buryplo
    5
About buryplo
  • Birthday 01/01/1
  • Gender
    Not Telling
  • Location
    France
buryplo's Achievements
MIDIbox Newbie
  1. I use this schematic http://ucapps.de/mbhp/mbhp_lcd_4bit.pdf and left D0/D3 unconnected. Should I connect them to ground??? The strange thing is that the lcd works until I connect sid module's IC3 Buryplo
  2. The IC are in the right way and the SID Mdule is right connected to the core
  3. Hi, I've started to build a MidiBox Sid. The core is working fine (I can upload application, the lcd is working). I 've plugged the sid module and checked the voltages, all OK. So I put the ICs in the socket. The LCD doesn't display anything but I still can upload application. I'v try removing the ICs and when I removed IC3 my LCD is working again. I've no idea where the problem is, i've no short or cut in the PCB. If anyone know how to solve this problem. Buryplo
  4. S'lut J'avais le même style de probleme sur ma MidiboxFm, c'était juste le cable de sortie qui était mal soudé. Pour le test d'interconnection, c'est écrit en en-tête du fichier main.asm comment l'utiliser. J'éspère que tu arrivera à le faire fonctionner, ce synthé est genialissime....
  5. buryplo
    samples?
    Hi I've made some little sample with my young MidiBox FM : http://jack.celer.ifrance.com/. I can made other sample if you want. This synth is terrific Buryplo
