jerash
    95
About jerash
  • Birthday 01/01/1
Contact Methods
  • Website URL
    http://www.mawzer.com
  • Gender
    Male
  • Location
    South France (Landes)
jerash's Achievements
MIDIbox Newbie
  1. hello, yesterday i successfully tested the "filter box" with the pedalboard and sampler, all is working good ! Even with the filterbox sending the PC twice, wich not a real problem in action. So id decided to go on step further, and add a 7 segment LED display to have a visual feedback of selected patch. So before i ask you questions, i will look around code examples and try to create it myslef. thanks for your contribution QBAS, and to TK for this great project ! RAF
  2. oh yes ! wonderfull we can launch 2 Mios studio at the same time ! :-X messages PASSED are stil received twice, same result with 2 mios studio and midiox. ... rgoto PC_BLOK ;pc0e rgoto PC_BLOK ;pc0f rgoto PC_PASS ;pc10 rgoto PC_PASS ;pc11 rgoto PC_PASS ;pc12 rgoto PC_BLOK ;pc13 rgoto PC_PASS ;pc14 rgoto PC_PASS ;pc15 rgoto PC_PASS ;pc16 rgoto PC_PASS ;pc17 rgoto PC_BLOK ;pc18 rgoto PC_PASS ;pc19 rgoto PC_BLOK rgoto PC_BLOK ... PC_PASS ;procedure for PC_xx : PASS call MIOS_MIDI_BeginStream movf MIOS_PARAMETER1, W ;passe le parametre 1 call MIOS_MIDI_TxBufferPut movf MIOS_PARAMETER2, W ;passe le parametre 2 call MIOS_MIDI_TxBufferPut movf MIOS_PARAMETER3, W ;passe le parametre 3 call MIOS_MIDI_TxBufferPut call MIOS_MIDI_EndStream return looks all good, isn't it ? (idiot idea:) i send with parameter 1 then two then 3, or maybe i should reverse the order ?
  3. Hi this trick is to be obsolete with the "CPFSLT MIOS_PARAMETER2" procedure. This looks like what i need, in 3 lines of code instead of ....too much ! Tested successfuly ! nothing special, bad word using from me. no, I monitor only the input of pc (output of midibox) I'm doing more tests next tuesday with the pedalboard and sampler, here at home i only have the pc running midiox and Mios Studio. Test messages are generated by midiox keyboard, sent to the filterbox (its little name ;) ), and back to midiox input. I took a special attention not to create a loop by unchecking the box saying "automaticallly attach inpuuts to outputs during selection" in midiox. Raf attached are 3 shots from the filterbox itself
  4. Hi, I like your style of writing code ! it makes all things logical to me. Now the code is like a rolling stone, thanks to you i've been able to have the filter running ;D Messages are filtered the good way (note on transformation), or blocked correctly. But "passing" messages does twice ??? 1/ the procedure "PC_PASS" takes all three byte from 1 to 3 and calls MIOS_MIDI_TxBufferPut each time. Any idea why the message comes twice in the midiox input monitor ? 2/ You create a table called by : "JUMPTABLE_2BYTES 32" can i make this table 128 x 2BYTES long instead of 32 ? this is because program changes greater than 1F are converted into notes like procedure PC_0. I don't see where is the default point of jump/goto... I would like (ALL PC > 1f) branch to PC_BLOK I can't enough say you how much i'm happy this thing is already running tonight. Merci !!! RaF main.asm
  5. Hi, I'm starting a new project with midibox. The goal is to filter incoming midi messages. some mesages i want to convert, some other to block. I have a Boss midi pedal controller sending only "program change" messages. I want to play a sample when pressing a pedal, but my sampler need "note on/off" messages. So the midibox is placed between pedalboard and sampler and needs to convert/filter the messages following a precise table. The Core V3 pcb is now built, PIC18f452 burnt with bootloader v1.2, then succesfully updated with MIOS v1.9. I also uploaded the "change_id_v1_9c.zip" troubleshooting app to confirm MIOS is up and running, and application upload also. In midiox, i receive a correct CC message "0427" saying All is good ! Now i'm writing code in MPLAB, compilation goes well, but my code is ineficient due to my lack of knowledge in programming. I'd prefer to use assembler because my pc is ready to go with it. I haven't installed the necessary softwares to program in C. So i'm asking for your help here with those questions : 1. Where do i need to put my code for filtering ? (in main.asm in "Notify_Received event" section ?) 2. do i need to do "addlw 0x07" before reading or writing any byte ? 3. is it necessary to use "MIOS_begin_stream" ? 4. How to send a complete midi event ? 5. Here is the table of conversion i want to apply IN : incoming messages to midibox (from pedalboard) in hexa OUT : message to be transmited (or not) when corresponding message is received IN hex OUT hex ACTION ----------------------------------- PC00 NoteOn24 CONVERT PC01 NoteOn25 CONVERT PC02 NoteOn26 CONVERT PC03 NoteOn27 CONVERT PC04 X ALL NOTE OFF PC05 NoteOn29 CONVERT PC06 NoteOn2A CONVERT PC07 NoteOn2B CONVERT PC08 NoteOn2C CONVERT PC09 X ALL NOTE OFF PC0A X BLOCK PC0B X BLOCK PC0C X BLOCK PC0D XX BLOCK PC0E X BLOCK PC0F X BLOCK PC10 PC11 PASS PC11 PC12 PASS PC12 PC13 PASS PC13 X BLOCK PC14 PC15 PASS PC15 PC16 PASS PC16 PC17 PASS PC17 PC18 PASS PC18 X BLOCK PC19 PC1A PASS PC1A X BLOCK PC1B X BLOCK PC1C X BLOCK ... X BLOCK ... X BLOCK ... ... ... I'm looking forward to your help, so it could help me make a first step into MIOS programming for next applications. thank you, RAPHAEL.
  6. hello, I've just experienced the exact same problem. Read this long post, and acknowledged each step. then used another computer (still with internal AC97 soundcard) and the programming process went OK ! So i have to say the conclusion of this thread was interesting to me. Starting a new board, thanks again for this great diy project ! RAF
  7. jerash
    MPLAB project
    On y vient ! Il me manque juste de quoi faire correctement une soustraction (ou un opération donna tle même résultat) Le but étant de tranformer un message Program Change en message Note On Voilà comment j'ai modifié le fichier proc.inc dans la partie concernée : PROC_ReceivedCn ;; branch when PC number is 0x01 movf MIDI_LASTEVENT2, W xorlw 0x01 bz PROC_ReceivedCn01 PROC_ReceivedCn01  ;génération du message note on et midi channel identique movf MIDI_LASTEVENT0, W ;récupère le message PC ????????????? ;Soustraire 0x30 pour transformer PC en Noteon call MIDI_SendByte ;en gardant le canal midi  ;génération du note number movf MIDI_LASTEVENT2, W ;récupère le program number addlw 0x23 ;Ajouter 0x23 au program number (voir table) call MIDI_SendByte  ;génération de la vélocité movlw 0xFF ;vélocité max 0XFF par défaut call MIDI_SendByte  ;transformation terminée return Le seul point noire c'est la ligne avec les ????????? : Soustraire 0x30 du registre W pour transformer PC en Noteon Cn <> 1100 nnnn (message program change sur canal midi 'n') 9n <> 1001 nnnn (message note on sur canal midi 'n') Cette "soustraction" est surement possible par le truchement de quelques AND, XOR, OR .... pour éviter l'utilisation de SUBWF ou autre (...après qq minutes de bataillage...) Il semblerait que ca fonctionne en utilisant : XORLW 0x50 ca inverse les 2 bits qui font la différence entre le Cn et le 9n sans changer les nnnn .... ca a l'air bon on va dire que c'est bon, je suis content de vous avoir tenu au courant de mes tribulations Reste à voir s'il ne sera pas nécessaire d'envoyer un message note off ensuite, ce qui est une autre histoire ! RAF
  8. jerash
    MPLAB project
    Quelle nuit ! finalement j'installe la version 6.10 et : Deleting intermediary files... done. Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mpasmwin.exe" /q /p16F877 "main.asm" /l"main.lst" /e"main.err" Loaded Z:\_Projects\Project DIY\Midi Filter box\filter_v1.4\filter_v1.4\main.COD BUILD SUCCEEDED Extraordinaire ! reste à modifier les quelques lignes... je reviendrai surement vous demander un coup de main vive le diy ! RAF
  9. jerash
    MPLAB project
    salut, je me lance dans la fabrication d'un midifilter (projet qui semble tomber dans les oublittes de midibox...) pour interfacer un pédalier midi sur un sampler, et en suivant la procédure décrite par thorsten, je tombe sur un os : "open the .pjt file" > mon mplab v7.10 ne peut pas ouvrir ce type de fichier environnement ... il ne peut que ouvrir un .mcp Avez-vous une idée du pourquoi ? et du comment y remédier ? en installant une version antérieure ? J'ai essayé en ouvrant tout les .asm et .inc et lancer la compil à la main, et le Build fail avec ce message : Clean: Deleting intermediary and output files. Clean: Done. Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F877 "main.asm" /l"main.lst" /e"main.err" /o"main.o" Skipping link step. The project contains no linker script. BUILD FAILED: Thu Sep 15 04:37:07 2005 Etant donné que je ne suis pas très familier avec la programmation (juste assez pour modifier les quelques lignes nécessaires à mon projet), je ne sais pas comment utiliser le "linker script" Quelqu'un peut-il m'aiguiller vers la sortie ? merci, Raf.
  10. hi there, i found a (french) company building plastic boxes wich could be used for midibox projects : http://www.ltp.fr/Preconcus/Gamme/gamme.html look at EB400 and EB500 more They can drill, cut, draw, and engrave on the plastic. Best Jerash
  11. hello, this is an interesting question ;) Here's my opinion : - as the main cpu board doesn't work, take it away from the case. I hope that buttons are not soldered on the main pcb ??? (and unsolder some ic !!) - you may try to keep the analog and digital input circuits your some other projects, or spare for your working vm2000 - Tune the vm2000 case into a GREAT-LOOKING MIDIBOX ;D with internal power supply - put your SID rack over the mixer, and make some music :) :) RAF
  12. La Surface-One utilisait la technologie TACTEX http://www.tactex.com Il peuvent creer nimporte quelle forme. (effectivement, la surface one ne sortira jamais... c dommage) jerash, en balade a Barcelona:
  13. jerash
    Floorboard
    salut les frenchsous, après la MB64, je me lance dans la fabrication d'un floorboard pour un pote. Le design de Thorsten est à base de PIC16F874 Ma question : eske le firmware est compatible avec un PIC16F877 ? merci, RAF ---- EDIT 08/10---- Sérieux, personne ne sait ??????
  14. jerash
    PB faders
    ZZZZZzzzzzzzZZZZZZZzzzzzZZZZZZZZZZZZ ;D
  15. jerash
    Doepfer
    Sérieusement ???? vous ne saviez pas ? :o cependant, la photo avec les potars branchés, c'est tout récent ! et puis entre nous, on est bien loin des possibilités et de la flexibilité de la MB (sutout avec MOS ;D) allez ressaissisez-vous ! ;) RAF
