reboot
308 -
Everything posted by reboot
il te faut 4 core,4 sid,3 DINX4,2 DOUTX4,15 encoders,32 buttons,100 leds environ 250 e + 180 e pour la facade bref 500e
salut ukn ça fait + de 2 ans que je scrute le site pour avoir toutes les infos et ça change souvent il faut que tu lises tout ce que tu peux . pour commander tu vas dans "design" de "MIDIbox SID Synthesizer" et tu lis "Complete Control Surface (Step C)" et tu commandes tes cartes chez la http://www.avishowtech.com/mbhp/ si tu ne sais pas vraiment souder entraine toi un peu sur des "cartes a trous" ça coute rien. apres tu cherches ds le forum . le plus dur je pense est la partie que tu montes derriere le panneau... bon courage :)
syntheticsolace you're right . it's better to use a keyboard like the evolution ekey (45e) with midi and usb . for my sid i had to write an interface . i'm planning to buy the evolution for next project because it's simple and NEW a sequencer would be very very cool but more like the xoxbox and with the option to make chords....
ok one kit for me too .... ;)
very nice and well done Marco !
"This studio costed over $60,000" really? i didn't know beringer stuff is so expensive. even the tapes machines haven't the total hours of use it"s really expensive , that's my opinion
the answer : http://www.midibox.org/forum/index.php?topic=6137.0
hello thank you for your comments first thank to Thorsten Klose because without him i would't start to study electronic (2 yrs ago)and make this project and thanks for those who helped me to debug it. the case is one of two .It was made by a friend of mine (an ebenist) it is made of wild cherry tree (merisier in french) tinted. the keyboard is from an old toy. It's same one as yam dx 100 but shorter.If you find one you can cut it (the toy!)but it's probably a bit of work . The "midi interface" is not ready .My friend who's get the second one works on it and it's almost done. The is 3 things i would like to add 1.button for mono or poly mode, 2.Pitch bend, 3.Transpose for the keyboard and wait for V2... questions welcome what else?....i'm happy
hello TK i noticed a bug encoder with deph env the parameter don't come back when it's -64 and only decrement is it a bug or my machine (i put a picture of it but it's not finish yet)? thank you P1010027.JPG
hello Ryan, if you have a scope can you check the psu i had troubles with my sid the 5v wasn't stable so the system had trouble what kind of psu do you have ? hope i can help
ok i found the error vd on j10 (core) wasn't join to 5v on slave i will post soon pictures of my 4 sid with keyboard and home-made case when it'll be close. thank you Jack,audiocommander,OrganGrinder,MTE, and of course TK for your help .
hello i tested the sid voltage and there is vdd-vss------12.26 vcc-vss-------1.16 ????? if somebody 's have an idea?
thanks for the reply the sid works under MIOS V1.8 with the old PSU maybe because the pic was burnt by a friend of mine last year for the prototype we made and i didn't try to re-burn it as i wanted to keep it as a secure pic . the psu was probably un-stable and the midi dump too. so the system was stable even with a bad psu BUT BUT BUT because the pic was done with another machine ....i'm sorry about the confusion. i have no sound from slave even with link button (witch flashes) i search the errors i made.
thanks MTE ! i replace my 5v power supply and there's no button bug everything works on control panel now i have no sound from slave and the is a "humm" sound (normal i think) i pressed the link button but still the same think it's near the end of my problems thank you
it seems to be ok but i will check that each time my sid start my midi interface (midiman2x2) reveive a event is it normal? thanks
hello the PIC reboot sometimes when MIDIO128 is running and i turn encoders sometimes yes sometimes no after switch off i upload MIOS V1.9c from MIOS Studio with feedback i installed MPLAB
hello TK 1----i upload now via "use feedback" (i didn't do that) 2----checksum ok ....same problem with buttons filter and filter mode and when i select S&R osc . The problem seems to operate in random 3----load revision_id_v1_0 4----revision id : 0426 5----i also tried with one from SmashTV's : 0427 what do you mean by "MIDIO128 the buttons don't reset the core" thank you
hello 1---RC2 is not clamped to ground or +5V 2----the 1k pullup at RA4 is connected to the core . it wasn't on slave so i did it 3----now with master and slave it doesn't reboot but the bug button is still here 4----i uploaded midio 128 5---press env ---column l1 light and no sound but i hear the sound of sid 6--- i put again sid 1_7303b/setup_6581.hex 7----same problem but more stable , when i select the filter mode it bugs at LBH page and also when 123 is select ::) 8----now i just try to upload with 900ms and the LBH bug diseapear ...... 9----load again ...like 7 thanks i forgot that pin RC2 is directly connected to the SID clock input
hi i test only the master core with the optocoupler (first one) why do i have to check the connections if an older system works ? so now i search for mios 1.8 and sid application 1.7a i repeat that everything (with one core) works with mios 1.8 not with 1.9 thank you
from http://www.midibox.org/forum/index.php?topic=7423.msg50526#new hello i checked the connection and it seems to be ok the problem is 1----the sid reboot ten times maybe more before it's ok then when i push these buttons "filter mode" "matrix" and "lfo mode" it begins to start 2----if i put only one core with mios 1.8 and 1.7a the system if fully operational(i tested it with a bankstick that i removed now) so what is the difference between the 2 systems because i made my pcb one year ago and maybe if forgot some fixes i have read http://www.ucapps.de/mios_v1_7_hardware_mods.html and everything that already corrected thank you
hello first thank you to help me i describe what i do 1----with a virgin pic i burn with ic prog :mios update v1.9c/pic 18F452/burner/bootloader v1_2pic18F452.hex 2----open mios studio then dump mios v1_9pic 18F452.hex with "don't use feedback"and 750ms 3----can read mios v 1.9c and "ready." i did this process a lot a times 4----again with mios studio i dump this midibox_sid_v1_703b/setup_6581.hex 5----IT WORKS but when i press edit the machine REBOOT ok maybe it's normal at this point 6----take second pic with id value 0000...1 with ic prog 7----mios studio; same file with device id 01 8----sid is "ready." 9----again with mios studio i dump this midibox_sid_v1_703b/setup_6581_without_cs.hex 10----"MIDIboxSID V1.7303b CS not enabled! " 11----i plug the first core and the second one as slave and....my sid reboot again and angain i have to tell that the master has the chips stuffed in sid part and slave don't have i checked twice the connections of j11 i also tried to change the device id by using mios studio something is wrong in my slave area but where ? i did the 2 pcb's with 2 core and sid do i have to unplug everything to do a test ? i'm no sure it'll be usefull thanks again
ok my question is why does my master reboot itself ? when i "burn" the file without cs enabled it works i'm sorry to tell that but the installation is a bit strange....and about the id of the core i can't see the files corresponding to the slaves sorry ,but 3 weeks with the same problem gets me nervous see u
hello thank you for your help but it's still the same i use the folder mios update v1_9C bootloaderv1_2 + mios v1_9 then i dump via midi-ox a file i generated with convert.bat after renamed the file setup6581 by main the upload works with setup with cs but with setup6581 the sid reboot itself again and again thanks
hello i have a problem with last update my sid reboot itself again and again with setup 6581.hex i have no problem with 1.7a with mios 1.8 i can't put my first slave because i loose the 1.7a file and i have just one master i would like to use the lastest one but i don't understand if someone have an idea .......thank you
