kasiofz
    4
Everything posted by kasiofz
  1. Hi Thorsten, Thanks for the answer. Something has to be wrong with if statement, because when I replaced the code line with the if statement that you suggested nothing changed. But, when I replaced the code line with only the else statement code the problem solved. So, to summarise I replaced: SEQ_LED_PinSet(seq_hwcfg_led.beat, (seq_hwcfg_led.measure && measure_led_on) ? 0 : beat_led_on); with SEQ_LED_PinSet(seq_hwcfg_led.beat, beat_led_on); And the beat led worked fine. I thing that something is wrong with if( seq_hwcfg_led.measure != 0xffff ) Regards, Vasilis
  2. In the roll layer of a 32step drum track, if I change the roll parameter for step 1 I get roll on step 17 too. I don't know if this is normal, but the same happens on the other step pair too (2-18, 3-19 etc.) I want to ask if I can find the source code for midibox_seq_v4_095 latest release because I want to built it manualy with some modifications in the code-config file. Also I want to compare the two sources to source the beat light problem.
  3. Hi all, First post here, I used the latest release (midibox_seq_v4_096_pre5) on an LPC17 core. The beat led doesn't flash on the first step of the sequence. So I get 3 flashes in a 16 step loop. If I set the track synchronisation to 32 steps, the beat led flashes normally on measure step 17, but doen't flash on step 1. So I get 7 flashes. Release midibox_seq_v4_095 works without the above problems.
  4. Hi Is it still available?
