13 -
Gender
Not Telling
Endfest's Achievements
Oeps, stupid me .. I thought it was the other way around .. :blush: glad 99% of the time I work with CV/gate or midi2midi cables ;-)
Hey Folks, thnx for your help & apologies for my delayed reaction..Good news, everyhting works fine over here now :) Superhappy, having total control over my midibox with Lemur now. So, for you wondering what the problem was ... I have this really strange USB-Midi i/o cable .. on the cable plugs it sais 'In' and 'Out'. So I was thinking, what for as far as I know the industrial standard is, you connect the midi in plug in the midi in of the Midibox port and the midi out to the midi out port .. but .. some of you see 'm coming, with this plug it's exact the opposite! After plugging the midi in cable to the midibox midi out and the other way around .. everything worked spot on, YesS!! Thnx for the help peepz & grtz from a happy Midiboxtweaker :sorcerer: :afro:
Hier een NL'er die een midibox 4 gebruikt (niet zelf gebruikt). Heb 'm nu een klein jaar en zou niet weten wat ik zonder mist .. hemel op aarde deze sequencer (op die irritante, soms haperende, plastic drukkapjes na..) :smile:
Dear fellow Midiboxlovers, I have a problem with getting my midibox connected to Lemur. The template is on my iPad, I tried different settings in the BLM_Scalar menu on different ports, but without success. Keep on gettin' that disconnection button in the upper corner of my iPad. I use the latest lemur Template and connect my iPad and midi box with a camera connection kit & USB-Midi cable. Could it that I have to change settings or the script of the Lemur template, caus' it was designed for operation through OSC, while I try to make a connection with that USB-midi cable? Hope someone can help to sort this out and get the job done .. l look so much forward to enter tweakin' heaven ;-)
YESS, she's workin' again!! Thnx for your quick help Thorsten :sorcerer: !
Hey Thorsten, thnx for your analysis. So, some soldering to do over here .. Unfortunately, since I turned on my midibox since last time, my midibox is even weirder. Don't know if it has to do with the OS update or using the MBSEQ_HW.V4 file (which I now removed), but now it seems like (almost) every button is giving a different response/menu than it should. Some examples: Press: Track/Group 2 --> Midibox edit screen (left LCD), SESSIONS OPEN, SAVE evt (right LCD) Track/Group 3 --> STEP/TRIGGER/LAYER view (left LCD), DATAWHEEL, RANDOM GENERATOR, EUCLIDIAN (right LCD) GP1 --> no response GP2 --> no response GP4 --> EDIT screen changes to UTILITY FUNCTIONS (left), QUICK MENU CHANGE (right) UTILITY --> STEP VIEW SCREEN F3 --> TRIGGER LAYER F1 --> TRIGGER LAYER CLEAR --> TRIGGER LAYER PATTERN --TRIGGER LAYER FAST --> MENU SHORTCUTS Totally confused about this. Sorry for questioning again, but do you know what could cause this? Best regards, Willem
Sorry, didn't uploaded that file the right way ... here's what I get when pressing GP 15 (different than the rest & a lot longer..): [1255878.154] [sEQ_UI_Button_Handler] Button SR:25, Pin:0 not mapped, it has been pressed. [1255878.160] [sEQ_UI_Button_Handler] Button SR:31, Pin:0 not mapped, it has been pressed. [1255878.166] [sEQ_UI_Button_Handler] Button SR:29, Pin:0 not mapped, it has been pressed. [1255878.172] [sEQ_UI_Button_Handler] Button SR:27, Pin:0 not mapped, it has been pressed. [1255878.179] [sEQ_UI_Button_Handler] Button SR:26, Pin:0 not mapped, it has been pressed. [1255878.185] [sEQ_UI_Button_Handler] Button SR:24, Pin:0 not mapped, it has been pressed. [1255878.191] [sEQ_UI_Button_Handler] Button SR:30, Pin:0 not mapped, it has been pressed. [1255878.197] [sEQ_UI_Button_Handler] Button SR:28, Pin:0 not mapped, it has been pressed. [1255878.284] [sEQ_UI_Button_Handler] Button SR:27, Pin:0 not mapped, it has been depressed. [1255878.290] [sEQ_UI_Button_Handler] Button SR:25, Pin:0 not mapped, it has been depressed. [1255878.296] [sEQ_UI_Button_Handler] Button SR:31, Pin:0 not mapped, it has been depressed. [1255878.302] [sEQ_UI_Button_Handler] Button SR:29, Pin:0 not mapped, it has been depressed. [1255878.309] [sEQ_UI_Button_Handler] Button SR:28, Pin:0 not mapped, it has been depressed. [1255878.315] [sEQ_UI_Button_Handler] Button SR:26, Pin:0 not mapped, it has been depressed. [1255878.321] [sEQ_UI_Button_Handler] Button SR:24, Pin:0 not mapped, it has been depressed. [1255878.327] [sEQ_UI_Button_Handler] Button SR:30, Pin:0 not mapped, it has been depressed. Best regards, Willem
Hi Thorsten, I made it to the last step, but don't get any info on my MIOS Terminal button when I press GP's. When I press start or step I get code 'fa' and 'fc' in the Midi in screen (left above), when I press keys on the virtual keyboard I get note info in the Midi out screen, '[1253386.245] 93 46 6d Chn# 4 Note On A#3 Vel:109] Only info I get in the terminal output is this info over I put reset (reboot works fine): [1253198.761] reset [1253200.849] Init DHCP [1253200.948] [network_device_init] PHY initialized [1253203.981] Loading session 13112W [1253204.082] Init DHCP Is there something I do wrong?
Hey Thorsten, thnx for your quick reply & detailed reaction. Gonna dive into this & let you know! Best regards, Willem :smile:
Hey Thorsten, Thnx for your help (once again) & clearing things up. So, I found out that when I do press GP14, everything works fine and in the way you described it. I can recall and import them now without problems :) Things do still get strange when I use GP15. I think it has to with your remark that button 15 is (unintentionally) triggered .. because .. when I work in edit modus to - for example - write a pattern, also strange things (for me) happen when I use GP15. I want to show that with the two pictures underneath. Picture 1 is where I start to make a pattern Picture 2, is what happens when I push GP15. As you can see, my entire pattern is changing, the value of my notes even the positions of them. I do get a complete different pattern when I push GP 15: Do you know what I can do to make GP15 work normal again. I also noticed that GP15 is not working as it should, when I try to save a preset. Instead of 'Hoi', it's saving my preset as 'How' and instead of 'Shruthi' it's saving 'Shruthw'. Seems the same kind of problem caus' of triggering, not? Here I song I recorded, with help from your great Berlin School tutorial. As you might can hear, I'm havin' big fun & feel I finally can manage to compose music I wanted to make for a long time ... https://soundcloud.com/endfest/der-beobachter Best regards, Willem
Thnx for having a closer look at this Thorsten. Good weekend!
Thnx for your help & clearing up how I do select presets Thorsten (by scrolling & pressing the buttons under the selected preset & afterwards press IMPORT), that works totally ok ... The other situation, the randomness in gettin' into this select preset screen (second picture in my post above) still is a mystery. Here a step by step description, to give more information: First attempt 1) Power up with USB, I get the Edit Screen 2) Pressing Menu + event 3) Pressing button 15 (midi) to enter presets 4) I get the first screen 5) Pressing Exit 6) Pressing Presets again 7) I get the second screen 8) Pressing Exit (button 16) and after that Presets (button 15) again 9) I get the second screen again 10) Pressing Exit & Presets again 11) Next 8 times I get the first screen again Second attempt 1) Power up with USB, I get the Edit Screen 2) Pressing Menu + event 3) Pressing button 15 (midi) to enter presets 4) I get the first screen 5) Pressing Exit 6) Pressing Presets again 7) I get the first screen again, also for the next 15 times 8) After the 16th time I press exit & import I get the second screen Third attempt 1) Power up with USB, I get the Edit Screen 2) Pressing Menu + event 3) Pressing button 15 (midi) to enter presets 4) I get the first screen 5) Pressing Exit 6) Pressing Presets again 7) I get the first screen again, also for the next 7 times 8) After the 8th time I press exit & presets I get the second screen As you can see from above, it’s like random button pressing to find a chance to select presets in the left screen … do you know what could cause this randomness? Is there something I do wrong?
Hai Folks, Got a question 'bout storing and calling up presets on the brand new midiboxSEQ4 (already in love!) - a good friend of mine build for me... When I press Menu + event & after that step button 15 (PRESETS), I get this screen below: 1) Can someone explain me how I can select a different preset in the left screen? Now I only can select the preset 'JOMOXW.V4T' I created, although there are more presets I should be able to select (I created more than one)... 2) My second question is how I select the next/second/different 'presetscreen'. This one below: When I press step button 15 (PRESETS), I normally get the first screen I posted, but sometimes (almost kind of random) I get this second screen. How do I switch between those two? Now I sometimes, almost by accident, come into this 'save as new preset screen'.. My 3th question is why I can select pages (in the left screen) when I want to store a preset, but when I want to import one, I can't scroll between my created presets. Besides this, I'm must say, after spending two days with this machine, this is heaven. Makin' beats with that awesome euclidean rhythm generator and creating pattern chords in seconds is so unbelievable fun, easy & dope. Thorsten, you did such an amazing job by developing this beast, this IS by far the FATtest sequencer I have ever touched. I feel blessed that someone wanted to spent all that time to build this crazy machine for me .. hope someone can help me with solving these questions above..
