![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
rude bo
18 -
About rude bo
- Birthday 02/06/1980
Gender
Male
Location
IND
Contact Methods
Yahoo
rudebo80
rude bo's Achievements
![Rank: MIDIbox Newbie (1/4) MIDIbox Newbie](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
IMHO with mb64e firmware you can add up to 32 scratch wheels for only 1 core. B.R.
Hello here is my mbswinsid project, based on atmel chip + swinsid application for sid chip substitute. 80% finished. box case, button & encoder label still on progress.. ;)
I'll burn the bootlader for free.. ;)
hello TJ I think I have one PIC18F452, which has not been used yet. so cheers up im live in indonesia too. ;D
Finaly writing the fuse bit work using HP P3 pc ;D. But the output sound litle bit noisy. I think its my power suply problem. I'll find new good power supply after my mb swindsid frontpanel finished... ;) Thanks all for the help.. B.R.
HI I'll try on my friend PC tommorow. ;) Thanks B.R
Hi swinkels sorry for late reply, im just back from holiday. Im using TDA1543, i buy it from futurlec.com. I dont able to re-program the fuse bit config. im using pony prog with stk200 simplified. It always show "device missing or invalid". Please tell me how can I re-program it? are stk200 need external vcc? and what fuse bit should i tick? here I attached the recorded testone. and sorry for my english.. thanks before it testone2.rar
this is the schematic i've made. Iam glad if somebody correct it thanks B.R
hello I build mbsid + swinsid today. im using pic18f452 with midibox_sid_v1_7303c setup_6581.hex firmware and SwinSIDX2.hex for atmega, but when I play some notes on my keyboard, i just hear some noises sound from my speaker. I build based on swinsid schematic combined with mbhp_sid_v3 schematic. any sugestion please.... sorry for my english... B.R
hello.. so based on the SwinSid schematic the mbsid module does not need 9 / 12 volt suply . and SwinSId does not have an audio input. correct me if I am wrong.. thanks B.R sorry for my english
Hi, I build another midibox64 and have a problem. inside mb64 ini file I only found led-map assign for External bank ( 1 - 8 ). how to assign sr2 dout for External Bank (9 of 16)? ??? Thanks B.R.
@Sasha Yes the button are grey. i mount the button to stripboard. @cimo Its a custom cutting sticker. i ordered it from local car's cutting sticker. @disgustingpie Its from my broken audio speaker boxes. and thanks to T.Klose for wonderfull mios... Regards
I made the button from flexible keyboard. see here http://the-gadgeteer.com/assets/brando-flexible-keyboard8.jpg I cut it per button and glued to front panel... thanks
