        Spoth74
                Posts18
Everything posted by Spoth74
	Salut, Il y a aussi conrad qui en vend: http://www.conrad.fr/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=361281&langId=-2&parent_category_rn=18989 En plus en cherchant sur le net, il y a des fois des codes pour avoir 20% de reduction. Je ne sais pas si ca marche mais ca peut valoir le cout
	Hi, As we can learn for the others stupid errors. Let me explain my last work. The goal is to sold button with built in led on a pcb (rec, solo etc buttons). For the DIN, I'll retry later : first attempt, 1st short circuit. Happily the 7805 is protected !!! So I soldered 16 buttons on the pcb. Ok, first try, every leds are soldered in the wrong way ... Desolder, retry again: good. Then I tested the pushbuttons : Guess what ? I soldered them the wrong way too (4 pins connected 2 by 2). So for next time, I'll begin with ONE button and then test (not at the end). Good midiboxing, Steph keeping believing
	Yes, I will use J10/RC for the second enable line like the pdf example. I just wondered if someone design a pcb or something to extend J15 + 2nd enable pin in to 2*8 sockets to plug the 2 lcd with connectors. Thanks for help. Steph
	Hi, Thanks for reply, I see for the enable pin for the lcd, but to connect the data lines, Vs and all pins that are common to the 2 lcds, what do you use? Steph
	First Project, needs lots of help and support :PSpoth74 replied to ValveState's topic in Design Concepts Hi, Yes you can connect 16 encoders per DIN. You configure that in the second part of the file mios_tables.inc of the lc app. MIOS_ENC_PIN_TABLE ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 13, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 13, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 13, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 13, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4 ENC_ENTRY 14, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 5 ENC_ENTRY 14, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 6 ENC_ENTRY 14, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 7 ENC_ENTRY 14, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 8 ENC_ENTRY 15, 0, MIOS_ENC_MODE_NON_DETENTED ; Jog-Wheel ENC_EOT ENC_EOT ENC_EOT ENC_EOT ENC_EOT ENC_EOT ENC_EOT After ENC_ENTRY, the 1st number is for the Serial register and the second number the even pin of the encoder. So you cannot connect 16 encoders and other buttons like FX in one DIN. Be careful if this is push encoder you need one more pin (like a push button) and if you have touch sensor motorfader, you need one pin by fader (see the lc_io_table.inc file for example) Good midiboxing, Steph
	Hi everyone, Just a question, how do you connect 2 parralel lcds with core module ? Do you solder 2 wires by pin on J15 when necessary or I don't know what is the more convenient. Thanks for replies Good midiboxing, Steph
	First Project, needs lots of help and support :PSpoth74 replied to ValveState's topic in Design Concepts Hi again, I read once that Axel include one MidiSport 4x4 in his midibox. So he connected to the PC via USB and had 4 Midi ports avaiable. You can think of 4 LC in one enclosure. After that I don't know how he configured to have the right channel number on the midibox. Good luck
	First Project, needs lots of help and support :PSpoth74 replied to ValveState's topic in Design Concepts Hi, Be careful, I understood Mackie protocol for cubase doesn't support zoom button. See Cubase_SX_SL_MackieControl.pdf from Mackie page 31. (http://www.mackie.com/products/mcu/documents/Cubase_SX_SL_MackieControl.pdf) I'm not sure cause I didn't try yet. Good work...
	Bonjour, J'ai recu la commande de AlsComposants (www.alscomposants.com). J'ai d'ailleurs recommande depuis. C'est pas hyper rapide (1 a 3 semaines !!!) mais c'est pas cher et bien emballé, pas de probleme. De plus j'ai vu qu'il y a des RSAON sur www.conrad.fr (Ref 442081-62) à 23.90€. Sachant qu'en etant abonne a leur newsletter, je recois souvent des promos du genre une station meteo de m... pour 45€ commande mais aussi 20% sur votre produit prefere ce qui peut devenir interressant avec les faders. Bonne chance...
	Salut, S'il n'est pas un peu tard, je viens de trouver mieux: www.conrad.fr (article 442081-62). De plus, en etant abonné a leur newsletter, je recois souvent des promos du genre 20% sur votre article prefere. Bonne chance...
	Hi everyone, For the (at least) one thousand times, I enter ALPS RSAON in google and for the first time I found them at www.conrad.fr (Article 442081-62). I think it is better for french midiboxer than conrad.de Good night
	Bonjour, J'ai commandé des pièces sur alscomposants.com. Pas encore recu, je ne peux rien dire sur l'emballage, les delais etc etc mais ca semble etre le moins cher (a part reichelt bien sur) e aucun minimum de commande.
	Bonjour, Il n'est a priori pas defini dans la configuration par defaut (lc_io_table.inc) mais il existe sous le nom ID_NAME_VALUE, donc tu peux le rajouter soit en plus (il y a de la place sur le dernier module din) soit a la place d'un autre ou dans la second layer. Tu modifies le fichier lc_io_table.inc en consequence et ca devrait aller
	Hello everybody, I was looking around to find LCD 240x64 with KS0108 controller and I found a site (www.lcdis.fr) whitch sells it. The price the guy offers me is 48€/piece if I order 10 or more. So I ask you if you're interested to perform a bulk order.
	Thanks for quick answer
	Hello everybody, As it looks hard to find 240x64 KS0108 controlled LCD, I wonder if it is possible to use two 128x64 instead. It seems possible to plug the two ones the same way exept for CS3 and CS4 for the 2nd LCD. Doas anybody try this ? Thanks
	Salut, A priori, il y en a chez www.conrad.de (article 442081-07): http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTI2MjEyOTU0OTY= Bonne chance
	Tu peux regarder la : http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTIwOTk2OTY5NDM= article 442081-07 sur conrad.de
