![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
EvilEvilEvil
49 -
EvilEvilEvil last won the day on September 30 2018
EvilEvilEvil had the most liked content!
About EvilEvilEvil
- Birthday 01/01/1
Gender
Not Telling
Recent Profile Visitors
EvilEvilEvil's Achievements
![Rank: MIDIbox Newbie (1/4) MIDIbox Newbie](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
Displays not initializing after working for a while
EvilEvilEvil replied to EvilEvilEvil's topic in MIDIbox SEQ
Thanks again Hawkeye. I'll try that. In the meantime, here's the voltages I'm measuring at J15A -
Could the fact that I haven't yet installed the SD reader contribute to this issue? Does the SD reader need to be installed to see results on the display? -
Thanks Bruno - for the vid and the suggestions. I am going to try one more LCD and then hit your steps. Yesterday I gave up. Today I'm willing to try some more Can I just use isopropyl alcohol as flux remover? -
One last question. It was working. Is it possible that it would work (or appear to work) OK with the connection wrong? And then it burnt out? Otherwise this whole thing makes no sense. I never changed the orientation of the connections yet it worked, was legible etc... -
I already did I don't have an oscilloscope. I've tested the pins some. OK, I'll try another one. Then that's it for now. Maybe in some months I'll get encouraged to go back at it. Thanks again -
Here's this just for the record. This was taken at the same time as the above notch/cabling photos. -
Unfortunately, I'm still in the same boat after rearranging things as indicated by TK. See below. I have to get back to making music soon so I think I am going to have to give up for a while. It is really frustrating that the LCD worked fine for so many weeks and now nothing I do seems to help... -
Hey TK - thanks! Can you also indicate where the square outlined pin is on the LCD (I assume that the square one is Pin1?) According to your picture I don't have mine arranged correctly however the red stripe IS going to pin 15 on my LCD
Mine is hooked up with the red stripe on the arrow to the Core and to pin 15 on the LCD, like so: http://ucapps.de/mbhp/mbhp_lcd_2x20_mios32.pdf Contrast and brightness work for me. So that could be your issue - although you say it worked fine before?
Same exact thing I'm experiencing. It worked and I put it aside for some weeks while I built the other mods. Now it doesn't and just produces the black bars on the LCD. I've rebuilt my core, ordered another LCD and tried another discovery board - same result. It makes no sense because it worked fine several weeks ago. TK, please help! What does MIOS Studio say? Does Seq4 actually start?
Yes, changing the contrast and brightness often. My assumption is that if you can see the bars then you can see the regular OS display, correct? -
The only thing I can think of is that I fried all my LCDs somehow. Or else the ribbon cable is just not connected right - even though I've made about 4 of them now! -
Thanks for the encouragement Peter! I am about to give up :) (for now). I'm getting a voltage of 4.74 on the LCD pins. J15_S is set for 5v I've tried everything. USB mini cables, Micro cables, different 5v wall power supplies. connecting directly to J2, a 5v 1A battery, a 5v 2A USB hub..
