goule
Programmer
    191
Everything posted by goule
  1. They didn't send me the pad but different models of softpot (with different lengths). You're right the flickering is exactly the same as declaring an extra AIN input used and never connect it ! Do you have any solution for that flickering problem ??? :P
  2. Hello Master ;D I have a touch potientiometer (like ribbon controler) from Spectrasymbol which seems to be 200 kOhms. This brings flickering when not touched (it's a pity because it works very well as long as you keep your finger on the ssurface). Are you sure there is no other wy except from raising deadbandset ? (because loss of resolution leads to very poor controlers precision as you already know ;)) : I have to fix deadbndset at approx. 100 for this ribbons "shuts up" when in IDLE. Is there some electronic solution for that kind of problem, cause adaptability of potentiometers seems to be a very poopular question ... ?? Thanks for help people and forgive for bad english ... Olivier ka Goule
  3. Hi all, I've received the samples from SpectraSymbol : very nice piece of hardware ! :D I've connected it to the AIN : it works great to transmit values from 0 to 127 but it flickers a lot around 64 when you don't touch it :'(. I have many oher devices attached to other AIN pins (pitch bend, modulation wheel and two joysticks) and none of them flickers that way. ??? Do you have any idea ? Thanx for help, I'd really appreciate to use this as a ribbon controler for my midibox ... Olivier aka Goule
  4. Hi, I've purchased 2 joysticks on alltronics.com that looks like this : I'm looking for some sexy (or not ...) handle to screw on (excuse my poor english) Do you have any idea where I could find that ? Thanx, Olivier
  5. Oui exact comme on dit j'avais vu (mais pas bien regardé) : avec le pdf sur la même page on identifie bien les ports à tester. Merciii et désolé de cette question de flemmard j'aurais pu trouver tout seul ::) Ouuu comme il me tarde de partir du taff pour tester ça !!! Je sens que je vais pas faire une grosse journée moi ! ;D A+
  6. Yesss ça signifie que ce soir j'aurai fini mon CORE !!! :D Honnêtement je suis agréablement surpris de la qualité des kits fournis par SmashTV, la vitesse à laquelle on peut réaliser son core même sans trop de connaissances en électronique (2-3h à tout péter) et ... la réactivité de l'aide en ligne ;D Il me tarde de recevoir ls LCD pour tester mon core ... :P A ce propos j'ai vu à plusieurs reprises sur le forum qu'il y avait une marche à suivre pour le premier test du core : - ne pas installer les PIC - mettre sous tension - mesurer les tensions à différents endroits C'est justement ma question : où trouver les bons voltages à checker et où faire les mesures ? A+ merci encore
  7. Okay bon courage pour la suite ... N'oublies pas que de toute façons ce qui compte à la fin c'est l'abstraction comlpète du typage des pistes (mono, stéréo, etc.). L'objectif est surtout d'éviter de piloter les pistes stéréo sur 2 faders, c'est relativement contre nature et ça complexifie vachement l'approche au final quand tu es en phase de compo ou de mix. A+
  8. Merci tatapoum, encore une fois tu me viens en aide 8) J'avais vu ce schéma (c'est celui qui est resté non stop sur mon écran hier pendant les soudures ;D) Ok cool ce soir je vais pouvoir finir mon Core, dommage que je n'ai pas encore reçu le LCD pour le tester ... Pour le cristal, c'est pareil, pas de sens précis ? A moins qu'il faille se fier au sens de l'écriture ... Merci encore A+
  9. Salut à tous, Suite de l'aventure, j'ai reçu les composants par SmashTV. Effectivement le PCB est d'une qualité irréprochable. 8) J'ai quasiment tout soudé mais il me reste une question : qu'en est il du sens (polarité ?) des composants à connecter sur C1,C2,C3,C6, D1 et X1 ? je suis une bille en électronique (mais très motivé ;D) mercii
  10. Okay merci Lall ! A+
  11. Salut Julien, Franchement le VST remonte à un peu loin dans mon esprit et je ne sais plus ce que l'on peut faire / pas faire avec à ce sujet. Ce qui est sur c'est que j'emploie la méthode que je t'ai décrite de mon côté avec SX3 et ma mackie control. Bien que la Mackie control soit purement géniale en termes de remote, c'est le seul moyen d'uniformiser l'utilisation des pistes mono/stereo et de pouvoir échanger les positions des pistes, quel que soit les types de celles d'origine (VSTi, Audio, Rewire, etc.). Pour te donner une idée j'ai un modèle Cubase que je me suis fait et dont je me sers pour commencer une song : celui-ci contient 24 pistes groupes pilotées par la Mackie (soit 4x8 et je passe de 8 en 8 avec la mackie - ah, l'automation ;D ...). Bon courage dans tes recherches et au cas où tu te poserais la question : oui franchement SX est un peu à VST ce que XP est à 98 ;D ;D ;D A+
  12. Salut Laal, SEQ c'est le module pour faire séquenceur c'est ça ? Le souci c'est que moi je fais une midibox toute simple, sans séquenceur. Ca marchera quand même ? Merci
  13. Petite question : si je connecte un clavier maitre sur le MIDI IN du core, est-ce que sur la sortie OUT je vais retrouver les évènements de mon clavier mélangés aux controleurs de la midibox (ce que je voudrais faire) ou doit-on absolument rajouter le module LED/Thru/COM pour que cela fonctionne ? Merci !
  14. Perso j'ai une "vraie" Mackie Control ;D et malgré ses capacités énormes en termes de remote, je persiste à utiliser les pistes groupes (ne serait-ce que pour permuter des pistes en cours de compo, avec les faders motorisés qui échangent leurs positions et les noms des pistes aussi sur le LCD, quel BONHEUR 8)) Bonne chance pour tes tests.
  15. Okay merci pour ta réponse .... je vais passer commande des composants et je ferai des tests ... Merci encore ! ;) A+
  16. Super cool ! Merci pour ta réponse c'est exactement ce que je voulais savoir :D A+ Olivier
  17. ??? Comment je fais pour obtenir 36V à partir de mon 9V ? En mettant une résistance ? Je suis vraiment une quiche en électronique (et pourtant je fais des efforts :() A+
  18. Encore une question qui n'est pas très clairement expliquée sur le site ... A priori le module CORE contient des pins permettant la connexion directe de potard/sliders, donc si on en a pas besoin de + de 8, pas besoin d'acheter de AIN. Par contre, est-il possible de souder directement des leds ou des boutons sur le PCB du core, sans avoir à acheter de DIN/DOUT ? Merci pour vos réponses Olivier
  19. Salut les MidiBoxers ;D Je m'apprête à commander le nécessaire pour un module CORE; sur les liens conseillés sur Wiki j'ai l'impression qu'il est impossible de trouver des CORE déjà montés ??? Dites-moi si je me trompe, mais il faut quand même se taper la soudure des composants sur le PCB ? A+ ;)
  20. Merci de ta réponse. Si je suis ton lien, les composants dont tu parles sont bien les 17 et 18 (référence dans la colonne complètement à gauche) ?
  21. Justement, toute la problématique en ce qui te concerne vient du fait que les pistes que tu veux controler sont hétérogènes (un coup mono, un coup stéréo, etc.). Si tu crée par exemple 8 pistes groupe à chaque compo et que tu routes chaque piste de ton morceau vers une des pistes groupes, tu as plusieurs avantages : 1/ Tu n'as plus qu'une seule nature de piste à piloter (groupe) quel que soit ce qui arrive dedans (VSTi, Audio, etc..) 2/ Tu peux changer l'ordre de tes groupes entre eux :D (alors qu'avec Cubase tu ne peux pas avoir des pistes de toutes les natures (VSTi, Audio, etc.) dans n'importe quel ordre. 3/ Tu peux effectivement avoir un avantage a avoir techniquement des groupes (router plusieurs pistes vers 1 piste groupe) Au final tu t'affranchis de pas mal de problèmes ... et puis rien que pouvoir à tout moment changer l'ordre des pistes c'est hyper cool. Ah finalement ma caisse claire est là , je vais la coller à mon pied 8) Bref moi je dirais : que du bonheur ;D A+ Olivier
  22. Hello, Je cherche un encodeur rotatif ("rotary encoder", en anglais dans le texte ;D) qui ressemble de près où de loin à ce qui se fait sur les expandeurs EMU (gros potard sans fin, cranté). Où acheter une telle bestiole, et est-ce possible d'intégrer ça dans un projet "midiox" ? (genre 128 program change ...) Merciiiii Olivier
  23. Je ne me souviens plus de cette version de Cubase étant donné que je suis sur SX3 maintenant ;D ;) Par contre essaye de router la sortie de ta piste vers une piste groupe, peut être celle-ci n'aura t-elle besoin que d'un seul controle pour la panoramique ... yeah !
  24. Super grand merci pour tes tests  :o Par contre aurais-tu inversé les valeurs de R1 et R2 ? (ou alors je comprends plus rien)  Avec tes valeurs appliquées à la formule magique ;D j'arrive à Us = 1.68 x Ue  ??? Donc si pour toi Us = 4v, on a Ue = 2.38v ... bref je suis un peu largué je pense :-\ Merci pour les réponses aux questions ... [Edit : ] Le site que tu viens de poster est une mine d'or ! :o Génial ça va être dur de résister à faire marcher l'imprimante du boulot demain ;D ;D ;D En tout cas sacrée investigation sur la question, chapeau ! J'attends les résultats de tes tests avec impatience ;D Affaire à suivre  ;) Olivier
  25. Alors voilà ce que donnerait un schéma récapitulatif, juste histoire de checker avec vous si je vois les choses correctement : Ce qui m'amène aux questions suivantes : 1/ Dans la doc du module Core, je vois que la plage 7-10 V est autorisée, et j'ai donc supposé qu'un transfo 9V ferait l'affaire (sachant que j'aurai quand même un LCD à alimenter). Est-ce ok ? 2/ J'ai fait revenir ma tension amplifiée vers la gauche du Core; est-ce bien là les ports AIN ? ::) 3/ Dans la section ucapps.de sur le module core, on peut lire à propos du port J2 : Restriction: Le régulateur 7805 chauffe beaucoup lorsqu'il délivre un courant au dessus de 500 mA, donc seul les modules CORE sans écrans rétro-éclairés comme pour les MIDIO128, MIDImerger, MIDIfilter peuvent être alimentés par ce port. Donc logiquement ma question est : peut on utiliser ce port dans le cas de mon montage, sans risquer d'avoir des problèmes avec le LCD ? Sinon est-il possible de mettre un régulateur 9V -> 5V à la sortie de l'alim ? :P Thanx !
