49 -
Everything posted by lajos
Thank you! Happy New Year !
Hello! All I'd be curious to midibox64 it might be resolved, resulting in a MIDI signal volume changes? If yes, how? Thank you. Louis.
Hey! I would like to point midibox64-if I could drum up the volume!
Hello Thorsten! Would be a problem to have an electric throw / Edrum 16ch / That I would like to set per channel volume but do not know how. In principle, it can be Midibox64-but how? Or something else you can give me a solution? A Yamaha PSR-300 synthesizer controls the drum. And one or two smaller drum sound hangerővelkellene to speak! There are some simple circuit for this? Louis Regards from Hungary!
Twins V1.2 diagram if you have someone do it already! Thank you.
From the album: TwinSid V1.2
Thank you! Everything ok! Louis.
I'm Hungarian! But the Hungarian forum completely deserted. Therefore I have written here. Perhaps someone can help me. I just wish more SysEx file in the memory copy! I do not know how you can ask for help in this! Thank you. Louis.
Only "Vintage Bank" in the memory can be uploaded. The rest I can not! Why??
I want a different kind of SysEx memory! Which one is it? Does anyone have?
Hello! Why should the Vintage sys file I can upload to memory? Several people have tried but I can not! Why do help me! Thank you! Louis.
Hello! If someone would be so kind to put up a sys file TwinSidhez food. Now the bank is the only vintage. Thank you for your kindness! Louis.
Hello! Can anyone help? Or because I can do that. If you have someone send it to me or post your ide.Most Vintage SysEx works, I'd like to spend another one in memory. Thank you! Louis.
Hi, could someone beat me to the EEPROM can be loaded / Sysex / send files? Thank you, Louis.
Finished the Twins! Have already said, only one expresses output and the other is completely silent. I do not know what could be the problem please help me me! The sid is good both because it is the same If you mix them with acsatorna. In the menu, I know the L / R channels but you can also set only one channel is about! How can I retrieve the memory of a SysEx hurt? Thank you in advance for Louis.
Hello! Finished the great work! It's just the problem. I could not even get him to speak. I do not want to sound. A vintage SysEx became our narrow passage loaded. Someone could help me? Only one sid/8580 / in it, but he also would not work? Thanks for your help! Or what you need to program the EEPROM??
Hello! I started building this structure. If anyone can possibly help it if a problem is it for me please. 25LC512 EEPROM writes to him, is a good 24Lc512?? Thank you very much! Louis.
Thank you, now it works! The module can be sid midibox 64 to be connected? Audio output will not work? Because I did not come to the audio output signal! How to connect? Be something else? Thank you!
Hello! I solved the problem it works perfectly. I'm working with 32 knobs. Not tied to the core body panel potentiometer connector pins of the remaining body. By doing so it works perfectly! Hello Louis!
Hello! I'd like to get some help from someone if possible. I built a MIDI Controller. 1 core / 18f452 /, 1 AIN module, 1 DIN module, 1 DOUT module. Beégettem the 18f452 into the bootloader, then Mios sub-species of the other required midibox64 hex. The problem is that the midi output with constant back and sends out MIDI signals. I do not know but I think I did quite well. Someone has logged this problem? Any advice will be appreciated and thank you! Perhaps a küldhetnétek firmwarw You guys that work well Thank you, Louis!
