Hey! Thanks for the Replies.
The specific Error Message is "MIDI PROTOCOL TIMEOUT !!!" (with three !!! like that haha)
A part of the problem was definitely the clock. After switching from "Auto" to "Master" in the BPM settings page, The steps no allways go, and never hang up.
However, there is no midi data being sent, and I have my Midi Router Settings set to OUT1 as the default port, and All of my nodes set to OUT1.
Now, I just get that error message when I press stop.
I have no other midi devices plugged in, just one synth/drum machine in output A. (I've tried a bunch of different gear with all the same results.)
The breadboard didn't have any power, but it was only 1 of the output circuit of IO Module. basically ground,pin, 5v pin+220Ohm resistor, and MO1 pin+220 Ohm resistor.
I'm using a phone charger, and my multi meter probes aren't small enough to test the contacts
Also, I had some suspicion It might be my poorly made ribbon cables, so I bought 2 brand new pre-made ones from amazon, and they came yesterday, and I'm still having the same problem.
