S.M.
    30
Everything posted by S.M.
  1. yes, it's possible to make a switch for turning the patchselector to internal/external program-changes (added this to the to-do-list). It will have a better performance but the Gui will not respond to the changes of the SID then. I also planned to implement a plugin-internal multimode - so you can play different SID's with different parameters by one SIDControl, only. SIDControl is win32 compatible, only and an AU-version is not planned by my side.
  2. I've just fixed the problem :D Register by click on 'register' fill in your name in the first field and your email-adress into the second one. -> then click 'submit' After that check your mailbox and you will find your password in there. Now you can login with your email-adress and password. ...That's all. - it doesn't cost anything more than a second of time and you can login to all current & future-downloads on my Site. ;)
  3. Hi, ich möchte euch hier mal die erste Beta von meinem neuen VST-Plugin vorstellen. ' SIDControl ' stellt dem HW-Sid eine vollständige Benutzeroberfläche in Form eines VST-Plugins zur Verfügung. Man benutzt SidControl wie einen herkömmlichen Softsynth. Der Audiopart wird allerdings vollständig dem SID überlassen.... Ideal für minimal-SID-Synth user. mehr Info + Download auf ' http://vst-factory.saschazone.de ' oder ' http://www.saschazone.de ' ...grüsse aus Hessen.
  4. I have added a 1:1 screenshot of SidControl here: ' http://www.saschazone.de/gfx/sctrl2.jpg ' Some more features and restrictions : Direct MIDI-connection to your Sid by the VST-plugin (not the host) -so you do not have to configure anything MIDI-related in FLStudio. If the host allows internal sound-routing (FL does) you can send the aux or CDIn (where the SID is connected to) to the FX Mixer and through any other VST-plugin - in realtime (nearly) that sounds all good, but there are some little restrictions: When you render your song to wavefile you will hear nothing on the SID's-Channel because during the render-process the SID will not be played live. You can go around this by recording the SID-Channel first, then insert the wavefile to your Project before you start rendering. SIDCONTROL edits nearly all parameters the SID has -except the wavetableseq (but WT-patchchange is possible). Because of the many parameters it can cause something like a MIDI slowdown and many CPU-usage when you automate too many parameters at the same time or triggering patchchange too fast. But for me and my minimal-SID-Synth (which was a PC-CD-Rom before) it's the best choice to make cool HW-SID-sounds in a quick and easy way inside my PC. Maybe my next plugin is a MicroWave-PC-Control to get the same easy handling there, too... ps: (to dcreatorx) - It's made with Synthedit (http://www.synthedit.com/)
  5. I have just released the first public beta of my new 'SIDControl' VST-plugin - or better 'remote-VST-plugin'. " SIDCONTROL puts a complete user surface to the HW-SidSynth in form of a VST-Plugin. " Its usage is like a common VST-softsynth, but it does process MIDI instead of audio-signals. Now you can remote and automate your SID-Synth via a VST-Host like FLStudio or Cubase and SIDControl-VST. Check this out at ' http://www.saschazone.de ' or ' http://vst-factory.saschazone.de ' -hope you like it ;D ;D ;D
