synthmania
18 -
Recent Profile Visitors
synthmania's Achievements
Change the default channel at boot from 1 to another channel
synthmania replied to synthmania's topic in MIDIbox SID
Not sure if this is not doable at all, or if it is not worth to do :) Got no time to go in the ASM code of the OS, but if that is what is required, I can do that no problem. -
Thanks! I was wondering why there was also a couple of banks that are not usable. And totally forgot about the bank reserved for the ensemble. Thanks!
I am troubleshooting an issue on my sammichSID; basically I see that all the 24LC512 memory chips are installed; there are 5 of them. When using the SS, I can see bank A, B, C and D, but E, F and G give me the "no bank" message on display. I am curious how does the memory on the SS works, with these chips. Is each chip hosting a bank? In which case I should see banks A through E; but the last bank seems to be D. Do I have to initialize again the chips, or maybe some went bad? Thanks
CTRL panel with sammichsid seems to hang
synthmania replied to synthmania's topic in Testing/Troubleshooting
Found the issue; I had a newer version of CTRL; so the panel won't work. Downloaded a version from few years ago and it works fine. Cheers! -
I have found the CTRL panel for the sammichSID; which seems to work for wave shapes and other controls; but if I press buttons like the one to init a patch or to read the patch from the device, it just hang. I see the LED on my interface showing midi traffic but it never stops, it goes on and on. I just started with CTRL so I can't just look at the problem and figure this out, so I wonder if someone can give me some pointers about what is going on and why. Seems that the panel wasn't updated for quite a while, although same goes for the sammichSID, so I wonder if this is somehting that can be fixed or if there is something else to troubleshoot, that goes beyond CTRL panel. Thanks
Hi Krizz, not sure who this Paolo is, but I assume you got the wrong person :) Indeed I am going for the 8580 too; got 2 more SID chips since I am building also another midibox on top of the sammichSID ;)
Brilliant, thanks for clarifying things!
Thanks Thorsten, Tried as you mention, but somehow that ABW parameter does nothing fundamentally. I tried to load the init patch and the "techno PWM" and the background note that continue to play is still there,although I lose the glide when it is on. I can still hear the background play on any patch I tried, even turning on ABW. One interesting thing is that there is a GSA parameter, that is also used to solve the ADSR bug, from what the manual says, and when I enable that; the outcome is like if I had a "hold"; so the note continue to play even after I release the key, at full volume. This is quite different from what I hear (very low volume tone after releasing the note). BTW where do I set ADR to 0 and how do I tell MIOS to use the SW based filter ADSR? Thanks!
Hi, Just finished to make a sammichSID; using 2x6581 original SID from 1982 (not sure the revision; I would assume R2?) sourced from my old C64 and the second was from internet. Everything seems to work fine; although I noticed that there is a very prominent issue: the clearGate bit does not seem to be set when the note off is send; so while the sound is not that pronounced, you can see from the oscilloscope and hear from the speaker, that the VCO are still up and running. I have no idea what the problem is, since I am using MIOS, I didn't write the code myself. Searching the FAQ on midibox2 manual there is a note about audio ghosting on 6581 and VCO not going silent, but there is no actual solution explained; I heard this is a common problem on sammichSID boards and it is solved by filtering the audio or changing the volume settings on the sammichSID, so the ghosting won't be perceived. Is this the only solution? While searching online, I found this video that show the sid driven by an arduino, and to stop sound, the clearGate bit is set at the end, which silence the VCOs. Is there a way to do this in MIOS too? I noticed the only thing that get close to set the clearGate bit is to change the preset; although in a live situation is not really feasible, especially because some presets does cause an audible pop when switching preset. Attached the video below so you can see what the user here did. I know the sammichSID is not the same as this in the video; but I would assume that MIOS is talking to the SID using the standard registers, so there should be a clearGate instructions that can be sent somehow via midi, when noteOFF is send and the value of Decay parameter is honored, so you won't cut off sound ?
Nice pictures! Those will come handy to get a comparison when soldering the components. Did you buy the kit including all the parts included? Would be nice to have an updated bill of parts for that kit, I just ordered the parts for the core and SID modules, not for the MB-6582 PCBs yet :)
Thanks for the clarification. In the end being a DIY project, I understand everyone can make it as they like :) What is routing matrix adding to the overall experience? Maybe it is more for live usage? I am planning to tuck the device under the table or somewhere around and use it as sound module mainly, so the lack of extra controllers or even a screen is not bothering me (for now) :) So the issue is just noise? The manual seems to mention ghosting, when a note is pressed and released; which to me sound like a pretty big problem. I can do filters; so if that is all is needed that should be simple; but I would assume there is a way to totally silence the VCO on the chip, to remove ghosting but I can't find much on the forum either. Maybe a fast program change back and forth would stop the VCO ghosting? Or send a reset signal? Although if I remember correctly, that will reset also the current settings you have on the buffer of the chip.
Thanks; I read the manual but it is not a step by step manual, so it is more of a guideline about how to do things, and there are no reference to pre-made PCB ; that's why I was asking (there is a broken link referring to a kit, that's all I was able to find on the manual). Since I want to try all solutions, I did order the PCBs AND got the sammichSID kit; hopefully it will arrive soon, since I paid for expedite shipping. I have 2 6581 so I can use one for each project and see which one works best for me; got all the components monday, so I can do all 3 implementations at this point and see which works best for me. @dwestbury I was told that sammichSID has a different interface, even if it is using MIOS; in fact I saw that it has a row of buttons that is blank (I assume those are the #1 to #5 buttons for options, there is no label on them from the picture I saw), and a second row with F1 F2 and F3; the midibox V2 manual does not seem to have any reference to these. The other side has the shift, menu, and top-bottom buttons; which are in the manual. Is there a sammich manual beside the build guide? Also as side note; using 6581, the manual warns about leakage of the sound after pressing a key; how bad is it? Is there a way to solve it? Because if I am recording audio that has leakage and background sound, I can't really do much to fix it (I can fix background noise with the audio tools available these days, but I don't think that will work for actual persistent audio that leak. I won't know until I actually build either solution so I want to be prepared about it Thanks!
Thanks for the clarifications! So it is fundamentally a core with 2 SID modules then? I looked around and the prices for the few on the market are insanely high. The other alternative is ebay kits; which I assume are not "original", if the user didn't release kits anymore and he is not selling them from what I can tell. If it was in the 100-150 USD ballpark I may consider it; but I see that ModularAddict sell the PCB already, so that is a more practical way to get started I think. Good point on the SID not being producing the same sound; I was curious why would someone use 2 in stereo, but since each chip has 3 voices mono, that make sense. Would you say that to start, I should get the PCB from https://modularaddict.com/manufacturer/midibox ? I have no clue how to work with PCB, I can make breadboard circuits but that's the extent of it; having a PCB that is well made is probably the best route for me. I was planning to order the SID module, but there are 2 core modules; there is MB6582 - SID synth main PCB and Core8 PCB.Then I need the midi module too I assume, to be able to have the box to talk to my computer.
I am a beginner too and finally got the plan to build a simple setup with just the core and the SID module, and like others, I also found myself struggling to find step by step instructions that show how to do things; but the nice part is that the forum is pretty active and people are super helpful! If someone has an updated bill of materials for the various modules, that would be awesome to have! Also I am not sure about PCBs... is ModularAddict selling PCBs for the different modules? I found one PCB that say 'SID synth main PCB", although it is quite large and does not look like the core one on the website. I am going for the basic approach; which is 1 core, 1 SID and the midi IO, so I can use it as sound module and make all the changes via midi/sysex. I am hoping to find a PCB pre-made because I know how to solder but I never made a PCB nor I made a perforated board project before, so I would gladly skip that part :)
