toneburst
Programmer-
524 -
Everything posted by toneburst
Ooops, just the post a little further down the page asking exactly the same question. Must read before posting in future.... Actually, I think my post is slightly different in emphasis, at least. Alex http://www.toneburst.net
Sorry 'Speak & Spell' ;) Anyone thought of/tried controlling any of the old Texas Instruments toys from a MBCore? I have no idea if such a thing would be possible, but I'm be intrigued to know if anyone has considered it. Maybe something like the MBSID board would be possible, whereby the main chips of a one of the toys could be rehoused on its own board and controlled by a MIOS application. Something like the MIDISpeak board John at highlyliquid.com makes that allow individual phonemes and vocal fragments to be accessed from the ROM would be very cool, + the option to create glitchy circuit-bent-type noises by sending spurious data to the controller chip. It's all pie-in-the-sky stuff, but anyone any thoughts? Alex http://www.toneburst.net
Another newbie question, I'm afraid: what are the advantages and disadvantages of machined-pin DIL IC sockets vs. standard (cheaper) alternatives (other than that they look cooler)? Alex http://www.toneburst.net
Thanks for that moebius. I will do a search now. Cheers, Alex http://www.toneburst.net
I'm thinking of using a joystick as an assignable controller on my MBSID. Would something like this be up to the job? http://onecall.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=1148304 I guess I'd need an AIN board too, since it's resistance-based, and I don't know how I'd tackle to MIOS setup side of things. Any thoughts, anyone? Alex http://www.toneburst.net
Cheers pay_c! Alex http://www.toneburst.net
Hiya, just a quickie. 10k*5 resistor networks for DIN1X: commoned or isolated? Alex http://www.toneburst.net
Toneburst MIOS Upload Issues Thread 1
toneburst replied to toneburst's topic in Testing/Troubleshooting
Just got the first sound out of one of my SID boards!!!! I'm very happy :) Still loads of work to do- need to get the Mike's Core up-and-running. I put a new optocoupler in it and put the PIC (now with MIOS installed) back in the socket. I still can't upload anything to it, but I now get MIDI Frame Errors, rather than nothing except Unexpected Upload Requests. It's not rebooting all the time, anyway, so it's definitely progress! I'll recheck solder joints and component values again later. The working SID board is the one I got with the kit From Mike, which I just put together this evening. For symmetry's sake though, I'd like to get the Mike's MIDIShop Core, and SmashTV SID working too, of course. Unfortunately, that means desoldering and removing all the pins from the SID socket I managed to break while testing voltages a while back. I'm going to need to invest in some desoldering braid, I think, because my desoldering pump isn't doing the job. I'm so glad I've managed to get a sound from it at last!!!! Alex http://www.toneburst.net -
Ah, that's good advice Carsten. I didn't realise that. So you mean put the IC in a socket, then put that socket into the socket soldered to the board? Genius.... I'll add a spare socket to my little (but growing) list. I will try to track down one of these. Sounds very very useful. I've been using a screwdriver pushed underneath the IC, but it's quite hard to lever the chip out without bending the pins. I always treat my SIDs with respect and wear the ceremonial gloves, hat and cloak when handling it ;) Alex http://www.toneburst.net -
Hi Wilba, That's about the size of it. The 2nd kit still just sends out upload requests, but the second one seems now to work fine. I've managed to upload MIOS, the SID application and the SID Interconnection test app so far. I have another spare optocoupler now, so I will try that in the Mike's board, though I don't expect it to make any difference. I'll also try swapping the optocouplers back again, as you suggest, just to see. I've been using 2 different PSUs (a 5v 'wallwart' one and an Optimised PSU/C64 brick one), but both seem to work with the SmashTV board. I'll definitely try this, though I'm getting increasingly nervous about removing and reinserting the PIC chip- those pins are so delicate! I'm at work at the moment, but as soon as I get home, I'll try the tests you suggest, and let you know what I find out. I may even pop home at lunchtime and give it a try... Thanks once again for all your help and encouragement, Alex http://www.toneburst.net -
One little word has made me a very happy man! That little word is glowing on the screen of my pink LCD screen right now.. That little word is: "Ready" Weeeeeeeeeeeeeeee :) I swapped over the optocouplers from the two boards. Board #2 still doesn't work, so it's either a soldering/component error (not unlikely), or the optocoupler that came with the SmashTV kit is dodgy. I must admit I found Mike's kit a little more challenging to construct than the SmashTV one, which is nicely labelled with all components. I'll recheck all the component values and solder joints again. It could well be I used the wrong resistor or capacitor somewhere in there.... As for the SmashTV kit, after I'd swapped the optocoupler, and put my one PIC back in the socket, the MIOS upload worked the first time I tried it! I guess it must have been a dodgy optocoupler, or maybe just something that removing and reseating both chips fixed. I still can't understand why the loopback test worked perfectly, but the main thing is I've finally managed to get MIOS on that bloody chip! I'm a little scared to try uploading the SID application now though, just in case it's stopped working again..... Fingers crossed. Thanks again for all your help Wilba (and everyone else who responded to my plea for help). I'm so happy to be able to move on to the next stage, at least with one of my two boards! Lets see if I can get SID on there now, wish me luck, guys! Thanks again! Alex http://www.toneburst.net -
Hi Wilba, I picked up a book on beginner electronics a while back, which I keep meaning to make a start on. One of the reasons I haven't got round to it yet is that all the exercises require a breadboard! Looks like I'll have to pick one up. They're not too expensive, I don't think, and as you say, they'll come in handy for all sorts of things. I don't currently have duplicates of most of the Core board parts (except for the replacement optocoupler I bought), and some of the resistors, maybe. I do have a 5V 'wallwart' PSU though, so maybe I don't need the 7805 (I removed it from both boards because I was initially using the Optimised PSU and original C64). I'd just need to pick up the caps, oscillator + another PIC w/ bootloader. I have another PIC on the way anyway, so if that doesn't work in either of my current boards, then I may do the breadboard thing. It would be useful to me as a exercise in translating circuit-diagrams into working physical circuits, anyway (you wouldn't believe how long it took me to put together a working Optimised PSU based on the diagram). So, am I right in thinking that if the crystal oscillator wasn't working correctly, the PIC wouldn't work at all? It's definitely sending out the upload request string on both boards. It won't do much else, but it seems to do that fine.... :( I'll swap the optocouplers around when I get home and see what I can find out from that and get back to you. Incidentally, could the issue with my LCD module be related somehow? I know I did connect the LCD incorrectly the 1st time, so I wouldn't be surprised if I had damaged it, but it may be related to my MIOS upload issues. Cheers, Alex http://www.toneburst.net -
Hi Wilba, thanks for getting back to me again. I have another PIC on the way from Germany (should hopefully be delivered in the next few days), so I can test that when it arrives. Unfortunately, what I don't have is a known-working core PCB. Is there anything I can do to test the oscillator/clock on both boards while I wait for the new PIC to arrive? I only have a basic multimeter, being a relative newbie, though I may be able to get access to an oscilloscope at work. Re. the MIDI interface, I've tried several different MIDI interfaces, on several different computers, and I've used MIOS studio, MIDI-OX and Sysex Librarian under MacOS X and Windows, so I'm reluctant to believe that none of my interfaces work.... Thanks again, Alex http://www.toneburst.net -
Optimised PSU Success, But Possibly Broken my Core Board :-(
toneburst replied to toneburst's topic in MIDIbox SID
Could be. You can apparently take LCD modules apart and replace the polarising film, to make change pos. displays into neg. ones, for example. Or maybe fix this issue... Never tried it though. Alex http://www.toneburst.net -
OK, I've done the loopback test again, as you suggested Wilba. Both boards 'pass' ie if I send MIOS to the out port, I get exactly the same back at the in port, byte-for-byte. Works in MIOS Studio running under Windows and MacOS, incidentally. I haven't tested all my MIDI interfaces, but it's probably not worth doing that now. So, this means that the the PIC should be able to send and receive MIDI on both boards. Something must be different on the 2 boards though, as I get different error messages. I'm using the same PIC on both boards (forgot to order the PIC from Mike when I put in my order for the v.3 boards, though I have one on the way now). The PIC I have currently is the one that came with the SmashTV kit, and is indeed a PIC18F452, with the bootstrap loader already burnt (I don't have my own PIC burner). I built the SmashTV kit entirely from the parts provided, though the other board has a replacement optocoupler which I swapped-out on the off-chance that this might help. Should I wait for my new PIC to arrive, or are there any other tests I could run? I know the PIC is getting power on both boards. I also get a MIDI output from both boards, and when connected, the LCD works on both, though unreliably, as mentioned in previous posts. I ran the loopback test without the LCD or SID modules connected, by the way, as you suggested. Thanks again, Alex http://www.toneburst.net Incidentally, HL-SDK, I like the sound of Ghetto Bass' ;) -
Hi HL-SDK, it's good to know you've manage to upload MIOS using an M-Audio interface. I've tried several different ones now, so I'd be really surprised if ALL of them don't work- must be a PCB/PIC-related issue I think. I've been using MIOS Studio (though for some unknown reason, it won't work on one of my computers). It does make things nice and simple, though MIDI-OX gives you more options in terms of setting buffers etc. I'll give the little test Wilba recommended another go and see what happens. I guess the reason I've been concentrating on trying dofferent MIDI interfaces and setups at the computer end is that I know more about computers than about electronics! To my untrained eye, the soldering on both PCBs looks fine, but it does look as if there are major problems with at least one of the boards and possibly with the PIC as well. The loopback test will help a lot, I hope. I suspect the fact that I've soldered a few MIDI-related boards in the past that have worked fine 1st time (including some quite cool ones from http://www.highlyliquid.com) has given me a false confidence in my soldering abilities :( Maybe it's the jumpers on the bottom of the v.3 board... was never completely happy with those... Right, time to break out the soldering-iron again. Cheers guys, Alex http://www.toneburst.net -
Thanks again Wilba. that all sounds like great advice! I will do some more tests this evening and get back to you. Thanks again, Alex http://www.toneburst.net -
That was from my Mike's MIDIShop PCB. I transferred the PIC to my first board, the SmashTV one. This time it's still not working, but I'm getting slightly different errors messages. Still getting the Unexpected Upload Request ones, but also getting another error. I guess there must be some major soldering/component issue with the other board so the MIDI in to the PIC isn't working at all... Anyway, from MIOS upload window: Starting upload of mios_v1_9c_pic18f452.hex Hex file contains code in MIOS range, forcing reboot! Received error code 0C: MIDI IN Frame Error This was an expected error - please ignore! Received Upload Request Sending block 00000400-000004FF Received error code 0C: MIDI IN Frame Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Error: Received unexpected Upload Request Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Error: Received unexpected Upload Request Sending block 00000500-000005FF Received error code 0B: MIDI IN Overrun Error Aborting after 16 errors And from the MIDI In Window: 00000000059215 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000061107 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000062999 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000064891 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000066783 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000068677 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000069197 ms | Sysex message: F0 00 00 7E 40 00 0E 0C 01 F7 00000000069201 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070713 ms | Sysex message: F0 00 00 7E 40 00 0E 0C 01 F7 00000000070716 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070719 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070723 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070724 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070726 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070730 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070732 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070736 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070738 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070742 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070745 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070747 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070751 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070754 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070758 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070761 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070763 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070766 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070767 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070771 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070774 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070777 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070780 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070782 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070787 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070788 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070793 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070795 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070798 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070801 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070803 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070806 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070808 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000070812 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000070905 ms | Continued Sysex message: F7 0B 01 F7 00000000071008 ms | Continued Sysex message: F7 40 00 01 F7 00000000071099 ms | Continued Sysex message: F7 00 0E 0B 01 F7 00000000071102 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071210 ms | Continued Sysex message: F7 00 7E 40 00 0E 0B 01 F7 00000000071213 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071215 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071219 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071222 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071224 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071228 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071230 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071231 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071237 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071238 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071241 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071244 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071246 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071251 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071253 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071256 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071259 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071263 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071265 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071266 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071270 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071273 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071278 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071279 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071282 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071284 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071289 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071293 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071297 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071298 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071300 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071305 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071307 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071307 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071313 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071314 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071317 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071319 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071323 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071326 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071329 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071334 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071336 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071338 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071343 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071345 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071347 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071349 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071353 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071356 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071358 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071360 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071365 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071367 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071370 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071374 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071376 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071378 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071383 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071384 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071388 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071390 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071392 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071395 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071398 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071402 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071405 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071407 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071411 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071414 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071418 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071421 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071425 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071426 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071430 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071431 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071435 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071437 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071440 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071443 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071446 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071449 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071452 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071455 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071459 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071461 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071465 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071466 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071469 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071473 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071475 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071478 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071480 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071485 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071488 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071490 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071492 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071495 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071498 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071501 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071505 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071507 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071511 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071515 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071516 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071519 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071522 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071523 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071528 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071529 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071533 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071535 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071539 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071542 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071545 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071549 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071552 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071555 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071557 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071560 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071562 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071564 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071569 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071571 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071575 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071576 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071580 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071582 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071586 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071591 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071594 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071596 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071598 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071599 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071604 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071606 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071609 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071611 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071614 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071617 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071620 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071626 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071628 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071630 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071633 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071637 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071639 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071641 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071645 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071647 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071650 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071652 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071655 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071658 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071681 ms | Continued Sysex message: F7 01 F7 00000000071682 ms | Continued Sysex message: F7 00 0E 0B 01 F7 00000000071685 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071687 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071692 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071694 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071696 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071699 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071702 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071705 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071710 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071712 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071715 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071718 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071722 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071724 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071726 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071728 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071732 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071735 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071738 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071742 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071744 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071746 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071751 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071753 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071757 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071760 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071762 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071765 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071767 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071770 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071772 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071776 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071778 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071782 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071785 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071786 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071790 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071794 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071798 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071799 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071802 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071806 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071807 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071810 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071813 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071817 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071820 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071821 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071825 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071827 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071832 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071835 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071837 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071840 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071844 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071846 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071849 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071851 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071854 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071857 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071861 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071862 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071867 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071870 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071872 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071876 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071879 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071882 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071884 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071888 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071890 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071892 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071896 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071897 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071902 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071903 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071907 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071909 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071912 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071917 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071919 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071922 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071926 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071929 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071931 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071932 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071936 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071938 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071943 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071946 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071948 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071951 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071953 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071957 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071962 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071965 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071967 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071968 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071973 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071974 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071978 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071980 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071982 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071985 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071990 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071993 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000071995 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000071998 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072001 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072005 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072007 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072009 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072014 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072015 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072018 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072020 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072024 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072027 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072030 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072033 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072036 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072038 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072043 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072044 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072048 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072050 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072054 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072057 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072058 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072063 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072065 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072068 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072071 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072073 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072076 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072080 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072084 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072086 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072089 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072091 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072094 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072098 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072099 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072102 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072105 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072108 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072112 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072113 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072117 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072120 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072126 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072126 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072130 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072132 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072135 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072138 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072141 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072143 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072146 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072150 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072152 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072155 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072158 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072160 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072165 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072168 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072171 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072173 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072177 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072180 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072182 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072184 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072188 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072189 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072194 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072196 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072200 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072201 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072205 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072209 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072211 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072215 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072217 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072220 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072224 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072225 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072228 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072231 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072235 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072237 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072240 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072243 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072245 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072251 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072252 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072256 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072259 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072262 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072264 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072266 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072270 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072271 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072276 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000072279 ms | Sysex message: F0 00 00 7E 40 00 0E 0B 01 F7 00000000072282 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000074174 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000076065 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000077959 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000079849 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000081743 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000083635 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000085527 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000087419 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000089310 ms | Sysex message: F0 00 00 7E 40 00 01 F7 etc. Hope this helps with diagnosis. Thanks again, Alex http://www.toneburst.net -
Where Can I Download hex2syx.pl script?
Thanks Moogah, that's great! Alex http://www.toneburst.net -
OK, here's the output of the MIDI Out and Upload windows. My Setup this time is: PowerMac G5 Dual 2.3GHz / MacOS 10.4.8 MIOS Studio latest Beta Steinberg USB2MIDI interface (not tried this one before) Plumstone Java MIDI extension This is the 2nd, Mike's MIDIShop board Incidentally, I don't know if this is a seperate issue, but the LCD keeps screwing up. Sometimes it displays the row of bars, as it should, but sometimes it displays other stuff, sometimes just a single line of pixels, other times more blocks, with lines through them and randomised-looking portions. I did plug in the LCD cable the wrong way round when I first connected it. It got quite hot so I unplugged it as quickly as I could. It was subsequently fine, when replugged the right way round, but a couple of days later it started to screw up. Could this indicate a problem with the PIC, maybe? = = = = = = = = = = = = = = = = = = = = = = = = Upload Window: Starting upload of mios_v1_9c_pic18f452.hex Hex file contains code in MIOS range, forcing reboot! Received Upload Request Sending block 00000400-000004FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Sending block 00000500-000005FF Error: Received unexpected Upload Request Aborting after 16 errors MIDI Output Window: timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 00 00 00 00 00 00 F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 00 00 20 0D 7B 62 5F 00 45 0F 7F 7F 76 39 7C 0F 57 35 4F 61 3D 33 6B 01 73 21 1E 5D 26 1A 0A 0D 49 71 50 4E 6A 00 2D 04 7A 71 07 68 3C 56 42 3E 43 03 45 6C 7F 78 2C 2E 6B 7E 11 00 38 39 7B 4F 57 45 4F 5D 3D 3E 6C 7D 6F 6B 77 67 6F 1E 5F 2E 3E 7B 75 01 70 17 6F 28 13 01 3F 7A 41 38 0C 07 54 24 00 5C 71 3C 1F 7D 6B 0B 62 7F 6E 78 5F 37 7E 79 45 7B 7F 77 5C 2F 57 7F 3E 62 40 7E 0B 7E 14 09 70 60 31 20 5F 00 48 00 08 07 35 4D 6F 14 50 05 34 02 74 07 3E 60 2F 61 32 5E 52 1D 40 67 43 05 57 4F 24 19 59 06 60 1D 4F 13 3B 61 6C 71 1B 1B 00 02 40 36 75 0E 62 49 37 03 6D 45 30 15 50 63 50 5B 14 20 70 58 17 43 38 02 40 7C 0B 42 47 31 24 5C 01 60 50 0D 24 0E 22 70 6A 4A 1D 45 52 54 29 54 5B 75 05 08 73 41 2D 28 76 14 4A 68 1E 61 5F 01 29 41 4E 60 63 61 0C 76 02 1E 0E 67 30 1B 70 01 29 41 6E 60 63 61 2D 28 42 7C 02 2F 3B 61 70 0A 7B 5C 0F 00 40 1C 0B 37 37 6A 0E 30 6B 3C 6A 05 4B 5F 3D 38 1D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 01 20 00 20 54 77 75 55 0E 62 69 3B 76 02 3E 08 16 5E 43 12 02 40 36 19 06 19 23 33 13 31 2A 1B 11 1A 63 00 58 68 01 0D 00 0A 68 06 68 00 56 60 26 42 09 5F 02 3B 03 0F 04 4B 3E 6F 6B 41 20 19 3A 46 30 19 01 38 33 59 43 27 2E 79 6F 76 1B 1A 6B 3A 0F 5F 32 35 75 3B 20 0A 19 2E 67 64 5E 57 06 7C 0A 01 49 2F 61 6D 04 69 23 70 05 02 1C 09 5A 44 0B 61 4D 14 30 0D 4C 69 22 15 6C 26 6D 79 58 1E 24 51 3D 36 21 5D 07 5C 1D 12 32 40 7A 09 12 45 69 59 03 74 12 25 0C 69 5F 1A 28 41 5B 09 5B 3E 34 51 36 36 33 69 53 07 3E 3E 6B 43 0D 60 61 60 0E 0B 03 7B 00 3F 00 08 18 02 06 00 41 40 10 30 02 0C 00 43 00 20 60 31 21 7E 05 7C 01 2D 45 50 02 0C 06 14 1E 20 56 62 68 02 06 00 01 4E 41 60 60 0B 58 5B 40 50 08 10 39 46 37 6C 6D 60 18 73 0A 6F 59 1B 56 18 00 48 01 68 1C 0C 01 3B 0B 38 0A 01 02 07 18 66 78 0C 39 45 37 6C 30 01 10 02 63 00 09 00 16 19 00 48 00 05 00 6D 6D 7F 78 2F 31 34 09 00 00 40 00 4D F7 -
Hi Wilba, thanks very much for your detailed reply. Unfortunately, I'm at work at the moment, so I can't do any more tests right now. I do know that recently, I haven't been getting Framing errors though, I now just get unexpected upload request errors, as if the PIC wasn't receiving anything. The upload request seems to be send every 2 seconds, whatever I try to send to the Core board. I'm pretty sure it's not a problem with the optocoupler, as I've tried 3 different ones now. Unless I have it in the wrong way round, of course. As I said in a previous post, I've assumed the mark in one corner of the chip indicates PIN 1 If I could find the hex2syx perl script I could try uploading MIOS using Sysex Librarian from one of the Macs. Maybe you or someone else could send me MIOS as a syx file so I could give that a go? As for soldering/construction errors; it's definitely a possibility, as I'm not the World's greatest solderer, and will admit to not really knowing the first thing about micro electronics. However, I've made up 2 of the Core PCBs now (one SmashTV v.4 board and one v.3 board from Mike's MIDIShop), and get the unexpected upload request error in both cases. I only actually got the framing errors on a couple of occasions, with the 1st, SmashTV board. I have the boards here at work with me now (I popped home and got them- don't tell my boss), so I'll try some more tests here, and get back to you. Thanks again, Alex http://www.toneburst.net -
http://www.ucapps.de/howto_tools_hex2syx.html has a walk-through about using a script to convert a MIOS hex file into a sysex file. Where can I download this perl script though? I can't find it anywhere on the site... Alex http://www.toneburst.net
I've tried my one remaining untried MIDI interface now. My Emagic AMT-8 doesn't work either. Now I'm really screwed- I have nothing else to try...... What do you think guys: should I just give up entirely and take up gardening or something? Just to recap- I've replaced the entire Core PCB and all components except the PIC with a new one I've run all the debug tests I've tried 3 different MIDI interaces, by 3 different manufacturers, in 2 different OSes and on 2 different computers I've tried changing MIDI cables I've tried 2 different PSUs Nothing I have done makes any difference- I still get exactly the same error messages in MIOS studio- 'unexpected upload request'... I'd be really really really grateful if someone out there could think of anything at all I could try. It's been nearly 2 weeks since I hit this brick wall.... Maybe someone can upload MIOS and the SID application for me..... It looks increasingly as though I'm never going to get it to work here... :( Alex http://www.toneburst.net -
REALLY..... I will try another interface, in that case. The NI Kore doesn't seem to work either, but I have a few others I could try. Thanks for the info Twin-x! Alex http://www.toneburst.net -
Hiya, I know answering my own post seems a bit like talking to myself, but here goes anyway... I'm really running out of things to try here. Last night, I completed my second Core module, this time I bought the PCB from Mike's MIDIShop (excellent speedy delivery, incidentally). I forgot to add a PIC to my order, so I reused the one from my first SmashTV Core module. Otherwise, everything is new. I also managed to find a 5V wallwart I didn't even know I had so I could eliminate PSU issues from my enquiries. STILL... DOESN'T... WORK............... Tried 2 different USB MIDI interfaces on my MacBook Pro (NI Kore, Midimac MIDISport 2x2). Tried booting into MacOS X (10.4.8 if it makes and difference) and uploading via MIOS Studio. Tried booting into Windows XP SP2 and uploading via MIOS Studio. Tried the send/receive SYSEX loopback test in MIDI-OX. Fails with both interfaces (I get an error message saying something like 'the port is trying to send something, please wait until it has finished and try again'). A couple of times I have been able to send and receive a SYSEX file, but not all the bytes sent have made it back to the MIDI input. I've tried adjusting buffer settings as suggested in the MIDI Interface Troubleshooting guide http://www.ucapps.de/howto_debug_midi.html Incidentally, the SYSEX file I'm using is a random file I found on the WWW- think it contains some patch data for a Korg synth. In terms of the loopback test, I don't think it matters what it is, does it? So... I tried the same two interfaces on another computer. Upload fails in MIOS Studio, with the usual error message. This Mac won't boot into Windows, so I can't run MIDI-OX. I have a third Mac, a PowerMac G5, but MIOS Studio doesn't work on this machine (the GUI is broken, and you can't connect MIDI interfaces to the MIOS Studio In and Out ports). This machine has a PCI-based MIDI interface (part of the M-Audio Delta 1010 I have connected to it), so if I could get hold of a sysex version of MIOS, I could try uploading it with a SYSEX tool like Sysex Librarian from there. I've tried different MIDI cables, so I don't think this is the problem. I've checked the polarity of the diode and the value of the resistors. Soldering looks OK. Voltages are correct. Optocoupler is correct way round. I'm assuming the small dot indicates pin 1.... It seems likely that it IS a problem with MIDI on my computers. The only other common factor is the PIC. I'm getting another one from Mike (though I think he's awaiting delivery of a new batch himself at the moment), so I'll soon be able to eliminate the posibility of a bad chip. If I can't upload MIOS via SYSEX transfer using another application on the G5, I think I'm screwed.... :( Anyone any ideas? Anything at all I could try? Thanks for all your help guys. I desperately hoping I've missed something obvious here... Cheers, Alex http://www.toneburst.net
