TK.
Administrators
    15,248
  1. Up to 16 different modes can be realized, problem is only the order of listed modes in the menu. 1) I could either add it behind Note/CC/Len, but this would make existing patches incompatible if they are using modes behind this new one. People could complain about this 2) Or I could add it to the end of the list, but in this case some other people could complain about the strange order of event modes. So, what would you prefer? Best Regards, Thorsten.
  2. The expensive solution would require seperate CAN tranceivers for each PIC. But the diode/pull-up resistor approach works extremely stable as I noticed, and I think that tranceivers are only required for higher distances (e.g. > 1m or so..), or if you are planning to access the master/slaves from another CAN node like from a PC with CAN interface card (I've prepared this multimaster capability in the protocol). Maximum distance: 40 meters Best Regards, Thorsten.
  3. I would prefer what I've proposed several times: that uCApps turns into a "reference manual", whereas the wiki goes into the direction of a "user manual". I would like to concentrate on the specs and requirements, and the wiki could elaborate it more understandable for common users, who are not so deep into the topic. Example: MIDIbox64 - most people don't know, what cool things they can do with this controller, they don't know, what "Snapshot", "MIDI Merger", "Morphing", "Meta Events" really means. Some people even don't know, what a MIDI controller can do at all, how to setup their software, etc... for myself, this is clearly a part of a user manual, and this is the stuff which has to be documented by the community. Once such a "user manual" exists, I would just reduce the MIDIbox64 page, so that it highlights the features and lists the links to additional informations. And at least one link would go into the Wiki Another example: the bootloader page for newbies is clearly a more user friendly description of that what you can read in the expert page -> Wiki. Also the description of the MIDIbox SID Control Surface needs some extensions, it has been started here: http://www.midibox.org/dokuwiki/doku.php?id=midibox_sid_v1_manual, but it's far from completion. Once this page is complete, I would replace http://www.ucapps.de/midibox_sid_cs.html, but of course, I would never replace the main page http://www.ucapps.de/midibox_sid.html Of course, the wiki can and should never replace ucapps.de, this would be the wrong way. So, please don't discuss about the sense or nonsense of the wiki, just improve it! :) Best Regards, Thorsten.
  4. This idea isn't so new... the problem is, that so many people offered help in the past, but the results were only an overworked layout or re-verbalized informations from my own page with zero advantages for the users. It's the content, that counts! So, my proposal: copy an uCApps page into the Wiki, improve it dramatically, and I will replace the old page by the new wiki page. Please don't do this in hurry, but do this with full dedication. Don't try to revolutionise uCApps.de immediatly and left it as a long-term lot, but bring it slightly into a new direction! Best Regards, Thorsten.
  5. I'm using Wilba's PCB in the meantime and accordingly don't have problems with the space inside the case See http://www.midibox.org/midibox_sid_blm_photos/ Best Regards, Thorsten.
  6. Ok, in this case I'm sure it's an interconnection problem as already assumed by doc. You should try the srio_interconnection_test_v1 to check the control lines to the DIN/DOUT modules. The test procedure is described in main.asm Best Regards, Thorsten.
  7. In the meantime I made some additional experiments, and I think that I will release a last V1 version with CAN support (for PIC18F4685 only) which will include all the communication functions which I will use for MBSID V2 as well. This is to get more experiences about the best protocol handling before I'm starting with V2 Thanks to CAN it doesn't really make a big difference anymore, if the SIDs are connected to the PIC which also handles the CS, or if they are connected to slaves, and accessed from the master remotely. Accordingly, so long only 2x3 SIDs (stereo option) should be used for such a system, just left out the SIDs on the control surface PIC. I've prepared the protocol for up to 127 CAN nodes, but I think that 7 should be the maximum for the internal handling, otherwise it would only be a waste of memory. Makes 1 master + 7 slaves = 16 SIDs ;-) But I want to highlight, that I would never test such a system and cannot guarantee that it will really work. My own configuration is still 1 master, 3 slaves, 8 SIDs Best Regards, Thorsten.
  8. Ok, I see. It could also be useful for myself when I temporary want to disable the loopback in order to control the arpeggiator/transposer directly from a keyboard. Therefore it's implemented now in the new build #69 (F1->PMte) There isn't enough RAM for an effect like the Magic MIDI Delay, and also the complexity of the sequencer engine would kill me - I've already difficulities to add new features w/o looking deeply into the code I programmed months ago... therefore I don't think, that I will add much more complex features, only simple features, into V3 You can send Notes or CCs. Notes will be forwarded to the transposer and arpeggiator, this allows you to realize quite impressing tunes with a small number of patterns (or just with a single pattern set) CC's will be forwarded to the track NRPNs, the Loopback channel correlates to the track number. There is nothing more to say about this, the usage is straightforward. it's the scroll function, it shifts all selected tracks left or right from the step at which you are turning the GP encoder seems that I forgot this combination. From my oppinion it would fit best at the position which is currently used for Note/CC/Len - does anybody use this one? If not, I will replace it A mixer map just allocates a song position, you can dump one or more mixer maps whenever you want, it's part of the sequence. Best Regards, Thorsten.
  9. Build #69 got a new menu page for muting MIDI ports o a new menu page is available which allows to mute the output ports seperately (Def, Int, IIC0-3, AOUT, Loopback). It can be quickly accessed from the Utility page (F1->PMte) [/code]
  10. Thats possible with a small modification in mios_midi.inc, search for "MIOS_MIDI_RxBufferPut" and "prevent overrun" Best Regards, Thorsten.
  11. Am Gameport liegen 5V an, in diesem Fall koenntest Du also auf den 7805 verzichten Gruss, Thorsten.
  12. Yes, it's located in mios_tables.inc, the name is "MIOS_MPROC_EVENT_TABLE", and on matches the USER_MPROC_NotifyFoundEvent function will be called. I must clearly say, that it was a bad idea to add such a feature to MIOS, as most applications need an individual MIDI handling with different data structures. It's also not possible to realize, that a Note Off event will turn into a Note On with velocity=0 w/o duplicating table entries. On the other hand: this is the fastest parser you will find especially for CC's Best Regards, Thorsten.
  13. Two things would be interesting for me: how does the CS behave, when no BankStick is connected? Which BankStick (EEPROM types) are you using exactly, and are there different Chip-Select configurations (Pin #1/#2/#3), so that each BankStick has an individual address? 2: Do you see a "*" marker left to the patch number in the SAV menu? This identifies, that no BankStick has found for the selected bank. Changing Pattern Names: CFG->Nam Best Regards, Thorsten.
  14. So, finally my answers (as I've a little bit more time to read them and to think about a solution) You can already do this by pressing and holding the MUTE button. Now you can select multiple tracks with the GP buttons. All selected tracks will be solo'ed when you activate the SOLO function. I will add a sequencer option for this alternative behaviour sooner or later (not guaranteed to be included into the v3.0, which I'm planning to release soon to get a free head for MBSID V2) MIDI Fx: planned, but not for V3.0, as it will require a lot of programming effort. I'm not sure if I would use this by myself, because most of my synths are voice limited, so that I prefer audio Fx (therefore: low priority) Changed progression: this is already possible by using the Loopback. You can control CC#41, CC#42, CC#43 (see mbseqv3_cc_implementation.txt) from another track. You can use a clock divider on this track to make changes each 16, 32, 64 steps or so.... I want to highlight, that there might be more possibilities available than anybody ever have thought of ;-) It's called "Scrl" (for scroll), as the term "Shift" might be misleading. it's finally available now, after I head to overwork most of the song handling in order to realize such special actions. Therefore it took a little bit longer (it wasn't so simple as expected) Mixer maps can now be dumped within Songs (or Phrases) as well A direct link to patterns is not possible for conceptional reasons (as the content of mixer maps is not directly related to the content of patterns) Best Regards, Thorsten.
  15. Build #68 contains a lot of improvements I made in the last two weeks for the song menu page and the phrase/song mode. Phrase mode is the one I prefer to use, as it allows me to prepare pattern sets and to switch betweem them interactively while the sequencer is playing. Song mode is the traditional mode you know There is a slight incompatibility when you've used song position jumps in the past. The target position is now stored in the G0 parameter. But this change allowed me to introduce two new song actions: jump song and dump mixer map. From the ChangeLog: o in song menu page, there is now a better seperation between "Phrase" and "Song" mode. It can be switched between these two different modes by pressing the SONG button multiple times. The SONG LED will flash when the sequencer is in Phrase mode. Definition of Phrase Mode: a song is used as "pattern set storage" You can define a set of 4 patterns (G1/G2/G3/G4) for each song position. You can link one or more mixer maps to a phrase. The sequencer changes to a new pattern set immediately, or synchronized to the beat (selectable in options menu), once a new phrase has been selected. This can be done with GP encoder #2 (Phrase A1, A2, A3, ..., A7, B1, B2, ... -> 128 phrases). In addition, the phrase A1, B1, C1, ... P1 can be directly triggered with the GP buttons when the cursor flashes below the "Phrase" menu item (second item in the menu). Quick selection: press LAYER B button (see below) The usage of GP buttons is propably the most prefered, as it allows you to quickly change between different pattern sets while the sequencer is playing w/o temporary selecting other sets which are between them with a rotary encoder. Phrases can also be combined with one or more mixer maps. In this case the first step (A1, B1, C1, ...) has to be assigned to a Mixer Map Action (see below), whose content will be dumped out. The sequencer will go to the next song position, and check for a Mixer Map again. Once it has reached a position with a pattern set, it will change to the new set and give back control over pattern changes to the user. Definition of Song Mode: similar to Phrase mode, each song position holds a pattern set. In addition, following actions can be defined: o STOP: will stop the sequencer once this position is reached o PLAY (x 1): plays the pattern set for one measure and thereafter jumps to the next position o LOOP (-> x 2 .. x16): loops the position 2 .. 16 times and thereafter jumps to the next position o JUMP POSITION (-> A1 .. -> P8): will jump to the given position o JUMP SONG (-> S 1 .. -> S16): will jump to the given song o SELECT MIXER MAP (-> 1..128): selects a mixer map and dumps the content. Continues with the next song position Shortcut buttons: within the Song Menu Page, most menu items can be selected very quickly with the TRACK and LAYER buttons. o TRACK 1: sets cursor to G1 item - you can now change the pattern with the GP buttons or with the datawheel o TRACK 2/3/4: like above, but for G2/G3/G4 item o LAYER A: sets the cursor to the Song item - you can now change the song with the GP buttons or with the datawheel o LAYER B: sets the cursor to the Phrase/Pos item GP buttons select 1 of 16 phrases/positions in steps of 8 Datawheel selects 1 of 128 phrases/positions o LAYER C: only in Song Mode: selects the Action item o new option: when the sequencer is running in song mode, the edited song position can now automatically follow the song. This optional function, which might disturb an edit session, can be enabled in the options menu (F1->Opt., within this menu, press select button to reach the "FollowSong" option) o there is now a check during the initialisation for the PIC derivative. Execution from any other PIC than PIC18F4620 is gracefully prevented. You will see a message on screen, and a MIDI event "EE <devid[2:0]> <devid2[9:3]> is sent to notify about the wrong PIC [/code] You will also notice, that main.asm has vanished. Now only setup_*.asm files are available anymore - this is to make clear, that main.asm was my own setup with special hardware settings (it's now in setup_tk.asm)
  16. Yes, there is a way - just use the MIDI router project. A firmware for a standalone MIDI merger is not available, however, I guess that you have a PIC18F452 free from your MBSID V1 Best Regards, Thorsten.
  17. TK.
    SEQ FW
    Vielleicht haben noch andere Leute einen PIC18F4620 herumliegen, den sie sich urspruenglich fuer die MBSID V2 besorgt haben. Ansonsten bietet Mike einen vorprogrammierten PIC18F4620 in seinem Shop an. MBSEQ V3: die laeuft ja schon seit ca. 3 Monaten bei ein paar Leuten, alle geplanten Features sind implementiert, ein paar neue Requests von Anwendern sind noch unter Diskussion, Bugs gibt es keine Siehe auch http://www.midibox.org/forum/index.php?topic=7805.0, dort steht ein Link zur Firmware Gruss, Thorsten.
  18. My comments this weekend (I've already prepared an update of MBSEQ, e.g. the song menu page has been overworked, but its not complete yet) Best Regards, Thorsten.
  19. TK.
    SEQ FW
    V2.4 kann nur einen einzigen MIDI Port adressieren. Es ist moeglich, das Modul bereits jetzt zu verwenden, indem Du die MIOS ID auf 00000000100000 aenderst. Im change_id Package gibt es hierfuer bereits ein vorgefertigtes .hex File (iic_midi_10.hex), dass Du einfach nur aufladen musst. Danach wird der MIDI Out ueber das MBHP_IIC_MIDI Modul mit Adresse 10 geroutet Danach wieder die MBSEQ Firmware aufspielen jep, kein Problem Uebrigens: in der Fleamarket Sektion werden gerade PIC18F4620 mit aufgespieltem Bootloader angeboten! (8 EUR + Versand) Gruss, Thorsten.
  20. TK.
    Midi Software
    Hallo, wuerde mich ebenfalls interessieren. Ich habe noch kein Programm gesehen, das ohne Neustart die Liste der MIDI Interfaces aktualisiert, und diese dann auch noch automatisch verroutet Gruss, Thorsten.
  21. as my boss says to such questions: today we will solve the problems of today, tomorrow the problems of tomorrow ;-) However, the two allocated pins RB2 and RB3 have to be duplicated at a free port, e.g. Port RA2 and RA3. This doesn't cost much performance Currently I would prefer a compile option here, since it's a very special case. I've already changed MIOS, so that derivative specific settings can be made at a single place (mios.h), thereafter you need to build a new mios binary. #if PIC_DERIVATIVE_TYPE == 4 LIST P=PIC18F4685, R=DEC #include <p18f4685.inc> #define PIC_DERIVATIVE_CODE_SIZE 0x18000 #define PIC_DERIVATIVE_RAM_SIZE 0xd00 #define PIC_DERIVATIVE_EEPROM_SIZE 0x400 #define PIC_DERIVATIVE_IRQ_WORKAROUND 0 #define PIC_DERIVATIVE_T08BIT_INVERTED 0 #define PIC_DERIVATIVE_SET_LCD_4BIT 1 #endif [/code] Please note that I found out, that the 4bit initialisation sequence doesn't work with all LCDs (it didn't work with my displaytech 2x20). In the meantime I solved this, the fix will be available with the next MIOS release I will make it available next weekend. My priority was on CAN setup at the application side, I haven't updated MIOS yet to support addresses >= 0x10000, this will require some changes at places where the table pointer is initialized, and the ISR needs to store/restore TBLPTRU in addition CAN is an ISO standard, there are many microcontrollers available which support this interface, especially 16bit and 32bit microcontrollers for the automotive range which "bigger" PIC do you mean? Or do you mean another microcontroller family? Yes, of course, it's only a question of implementation effort. yes it will require a small modification in app_defines.inc, some variables which are located to 0x060-0x07f, and which are accessed directly, need to be located to another location (or the code need to be changed). However, a modified MBSID V1.7303 version is available on request. It's 100% compatible, and already gets use of the CAN interface - I won't release this version officially, as the communication protocol is not the best (accordingly this is not a good programming example), it's just a quick&dirty hack that I've used to evaluate the feasibility. In MBSID V2 I will take care that the memory structures are optimized for fast CAN transfers from the beginning Best Regards, Thorsten.
  22. The intention of this thread is to inform you early enough about a new decision I made for the MBSID V2 hardware. As mentioned in the wishlist thread (http://www.midibox.org/forum/index.php?topic=6564.0), I've evaluated the usage of a CAN interface for MIDIbox SID V2. More informations about this interface can be found here: http://en.wikipedia.org/wiki/Controller_Area_Network The big advantage for MIDIbox SID is, that the master can not only send data to the slaves, but also receive data from any slave. Accordingly, it will be possible to share resources over multiple microcontrollers w/o the need for mirroring the data. This ensures data consistency, and frees some memory for nice features, e.g. double buffering of parameters for non-destructive modulations, an UNDO function for patches, large bassline and drum sequences, etc... Another advantage is the speed of course, it's 1 MBit/s, and the ECAN peripheral handles most of the transactions (e.g. message filtering, checksum calculation, data buffering via FIFO), which leads to a very good performance and stability compared to other network solutions like MIDI or IIC. With the PIC18F4685, Microchip provides a Microcontroller which is pin compatible to PIC18F452, almost SW compatible (with only one exception: RAM between 0x60-0x7f is not directly accessible), which contains 96k flash (3 times more than the PIC18F452), 3328 bytes RAM (ca. 2 times more), and a 1k EEPROM (4 times more). It seems that the EUSART bug has been solved on this new derivative (an advantage compared to PIC18F4620), accordingly no MBHP_IIC_MIDI interface will be required as a workaround anymore. So much about the reasons for the decision. For all users who already purchased a PIC18F4620: at the beginning of the project it can propably be used for a master-only MIDIbox, but once the application is bigger than 64k, you will have to switch to PIC18F4685. A possibility is maybe to sell the chip to users who are building a MIDIbox SEQ V3, because this application still needs a PIC18F4620 due to the RAM requirements To give you an impression about the hardware changes, here a schematic for the MIDI/CAN wiring: (PDF: http://www.ucapps.de/midibox_sid/mbsid_v2_communication.pdf) All CAN Rx lines are connected together to a single wire, which is pulled to 5V via a 1k resistor. The CAN Tx lines are connected via 1N4148 diodes to the wire, which forms a "wired-AND" The Master Core has a MIDI In/Out pair, the MIDI In is directly forwarded to the slaves for an optional "direct control", and for MIOS code upload (in MBSID V1, the MIDI Ins of the slaves were connected to the MIDI Out of the master, this is not required anymore, as the master can send data to the slaves via the CAN interface) Since two data pins of the LCD are allocated by the CAN peripheral, the LCD has to be used in 4bit mode. This is no performance loss, as the LCD benchmark turned out. The 18F4685 variant of MIOS always accesses the LCD in this mode During this weekend I adapted the bootloader and MIOS for PIC18F4685 and PIC18F4682 (a similar derivative, but with smaller flash memory), and I changed the MBSID V1 firmware, so that the master sends patches and parameter changes to the slaves via CAN. The results are already very very promissing, in fact there is no difference anymore, if a sound is played from the master or from a slave, it "feels" like a big microcontroller is running which controls all SID chips directly (quad-core). :) Since resources are shared, it would even be possible to attach more microcontrollers and to control them from the master. Not only MIDIbox SID's, but also MIDIbox FM's... thanks to the 96k flash, there should be enough room for CS variations. This as an outlook for next year (2008) or later ;-) Best Regards, Thorsten.
  23. Here a quite impressive snapshot from my scope: Master receives a MIDI Note and forwards it to a slave via CAN Bottom (Channel #2): 3 MIDI bytes Top (Channel #1): the CAN frame with 10 bit ID (used to address the MIOS core and to notify the MIDI package type), the control field, the data field with 3 bytes, the CRC checksum and the acknowledge Sorry for the bad resolution, but CAN is soooo fast (and transfers are still extremely stable :)) Best Regards, Thorsten.
  24. Yes, this is possible. BankSticks can be changed on-the-fly during runtime (hot plugin) Best Regards, Thorsten.
  25. currently yes. It could be, that I will provide an option for using 64k BankSticks for Songs (32 instead of 16 songs), it would be an easy change yes, but the maximum number of IIC EEPROM devices is 8. They could be located at different PCBs, but each device needs a unique address on the IIC bus Just order 8 x 24LC512 (Mixer: only 32k are allocated, but you can use a 64k device which doesn't hurt) Best Regards, Thorsten.
