Dauwige
16 -
Everything posted by Dauwige
SOLD!! ;)
Hi, here is my interface what i'm using to connect my two 2x40 LCD in my MIDIbox. Maybe you can solder one on a small breadboard but if you like more professionality.... Regards Core-LCD2.rar Core-LCD2.rar
Thx for hint. Forgotten to name the polygone. Updated ;) ::)
Hi, i made with Eagle a Memoryboard for up to 8 EEPROMS. I use it in my Midibox. It has a jumper ( or switch connected) )aswell for disconneting ( due addressing conflict with other Banksticks). Hope somebody needs them Regards... I²C Memoryboard.rar I²C Memoryboard.rar
This MIDIbox is still for sale! I will notify here when i'ts sold! And... I'll not give a price. That's up to you to give an offer. As i mentioned the value of this item would be minimum parts cost. So long...
Here some details: (maybe for calculating parts cost ;D) Qty. Item 1 Case 1 Frontpanel 1 Core (without PIC) 1 PIC 18F4620 2 PIC 16F88 3 DIN 3 DOUT 1 Power Supply 2 LCD 40x2 Backlight 1 LTC_V2 2 IIC - Midimodul (without PIC) 48 Push Buttons 115 LED's 8 EEprom 24LC512 17 Rotary Encoder 1 Various Parts (Cable, Connectors..) Voltage 110V - 230V/50Hz Weight 5.1 kg 2 MIDI-In 3 MIDI-Out 1 MIDI-Thru 1 Reset Button 1 BankStick Connector Firmware Version: 3.2a - adapted Space for extentions (more MIDI ports...) Printed User Manual CD with modified Firmware and Layouts Price? Well, i think that minimum parts cost would be a good start. ;) (shipping not included- Europe aprox. 40€ / International aprox. 66 €) Attached: My MIDIbox User Manual MIDIbox_16T32S_Manual.pdf MIDIbox_16T32S_Manual.pdf
Due no time for my hobby... I will sell my midibox seq. Pls refer to http://www.midibox.org/forum/index.php/topic,10427.0.html. If O.K. pls send offer by pm. Selling ONLY here! Regards.
Here are some fotos. I'm using it wit two Novation Synth's and a Boss Drumbox. 27_071220_Lights.JPG 19_071219_Finished.JPG 34_071224_Inside.JPG
Hi, yesterday i finished (well, small software tweaks are left) my MIDIbox 16T32S. Thx to all here in the Forum without their help this project was not possible. And of course to T.K. for this wonderful piece. If any interest i can put more fotos of this device. ... And Happy X-Mas.
Hi, i have finished my MIDImon V2 with the LCD & LED Display. Now my question: It's posible to connect a PCF8583 to the IIC and display in the meanwhile i'm not using the monitor? In the MIOS are functions for the bus, but my skill in asm programming is not so good. I need only a small template for access the IC. Thx for any help.
hi, there is a good program for design the frontplate see:http://www.schaeffer-ag.de/index.php?option=com_content&task=blogsection&id=8&Itemid=73&lang=en You can use in the print option -> tile print. It prints 1:1. So you can cut off the holes from the paper and try if it fits to your assembly. Hope that helps Greetings
thx for the fast reply. i mean if it´s possible to switch mecanical between different bankstix pcbs? Will the core recognize the switch? So maybe its possible to have more memory.
What is the best or maximum for the banksticks? Can i connect different chips on the bankstick pcb? I know that the maximum would 8 x 512 = 512K, but for song data is only the max. 32k. So is the following the maximum? 6x 24LC512 for pattern and 2x 24LC256 for song and mixer? Is´s posible to connect two or more bankstix pcb to the core? So how many 24LCXXX should i order? Many thx
Hi to all, first thx to torsten for for this exelent diy project. I started first with the v2.4 project but after a look to the new v3 i dicide to change to the new version. At the beginnig a had some problems but this forum is very good for solve the most problems. Tip:I get all PICs directly from Microlab as samples for free. There was a hint in this forum. First: I have made the 4x16 LED Matrix and wonder that all are on at power up. That happens in v2.4 and v3. Is this normal? Second : Is there a subroutine for showing System Info like firmware info and usage of memory or how (KB installed)? I have nearly finished the hardware and the front panel is ready for order: what u think about the panel? see attachment Later i will post some photos of my diy project. Greetings to all. added: in the setup*.asm there is the followig: LIST P=PIC18F452, R=DEC ERRORLEVEL -223 ; suppress "Redefining processor." for the v3 have i modify it to the PIC 18F4620? like: LIST P=PIC18F4620, R=DEC
