knarleybass
    11
Everything posted by knarleybass
  1. I'll take a kit, I have a few chips here
  2. I got it up and running, everything is loaded, and it sounds great. I can't tell if both sid chips are working, is there a way to test that? H
  3. you were right, the connectors on the right are for the backlight, K and A are for Cathode and Anode. once I figured that out I ran some wires. it's light up now. thanks again for your help. now to figure out the rest.... Howard
  4. Well, I soldered in the display just using the misaligned pins on the left side, and I am getting no backlight, I tried 5v and 12v. Howard
  5. One more quietestion, what do I set the jumper to for the backlite voltage? howard
  6. Thanks Ladigid On, I'll give it a shot, thanks again for your help Howard
  7. I am still a little unsure on how to re route the power for the display
  8. Thanks for the replies, here are some more pics, al this said, should I have a different display? thanks Howard
  9. honestly, I don't know. It's the display that came with the kit
  10. HI, I have had this sammichSID kit laying here, today I am putting it together. I have the Revision 3 board, everything is going well, but, I am at the stage where I line up the pins from the bottom board to the top/display board, the bottom header has 18 holes, the header in the display has 16 holes
