I heard about MIDIbox some time ago from a dear friend. Not realizing its potential at the time, it ended up somewhere in the back of my head.
However, now that I am planning to build an analog(ish) synthesizer, I can start to see attraction of the system.
My question is this: How much will the CORE_LPC17 board be able to process at a time?
Here follows a list of functions:
Scan a 49 key keyboard, using a six-bit polyphonic decoder. (Requires six Douts and one Din)
Mix note events from the keyboard into the external MIDI stream.
An internal clock, with tempo derived from either a pot or tapping.
A basic arpeggiator with the following functions:
Up, down, up-down, down-up, random, or order pressed modes.
Run over 4 octaves.
Semibreve, crotchet, quaver, semi-quaver, etc... based on clock input, from either the external input or the internal clock.
Gate length (PW) controlled via pot.
Output a CV, a gate, and clock pulse (to LFOs)
Potentially a MIDI output, combining the data from the original MIDI stream, the keyboard, the internal clock (if being used), and the output from the arpeggiator on a separate channel.
I think that is all for now. Shall write back if I remember something else...
So, would the core board be able to process all of this simultaneously?
Regards,
Steve.
