        patstormont
                Posts23
                Last visitedNever
Everything posted by patstormont
	MIDIbox of the Week (MIDIbox SID of Ixox)patstormont replied to Ixox's topic in MIDIbox of the Week Good work, I want build a small sid synth, mind if i copy your layout? Could i convince you to share your firmware?
	i bought some of these too, how did your tests go?
	Nice work playing with deadbeat, i saw him play about 5 times when he came to melbourne a few months ago, he's awesome. Nice guy too. I'm in a similar situation, I have a gig this thursday playing with swayzak, who were a really big influence on me when i was starting to produce. I've been trying to finish my midibox before that gig, but there's no hope now, luckily i have other midi gear i can use.
	no worries, i found it here: http://www.tme.hu/katalog/index.phtml?f_szukaj=KS01-BL-3
	Those buttons are fairly cheap it seems in quantities of 25-100 they'e about AUD$.95 each, or about US$.70 hmmm.
	Nice! Where did you get the caps for the led buttons? Or did you make them?
	they went for USD$49 too, that's so cheap.
	yeah the main volume knobs are a bit big, but i don't think it'll be too much of a problem. The main reason i've used those knobs is they were really cheap, 30c each.(about USD25c) i'm getting closer to getting it working, I think my ain boards are dodgy. Probably because i etched them myself. ::)
	MIOS/MB64e uploaded fine, but no midi...Help!patstormont replied to patstormont's topic in Testing/Troubleshooting OK, so with no ain connected i get no random messages. with 1 channel channel of 8 pots is connected i get the random cc events. I guess this means that there my core is fine and there is something wrong with my ain board, or the wiring of my pots. I wired the pots exactly the same as the 64pots diagram on ucapps.de. I checked them again and they seem fine. All these random cc messages mean an open connection somewhere in the circuit right?
	MIOS/MB64e uploaded fine, but no midi...Help!patstormont replied to patstormont's topic in Testing/Troubleshooting Hey Thorsten, Thanks for the tips, i'll try this test tonight.
	MIOS/MB64e uploaded fine, but no midi...Help!patstormont replied to patstormont's topic in Testing/Troubleshooting ok i started troubleshooting by unplugging all the modules and adding them one by one. I got the dins to work ok, but there is a problem with the ain modules i keep getting random control messages All of the unused inputs are clamped to earth and all of the pots seem to be wired correctly. What should i try next? The ain boards i etched myself and they are a little rough, but there are no faults i can see. The only thing i can think of is: I soldered the 4051s directly to the board, are these chips particularly heat sensitive?
	OK, so things are coming along. I've ditched the button matrix idea and will be replacing them with a 4x4 button encoder matrix with multicolour leds. But in the mean time I have been trying to get it working without the matrix. I've uploaded mios and 64e firmware, but am having some troubles getting any midi output. Anyway a couple of more pics including the new stronger case i found for it:
	So, I've finished building the hardware and have uploaded mios and MB64e to my controller. Specs are: 26 buttons 7 encoders 40 pots no display But when i open the mios studio midi monitor i get no midi coming out of my box at all, only the mios update request. I have also tried the midibox64 application and still no midi data. I figured it would need some extra configuration, but i get absolutely nothing from any of the buttons, pots or encoders. I have triple-checked all my connections and they all seem fine. Where do I go from here?
	I think they are the same ones, i tried looking on the conrad site for them, but couldn't find them.
	I'm thinking of maybe having a small redesign. I was thinking of using the 4 buttons on top of the matrix to toggle between different setups, but i might add extra buttons for this I have an encoder for each channel, these will be assigned to control insert fx parameters on specific to each channel. I'm thinking of adding a multi colour led and a small button to switch between the parameters of the encoder. The led will show a specific colour for each parameter. So this brings me to a question: Is it possible in the midibox 64e firmware to toggle through individual encoder assignments, or am i limited to toggling complete snapshots?
	I'm looking for these led caps, anyone know where i can get them?
	If you look around you can find flightcases that open like a suitcase, and have even depth on both sides. It'd be easy to use one of these to install a Midibox seq in one half and a midibox sid in the other. You'd have to recess the face panels so the knobs don't hit eachother, but that wouldn't be too hard. They're cheap secondhand too.
	How to change the assignments of my MB64 when I press a button?patstormont replied to snorkman's topic in MIDIbox HUIs I was wondering how to do this myself, I want to be able to toggle through 4 setups while playing live. Is it possible to assign each setup to a dedicated button? I don't plan on having a screen so i hope this is possible.
	Yeah it took a while to file them down. Other screws might look better, but I am focussing on functionality more than looks. Anyone know where i can different knobs for the joysticks? the ones that came with them are to short to gice good control.
	I will check it out, a friend has it. Even so I don't think this controller will change much as i'm fairly set in the way i play live, and i'm not far off finishing it.
	not yet i'm still on 5. i'll upgrade soon though. some more pics, this is how i'm doing backlit buttons. 10mm leds with the top sanded flat, glued to the top of tact switches. It looks a bit dodgy but it's actually really sturdy and looks like it will work fine. i need a new camera.
	I started building this ages ago to play live with ableton, my other midi controller(UC33) is on it's last legs, and i was never really happy with it anyway. I had a big break from building but have decided to finish it off. Basically it's setup like a 6 channel mixer with 3 band eqs, 2 sends, 1 mute button, 1 launch button, and 1 encoder per channel. It also has 4 joysticks to control fx, and a rather dodgy monome ripoff, which i'm not 100% sure will work yet. If it doesn't i'll just add more encoders instead. I am a student, so i've been trying to do this on the cheap. I'm pretty pleased with how it's coming along. The only thing that i've screwed up so far is the drilling of the front panel isn't as square as it could be. Anyway here's some pics.
