18 -
Everything posted by fourfour
Where do I put this file? I am not familiar with how to use templates? Thanks!
Hey Duggle. I was thinking I needed something like this. Do I just replace my default NGC with this code?
Here are all my files loaded on the SD. Archive.zip
Hey everyone. I am having trouble getting Pro Tools to respond to my controller. I have it setup in Pro Tools as HUI, but nothing seems to work. Is there a setting I need to declare in MIOS for HUI Emulation? Or is that always available? Setup: LPC17 NG DIN Thanks! -eric (the attachment shows the MIOS in italics, I just had it unplugged when I did the screenshot)
woot. @novski that was it! Again, thanks for the help everyone.
It all seems to be hooked up fine. I just had some jumper wires laying around that I crimped some dsub connectors to. All those are passing current fine. Do you have to #include a NGC file for it to load? Or does it load every file on the SD?
@duggle Ok, I tested all the connections. The clk, data and RC all beep ok from the core to the first shift reg. Thanks for your help.
@novski I am following that 'first steps' tutorial
Hey Spirit. Ya I get the voltage drop to 0V when the button is pressed. I have this in HELLO.NGC RESET_HW EVENT_BUTTON id=1 type=NoteOn key=36
I'm stuck again :/ I am new to hardware dev, I come form the software side of things. I appreciate everyones help getting me off the ground. I have a DIN connected to J8 and a single button. I am trying to get the 'first steps' one button test to work. There is voltage and the button works. Am I correct that the button gets wired to ground and D0? I get a voltage drop when the button is pressed, but nothing happens in MIOS. Thanks!!
Ok! We have liftoff! Thanks so much everyone.
@duggle: I assumed they just mirrored J8 e.g Vs Vd Si Sc Rc I have some ribbons on order. The site didn't state that I needed to order them separately. Thanks for your help.
@spirit: oh my, thanks for catching that. Unfortunately, that didn't solve the issue. LED still on all the time. I checked my wiring again over the whole board. (how do you send a beer?)
Hey Duggle. I am getting voltage to the DOUT board, tried using J8 and J9. Here are some pics, thanks for your help!! https://s3.amazonaws.com/uploads.hipchat.com/14874/54948/jijmbr9a06d226i/IMG_9264.jpg https://s3.amazonaws.com/uploads.hipchat.com/14874/54948/szsbs0p7lz9nyxs/IMG_1599.JPG
Hey Pete. Ya, I tried that already. I also tried setting individual pins to 0|1 and nothing happens.
Hey guys. I feel super stupid atm. I can't get anything to work as expected. I need to get back the basics here. I am have the LPC17 and a DOUT connected via J8. I hooked up an LED to Vs and D7 and entered 'set dout all 0'. I am still getting 5v at D7 all the time. Nothing else is connected. What am I doing wrong? Board specs attached. Thanks!! -eric
Hey Thorsten! Thanks for the quick response! re: ProTools fader control I am building a channel strip for a plugin. So all the encoders/buttons will control the plugin and the fader will be the output fader of the ProTools track. I need the fader to be controlled from ProTools and to control ProTools. The point would be to write and playback automation. I am not familiar with the protocols to know which would be best to implement. I don't think MBNG would need any control. Cheers. -eric
Hey. This is my first time posting and my first build. Thanks for all the hard work on this project. Very cool stuff! I have a few questions on getting started. I have the LPC17 setup with the SD and working over USB. My configuration is going to be: LPC17 (2) DIN to control 21 Rotary knobs and 20 buttons (1) MF_NG to control 1 Motorized Fader (Alpha) (1) DOUT for LED I won't be using any midi ports for this project, it will be USB-MIDI. I have J4B of LPC17 connected to J11 of MF_NG. From here, I have no idea what to do to be honest. :smile: I would love to make a detailed PDF of the connections to share. I will be interfacing this with ProTools and Reason, what is the best emulation for those? Any help would be amazing. Cheers. -eric
