hallucinogen
63 -
About hallucinogen
- Birthday 01/01/1
Gender
Not Telling
Location
hamburg
hallucinogen's Achievements
MIDIbox of the Week (MIDI-->sofa<-- by Seppoman)
hallucinogen replied to TK.'s topic in MIDIbox of the Week
mad idea ! 8) -
all the not working areas are just empty, currently i just got no time and motivation to fill them . the sun is shining in hamburg and mostly im out with friends... also there is still a little problem on the midi interface to fix - because of this i dont want to release it . the sequencer pcs will be released as soon as i find my acrobat cd .... and the psu board is just in process. the pcb section was planned to sell some pcbs for the 808 clone and maby others, but currently i have no time to make pcbs here at home. and until now there were not so many interests for ordering from a pcb service ... i dont know about the future of this section for the partlist - all lists i have are on the site . if someone made a list, they are welcome ! and finally the music and samples sections : due to the lack of webspace - the site is hosted by funpic.de (max filesize = 1mb) the sections are empty too. i have no money to pay for webspace or better im not willing to pay for it. :P but maby this problem is gone soon. if someone has already build some of the stuff please let me know if it works and if you had any problems ! its summertime ! go outside, enjoy sunshine and beer (or others ;) ) !! no need to drink but ... ;D hallucinogen
oh, yes - i forgot to finish the download section ::) i just added a price calculation : for the minimal hardware inc. psu and if u make your own pcbs : ca. 130 € + midi interface, case, cables etc. hallucinogen
@julian which links do you mean ? here all links are working ? @arumblack yes it is possible to trigger direct from a doutx - with a little change in the main.asm the pins are only for ~1ms up and that is working well (TK trick) USER_SR_Service_Finish clrf  MIOS_PARAMETER1    movlw  0x00   call  MIOS_DOUT_SRSet        movlw  0x01   call  MIOS_DOUT_SRSet   return hallucinogen
thank u guys ;D yes its a one man action ... everything should be on my site - and the price calculation is in progress ! (sorry cant give a rough calc - simply lost the overview) and maby i will make some sets of PCBs and sell them ?! greets hallucinogen
hi, i finished my 808 clone project ;D (you have to copy n paste the links) http://xlargex.xl.funpic.de/img/808top.jpg http://xlargex.xl.funpic.de/img/808innen.jpg http://xlargex.xl.funpic.de/img/808seq.jpg you can get more info, samples, pcb laouts etc on my page : http://xlargex.funpic.de greets hallucinogen
hi, im currently on building a Tr-808 from the original schematics with many mods ... and a midibox SEQ ... im using a aout with midibox CV for accents and a dout with midio (and a trick from TK that the outs are giving a ~1ms pulse) for triggering the instruments and it works very good ! ;D but i wasn´t able to do things like CV control or digipots .... when everything is working i will share the pcbs and stuff... if u cant wait drop me a PM ... hallucinogen
hi, have a look at http://www.ucapps.de/mios_v1_7_hardware_mods.html mabe u forgot to change the wiring to the SID module ? ( i had the same problems some time ago ... ) hallucinogen
@ titan: sehr gut :D ich muss nur noch ein paar teile wechseln da mein eagle einwenig kaputt ist und ich mir eigen libraries gemacht hab ... ich schick dir das file dann per e-mail ! wenn du lust hast kannst du es ja velleicht auch noch ein bisschen kleiner machen . danke hallucinogen
->Hast Du die Transistoren auch selektiert? Falls ja, wie kann ich messen ob sie zusammenpassende Werte haben? nee hab nicht selektiert - ich weiß ehrlich gesagt auch nicht so ganz wie mann das macht ;D das läuft aber auch so echt gut ! hab jetzt schon 2 am laufen ... ->Schlägst Du vor auch +/-12V zu verwenden oder würde deine modifizierte Schaltung ebenso gut mit +/-15V laufen? mit dem netzteil würd ich eigendlich +/- 15V nehmen wenn du eins hast (oder baust). ich hab nur +/-12V genommen da ich noch ein commodore netzteil da hatte mit +12/-12/+5V , und bissher nicht dazu gekommen bin ein neues zu bauen. zum bestelln schreib ich dir noch ne PM ! gruss hallucinogen
moin moin , erstmal wieder lob an TK !!!, dafür das das aout im sid schon so super läuft ;D die ausgabe der env. und lfos sind ja echt astrein !! und so schnelle env. kurven ... :D ich bin gerade dabei ein eagle board für den moog filter zu machen - is aber recht groß und imo noch im raster 2,54mm (für rasterplatine ;) ) -velleicht hat ja jemand lust das nochmal zu checken ?? ( und velleicht zu optimieren - bin noch ein eagle neuling ;) zum aufbau: im original hat der vcf eine temperatur-regelung und transistor-arrays mit gleichen (selektierten) npn-transistoren - auf die temp-reglung hab ich verzichtet und das ganze mit BC550C transistoren gebaut - und es funkt prima ! dann läuft das original mit +/- 15 V und meiner mit +/- 12V - scheint aber recht egal zu sein, ist wohl nur ein bisschen leiser. und dann wäre da noch der "TK" overdrive : ich denk mal du (thorsten) hast den wiederstand (R42-39k) nach dem eingangs-poti verkleinert ?! bei mir gehts so auf jedenfall: hab ihn durch ein 47k poti ersetzt, damit kann man die lautstärtke mit der der filter gefüttert wird bis zur totalen verzerrung aufreißen ! ansonsten ist alles wie im schema von Rick Jansen dann kam mir der gedanke, die resonanz auch per CV steuerbar zu machen ::) und zwar werd ich versuchen einen zweiten difference-amp mit nem ca3080 OTA zu realisieren... wäre echt sehr cool wenn man die filter settings gleich im sid mitspeichern könnte ;D - und für reso gibst ja auch ne CV ... also bei interesse einfach bei mir melden ! gruss hallucinogen
don´t know ... but i can send you the datasheet hallucinogen
das werd ich doch gleich mal probieren ! danke, wie immer best service ;D die doku ist auch schon in arbeit ... hallucinogen
ich meinte das wenn er: midi note c2 mit vel 40 empfängt (vom keyboard oder seq), pin 1 anstellt wird - bei vel 60 pin 2 / vel 100 pin 3 / vel 127 pin 4 / note c#2 vel 20 pin 5 usw. . .. also keine "schwankenden sachen", nur eine spalte mehr zum konfigurien der midi in events mit vel auf die dout pins in der "midio-presets.inc" ich hab mir nähmlich einen "mini-stufen-DAC" aus nem dout gebaut, um meine drums mit "accent" zu triggern - verschiedene wiederstände und ein paar dioden ;D nur ist jetzt das set auf 4 mal soviel tasten gelegt und unpraktisch in der handhabung ... - deshalb wäre vel (midi) in für den midio echt super ;D aber nur wenns nicht zu kompliziert wird ... ::) hallucinogen
moin wie schwer wäre es den midio "umzucoden", so das er auch auf vel reagiert ? ich würde gerne zb. auf note c2 vel 100->pin 1, note c2  vel 80->pin2, vel 60->pin3 ... haben. odere besser noch einen bereich von zb. 60-79 ... danke schoma !! hallucinogen
