1,774 -
Everything posted by cimo
Problem with MIOS Studio and osx 10.3.9
cimo replied to ChrisHipgrave's topic in MIDIbox Tools & MIOS Studio
oh god!! i will go down on the street with my laptop my MB play some music and beg for money to buy Tiger 8) do you also know if it is needed to digital-sync the soundcard with a cable to obtain good results or if it is accomplished into the application? best simone -
this is for meeshka (or anybody who can send it to me): isn it possible to get an older version of Mios Studio that will work on Java 1.4.2 ? at least i could run it untill i won t save some bux for Tiger!! best Simone -
hi thanks for the info what what ?? do you mean there is a way to have multiple soundcards enviroment on Core Audio?? let me know let me know see my message that s the only solution for the moment well i tried to install it .. but i can t understand is it only a command prompt application? yes but i have knowledge zero about C although i promised myself i will dig into C soon since it seems to be the next step !! i will have a look at your wiki txxx yes i tried release1 and 3 but of course the installer will deny it i was wondering how ChrisHipGrave managed to do it best simone -
for the moment i ve found the following solution panther - virtualpc - windows - mplab ide - hex2syx - panther - sysex librarian but i d like to have Mios Studio 7.4 working on panther btw it also won t load on windows xp on virtual pc any help appreciated best simone -
hey!! where s java 5 for panther?? thanks simone -
as usual and DUE .. thanks for the support yes i ve rebuilt the application and uploaded it i ve exchanged the default meta event 00 with the new one as described what about the byte1 is it supposed to be 00 or 7F ? best simone
hi all ok so far i ve added that meta event 00 to mb64e_meta.inc as described i have tried 1 to create a .ini file with a few buttons assigned to F0 01 (02,03, etc) 7F (is this correct? i tried also 00) on/off (is this correct?) 2 to use vmidibox to change the buttons as Meta Event with Meta ID = 1, byte 0 = 240, Nr. = 1 (2,3 etc), i tried all the different modes apparently the buttons send a syx so they have been configured but there is no channel change where is the bug?? thanks simone
ok case is open: the ground line after the first encoder is broken !! 5 minutes to midnight 34 degrees plus a bunch of computers humming and .. now the soldering iron... best simone
hi :( ok i am ready to open the case it s so damn hot here that i wouldn t be surprised if something melted... i ll write later and let you know best simone
hi all hi had a custom MB64e with 12 encoders 10 pots 12 backlit buttons 8 buttons all worked great but today while using it 11 of the 12 encoders stopped working i ve uploaded the same software again but they still don t work only one of the encoders is working. That seems to be quite funny for i can t really figure out what happened: my only idea is hardware failure but before opening the case and check it out i d like to know if anybody had a similar situation and if there is another possible solution. thanks simone
sp12 squared (12x12x8) blu leds ... i have to admit they are quite nice buttons .. but i will go for bigger self made buttons next time
i ve bought a joystick with button at Conrad and it works perfectly, i paid 95 eurocents for it but i think it was a special offer.I am really happy with Conrad products and customer support. Simone
FIAT LUX !!!! .. that was it, thanks Thorsten i only need to resolder a few connections in order to link the proper leds to the buttons but it s all working now .. ... i am using those famous RJS backlit buttons and they are very nice buttons indeed but they are not good for triggering samples since they can easily double trigger or not trigger at all.I know there is a parameter for low quality buttons i will try with that but i can t consider low quality buttons something i paid about 4 euros !!! They are great for activating effects, solo, mute etc Thanks again to George and Thorsten for the support Simone
as you can imagine i compiled and uploaded the same thing 100000 times and i am uploading the main.hex file and i compile it before and there are no errors .. i was wondering if there is any change in mb64e_leds.ini (i only changed the number of connected pins) i have to do .. i am just lost and i am sure i am lost in a glass of water (free translation from Italian) :-) cheers
Problema solucionado gracias a todos
ok i got it working<. the solution was manual upload after power on ... there is obviously a limit on the capabilities of MIOS Studio s "wait for upload request" function i hope this can be helpful for other people in the same situation DON T PANIC !!!! ...tx to g. for the help (btw what s your nick in the forum?)
hi rune running voltage on MIDI cables has its own protocol and it is 7 pins MIDI plugs where the power supply is connected to pin 6 and 7 i advice you to stick to this for future use with other hardware (you may have a look at the DSP "Eclipse" from Eventide) and also because as mentioned some hardware (yes not really commonly) uses pins 4 and 5 and you don t want to burn that kind of hardware !! good luck simone
hi thanks for the help out there but maybe i didn t make it clear enough that i am stuck at a earlier point: i can t make those leds light up with my customised MB64e application i see some flickering while i move pots and that means that ledrings are still enabled: but i have disabled them in main.asm i have encoders on the first 3 DIN buttons on DIN 4 5 6 7 leds on DOUT 1 2 (they are backlit buttons on DIN 4 and 5) and 12 pots everything just works fine but i can t link those leds to the buttons (i am sure 100% there is no hardware/connection problem) i was thinking about moving to a mbhp_lc since i am going to use it with Ableton Live5 but i want to learn how to setup the leds on MB64e i also "decided2 today to upload a corrupted application and now the PIC has just gone crazy i can t even upload MIOS anymore hop i can reburn and reset the poor thing, it s time to make my own burner anyway here a little extract from the main.asm #define LEDRINGS_SR_ENC1_16_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_CATHODES_2 0 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_CATHODES_2 0 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_CATHODES_2 0 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings ; #define LEDRINGS_SR_ENC49_64_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_CATHODES_2 0 ; second register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings #define DEFAULT_DIN_SR_PIN_01_08 4 #define DEFAULT_DIN_SR_PIN_09_16 5 #define DEFAULT_DIN_SR_PIN_17_24 6 #define DEFAULT_DIN_SR_PIN_25_32 7 #define DEFAULT_DOUT_SR_PIN_01_08 1 #define DEFAULT_DOUT_SR_PIN_09_16 2 hey Paul i have to admit i don t have an idea of how those pistons look like and i just imagine your organ like a huge machine with a big smoking chimeney on top.;-) anyway good luck with your project !!
hola volvere en espana el jueves y busco alguien que me pueda "burn" el bootstrap loader en un pic que he cargado con una aplicacion corupta, si se dice asi. aqui mi correo cimo75@gmail.com gracias simone
hallo i have uploaded a corrupted application to my pic and it stopped working properly: no MIDI events ca be seen by MIOSStudio or MIDIOx the MIDI/usb interface leds give continuos outgoing signal i can t upload any application i can t upload MIOS either i guess a new burn-straploader process will be necessary if anybody has another idea please let me know i am moving back to Spain in a few days and i don t know if i can find the components to build a burner myself, i will try but if anybody can burn the PIC for me please write me asap cimo75@gmail.com thanks any help is appreciated
hi all i ve got a midibox with 12 encoders 32 buttons (12 backlit) 4 faders 4 pots 1 joystick (analog) no lcd no menu everything works wonderfully with a slightly modified mb64e but there is no way i can thoseleds light up i used the test example to check that the dout2 and the leds are ok and they are i tried everything i could imagine but with no result obviously i am missing something: where should i modify the code to link the leds to the buttons? somewhere in the main.asm it says that the first 4 dout are reserved to the ledrings by default but i have no ledrings enabled any help is appreciated thanks simone
hallo i am looking for somebody who owns a version of Eagle Power Tools to translate an image into an Eagle script i can pay something or exchange the favour somehow simone
:-[ yeah sorry.. thanks for the help
