zeh
53 -
Everything posted by zeh
of course, this helps. its time to start coding mios stuff i think. i have managed to never code any line of mios code until now :) but i think the time has come. i will try it. many posts will follow :) but i will build the hardware stuff first. thanks! -zeh
Hi Forum, i was searching for about 2 hours now, i cant find the answer. i want to midify an old audiomixer, which has 128 analog, and 96 digital buttons/pots/faders is it possible to connect 128 analog inputs ? i dont understand that core slave stuff. is it possible to connect 2xAINX to one core, 2xAINX to another core, and then connect the 2 cores? if this will result in 2 different midi outputs, or is it one ? i read about the midibox NG, wich allows connection of 128 analog inputs, but i cant find it anywhere. is it dead ? thanks in advance -zeh
thank you! its a huge metal case, a old mixer, i will midifiy it. it will give it a try. thanks -zeh
Hi Forum, i have a question regarding the AIN module. is it possible to use 47K resistors instead of 10K ones? if yes, whats the difference in handling? i have to use them, because they are really great and i have a lot of them :( thanks for help -zeh
great, thanks for the answers. if we make a community order, how much will the shipping cost ? is it possible to send it in a standard letter? (approx. 1.50 euros). if yes, i will participate. because paying 5.65euros to farnell, just for the shipping of one chip, is paradox. greets -zeh
oh, sorry, you are right, i read that over ;-) so, i just buy 'some' 4620 and use the IIC workarround ? or should i wait, until some fix is out ? thanks zeh
hi there, where can i buy the non-buggy version of the PIC18F4620 in germany? i cant find it in the reichelt shop, also conrad electronic doesn't have it. I also looked on mikes midishop, but it is also not listed there. which one is the one without the bug? because if i order one, i think its not very 'new' because its lying in there storage for some time... which one do i have to buy and where can i get it ? thanks guys.. -zeh
of course, that was mios again :) some kind of typo, i tryed also the app :) thanks ;)
its working now... i reburned the pic and reinstalled MIOS. i dont know what was wrong. thanks for your help! -zeh
hi, thanks for the fast reply. i have a midibox seq v2 with a PIC18F452. i uploaded the bootloader 1.2 with my JDM burner via IC-PROG. after that, i uploaded mios 1.9c via midi with MIOS Studio. now: the box boots. i see a splash screen MIOS 1.9c, then ONE sysex request is sent. after that, the display says "READY." if i try to upload the 2.4c version of the mbseq application, nothing happens. like this: mios_v1_9c_pic18f452.hex Hex file contains code in MIOS range, forcing reboot! (reboot is not working, i have to reboot by hand...) Received Upload Request Sending block 00000400-000004FF ... now, nothing happens... ;( any suggestions ? thanks -zeh
Hi there, iam having problems with the installation of the application: midibox_seq_v2_4c i updated the bootloader and mios (to 1.9c) on my PIC18F452 SEQ version 2. after the booting process, the display of the SEQv2 says 'READY'. If i try to install the application, nothing happens. if i reboot the midibox, the sysex request is received, after that the upload begins. but it does nothing. can somebody help me ? thanks in advance -zeh
yeah guys, i love ya all. very nice. i received my second sample package today (a friend of mine ordered it). i got a rotary, a flex, and a linear sensor. time to experiment. thanks to all ya.
great :-) i will email you soon.
hi leute, ich kann zu creekree`s post nur sagen, das ich andere erfahrungen mit rakel und beschichtungsrinne gemacht habe. als ich noch keine beschichtungsrinne hatte, habe ichs mit einem alten plastik deckel von einem drucker gemacht. sollte halt eine moeglichst gerade kante haben, um einen realtiv gleich kraeftigen schichtauftrag zu garantieren. (schicht bekommt man in jedem siebdruck-fachhandel (gelbe seiten)). das mit dem rakel aus dem baumarkt, kann und will ich auch nicht gut heissen. ich habe mich damals informiert, und hatte auch solche rakel in der hand. der nachteil, ist der viel zu duenne, viel zu lange und viel zu weiche gummi. ein siebdruckrakel hat einen wesentlich haerteren gummi, kommt jedoch auf den zweck an. so laesst sich ein t-shirt rakelgummi (eher weich) relativ einfach, aber nicht ohne kraftaufwand mit dem finger biegen, beim haerteren (der dann benutzt wird wenn weniger farbe durchs sieb soll) tut man sich eher schwer. wenig farbe soll immer dann durch das sieb, wenn der bedruckstoff NICHT saugend ist. zb. aluminium, pvc, glas, whatever. benutzt man also nen rakel zum verfugen von fliessen aus dem baumarkt, kann man sich sicher sein, das man aufgrund der unnoetigen haerte des gummis garkeine farbe durchs sieb drucken kann, wenn dann eher schmieren. ich habe auch versucht, den gummi durch kuerzen etwas weniger elastisch zu machen, jedoch ist auch dieses ergebnis unzureichender qualitaet... zum tonpapier kann ich nur sagen, gute idee. hab ich auch schon gemacht, ich leg allerdings immer ne schwere schwarze holzplatte drauf, selber effekt. am besten man bastelt sich nen vakuumtisch mit ner gummimatte, ein wenig holz, ner glasplatte und nem alten staubsauger. aber ist nicht notwendig. sollte halt 'so gut wie moeglich' anliegen. da die meisten leute hier frontplatten bedrucken wollen, empfehle ich dringend einen genauen schichtauftrag, ein geignetes rakel, die bestmoeglich lichtdichte vorlage und eine genau anliegende vorlage beim belichtungsvorgang. selbstmach-siebe habe ich jetzt schon des oefteren mit erfolg angewendet, wobei sie aufgrund der grobmaschigen struktuer eher ungeeignet fuer nicht saugende materialien sind. also am besten ein sieb kaufen (ca 30euro gebraucht). laesst sich immer wieder entschichten. wenn wir schon dabei sind: beschichtungsrinne (ca. 20 euro, je nach laenge), rakel (ca 30euro pro meter), schicht (ca. 15euro pro liter), farbe fuer metall (ca. 20 euro der liter) so long -zeh
great !! cant wait to beta-test :-) thanks thorsten
wow, that would be great. my asm skills are too bad to think about doing something like this myself for now. hope you get it and publish the code. thanks in advance man. great stuff. -zeh
i also take one...
i really need this autosave pattern feature. like all the grooveboxes in softsynth programs. you alwas just have to select the pattern to edit, edit it, and then switch to the next one and edit it. there is no 'save pattern' button, its autosaved. so, since MIOS is able to write the bankstick, isnt it possible, to write the data to the bankstick, everytime a knob is turned. on every interupt? is this too bad for the perfomance? how long does a write take? or maybe, letz autosave every 5 seconds or so. i dont want to save everytime i changed the pattern. i think, there are people outside, which think this would be a good change in the software for the SEQ. i also think, its not too much work. my assembler skills are in the beginnings, so maybe someone who thinks this is cool, wants to help me implementing it, or, changing it in the software? thanks -zeh
i think MB64 is your choice... -zeh
jo, das ist natuerlich auch ne nette sache. bin grad mit dem seq v2 fertig, naja, analog out und ltc fehlen noch... ausserdem fehlt das frontpanel. ich werds wohl bei schaeffer machen lassen, da werd ich dann nur fuer die bohrungen und fraesungen 50 euro lassen, beschriftung mach ich aber selbst. hab 2 blau/weisse displays und nen a***h voll orangene abgeflachte leuchtidioten :-) (wird die version mit 16LED's pro Track) (aehnlich der MoxBox, siehe gallery). fuer buttons hab ich meine alte, nicht mehr funktionierende (wasserschaden :-] ) Roland MC-303 zerlegt. wird also (hoffentlich bald) ein nettes geraet. fuer die banksticks werd ich USB connectors verwenden und gut lesbar "NO USB!" draufschreiben. usb aehnliche sticks halt dann zum speichern. das ding wird aus alu von schaeffer gefraest, dann von mir orange lackiert und zu guter letzt noch mit 2 layern sieb-bedruckt. (weiss/blau). ich habe zum thema siebdruck vor langer zeit mal eine art howto geschrieben, ist leider nicht ganz vollstaendig und uebersaeht mit schreibfehlern. die grundsaetze werden jedenfalls erklaert, so ungefaehr... ;-) siehe -> http://www.toastworld.org/index.php?page=siebdruck hoff das hilft jemandem. bin aber auch per mail oder im forum fuer fragen erreichbar. zeh@toastworld.org bis denne -chris
hi thorsten, ich habe ein 'moog synthesizers' t-shirt, auf das ich sehr stolz bin, und mich auch sehr 'cool' fuehle wenn ich es trage %-] auf jeden fall wuerd ich mich noch kuhler fuehlen wenn ich mit nem 'ucapps' t-shirt rumlaufen wuerde. da ich hobbymaessig siebdruck betreibe und immer mal wieder ein nettes shirt drucke, wollte ich mir demnaechst mal ein ucapps shirt machen, wenn das fuer dich ok ist sozusagen. shirts auf ucapps zum verkauf anzubieten faende ich doof, aber eventuell koennte man ein howto zum siebdruck schreiben, und diverse vorlagen zum download bereitstellen. DIY eben... ich erklaere mich bei positiver resonanz, also, sollte jemand ueberhaupt interesse an einem ucapps shirt haben, gerne bereit ein howto zu schreiben. so long -zeh
ok, the problem is solved, but, it WAS the power supply. strange. if i connect the 'maybe defective' PSU, it only works if my PCs midi IN is connected to the midiOUT of the core. if i connect a new PSU, it works, also if there is nothing connected to the midiOUT of the core. i dont know why this happens, i think it gets power from the PCs powersupply, over the +5V of the midiIN from the PC, dunno if this works. thanks a lot -zeh
hi, very nice. i also figured the same out, the xypad act like 2 pots. isnt it possible, to do that 'save position' stuff via software ? maybe, it always saves the last value, then you touch the pad, the pot gets active, and sends a new resistance to change the value. best regards zeh
