
PWM Steps are at 30. Btw, couldt figure out how to load a saved "preset"... All of the saved Sys.ex Files were grayed out!?
Am I missing something?
Now I need to build the first Prototyp fader were the slider sits much tighter on the rail and can be adjusted,
this will eleminate a bit more of the noise (wich comes 50/50 from the motor and from the Slider).
Any Ideas how to lower the Noise a little bit more...?
What can I change with "MF Deadband"? I experienced no differene when I changed it to other values...
Thorsten, are you interested in testing a Fader?
Maybe You find out something else to control these beasts...
Thanks!
