60 -
About moroe
- Birthday January 1
Contact Methods
Website URL
http://www.Andremoroe.com
Gender
Not Telling
moroe's Achievements
Hello How do you save your SeqV4 songs within your daw project ? Is it possible to request the song data via sysex request over the usb cable ? Would be nice to create a vsti which has a song request and send button to have daw and SeqV4 data all in one. Greets Moroe
How do the 32 predefined chords get in the SeqV4 ? Are they coded in the OS ? Maybe i could write my own chords in the OS ? A option to record own chords and save them would be fine for the future. Or a txt file where i can load the chords in some format into SEQV4. Just a few thoughts Moroe
Cool. When has this changed ? I thought that in older Versions the possible amount of notes were only 4 per chord. Can i add my own chords to the predefined list with a bit of hacking ?
Hello I do a lot of jazzy Deep House and Detroit Techno and would need 6 or sometimes 7 notes per chord. Would this be possible in the future with a better chip or more ram ? Greets Moroe
Hello Elektron´s Octatrack has a compactflash card to store the samples. Because big CF Card are expensive and do not have 200gb+ of storage i would like to replace the Compactflash Card with a IDE Harddisk. It seems that Compactflash Cards use the IDE standard. Would it possible to use a IDE to CF adapter (but the other way round) to connect a HDD to the Octatrack ? Maybe with such a adapter: http://www.pcengines.ch/cflash.htm I would need to create some sort of gender changer to connect the adapter to the CF slot of the Octatrack. Greets Moroe
Hello Is it possible to do a usb to midi converter ? There appearing more and more synths which have usb and dont have a midi out port (only midi in) The problem is that i wanna send sysex dumps to other midi gear from these synths (waldorf blofeld,...) WITHOUT a computer. I also would like to get a small Akai LPK25 Keyboard (also with usb only) and connect it as a second keyboard to my hardware. Greets Moroe
Hello Is it possible to get a silver aluminium case with this bulkorder ? Like the prototype from TK. Greets Moroe
Hello Thorsten :hug: This is really amazing !!!! I have dreamed about this for years !! :drool: How will the 16x16blm and the SeqV4 work together ? Is it possible to use the knobs of the SeqV4 to adjust velocity , note length,....... of the 16x16blm ? Greets Moroe
Hello Are there some news about the implementation of the synth preset recording and sending feature ? Here some ideas and wishes: I would like to use single preset dumps and multi dumps. Each synth should have a dedicated preset dump folder with a single and a multi folder in it. If possible also Subdirectories for Soundcategories would be usful (pad,lead,bass...) Possibility to assign a preset dump folder to a track and its corresponding midi in and output. I also would like to send preset dump request messages to the synths, because some synths doesnt have a option to send dumps from the hardware manually (like the yamaha tx81z!!!!!). The dump request message could be placed in a txt file which lies in the single and multi folder. When pushing a button on the seqv4, the seqv4 should send a dump request to the synth. After the dump request was sent, the seqv4 should record incoming dumps. Then switch to the next synth and do it again. I would like to choose a preset in a folder and then use forward backward buttons to send them to the synth without to push an extra button (like the forward and backward buttons on a synth) If possible, during the sequencer is running. Possibility to save all used synth presets with the whole project/song. I know this will not be easy but it would be a complete set of features to work without computer. Greets Moroe
Hello Are there some news about the implementation of the synth preset recording and sending feature ? Here some ideas and wishes: I would like to use single preset dumps and multi dumps. Each synth should have a dedicated preset dump folder with a single and a multi folder in it. Possibility to assign a preset dump folder to a track and its corresponding midi in and output. I also would like to send preset dump request messages to the synths, because some synths doesnt have a option to send dumps from the hardware manually (like the yamaha tx81z!!!!!). The dump request message could be placed in a txt file which lies in the single and multi folder. When pushing a button on the seqv4, the seqv4 should send a dump request to the synth. After the dump request was sent, the seqv4 should record incoming dumps. Then switch to the next synth and do it again. I would like to choose a preset in a folder and then use forward backward buttons to send them to the synth without to push an extra button (like the forward and backward buttons on a synth) If possible, during the sequencer is running. Possibility to save all used synth presets with the whole project/song. I know this will not be easy but it would be a complete set of features to work without computer. Greets Moroe
Hi Thorsten Thx for reply Do you have already tried to implement the synthesizer preset send and receive option ? Greets Moroe
hello how will songmode organize the patterns ? is there a graphical display to see at which time which pattern is located ? something like this: songposition 01 02 03 04 : 05 06 07 08 : 09 10 11 12 : 13 14 15 16 pattern 01 01 01 01 : 23 23 23 23 : 15 15 15 15 : 24 24 24 24 and please please some news about progress of the seq v4 :) greets moroe
wow this was fast great job greets moroe
yeah it must be enhanced with seqv4 features it should only show how a 16x16 button/led matrix for the seqv4 should work greets moroe
here is a tenorion like flash based sequencer which shows what i wanna have: http://lab.andre-michelle.com/tonematrix damn would that be awesome :o greets moroe
