benwa
    8
Everything posted by benwa
  1. https://m.facebook.com/profile.php?id=736169256448640 tiens sur la page facebook du pote qui me l a fabriqué!
  2. salut je vend mon midibox seq v4 que je viens d acheter a un pote mais c est trop compliqué pour moi, je le vend 550 euros le prix que je l ai payé ave la face avant noire format rack avec 2 midi in 2 midi out sur l arriere et le dessous, pareil pour le lecteur de carte
  3. thanks you very much tk!
  4. thank you for your reply tk yes, before my friend build me my midibox seq i was using an mpc,on it there was a thing i liked that was; on each track i was able to associate a program change, that pc made his job to change my patch on my synth when i started my pattern then it didn t change again when my loop cameback to the beginning, so i wa able to tweack button and my patch was not reinisialized at every beginning of the pattern, i think it would be nice to have a the possibility to set a program change on each track without the need to put a pc on each step, or maybe it would be possible to configure it like a 0 program change don t change the patch?
  5. if i disable this option will i be able to associate a mixer to a track? i don t like to have to set a programm change on each step of tracks to select a patch on my synth for each track, or maybe i make a mistake and it s possible to disable program change on some steps?
  6. hi, i have just replace the button scrub that i didn t use to use it for the remix pattern feature, it work great, but i have this problem with the last firmware 4.086 the mixer map 65 come back every time, i can t associate a mixer map with a pattern it s the thing i d like to do to change pattern in sync with my elektron analog rytm, is there a way to do it properly?
  7. hi everybody, it s my first post on this forum, a friend just build a midibox sequencer v4 for me, and the first thing i really can t do is how to change the pattern on theidibox at the same time i change mattern on my elektron analog rytm i know that analog rytm send program change on channel 14, i d like to keep the analog rytm as master but if it s not possible i would change. i tried with the mixer map but was not able to associate a map with a pattern, i hope someone will be able to help me and hope you will understand my bad english :-)
