fairplay
    5
About fairplay
  • Birthday 08/08/1967
Contact Methods
  • Website URL
    http://MySpace.com/o8o8
  • Gender
    Male
  • Location
    Munich, Germany
fairplay's Achievements
MIDIbox Newbie
  1. ...ich will - ich will :thumbsup: ...
  2. ...hmmm, i just realise that your answer relates to the PIC... ...is it the same with STM32 (which i plan to build as i have the parts here already :rolleyes: )...
  3. ...hi Thorsten, thank you for your quick and encourageing reply!... ...i did fear that it might not be as easy as to just add the 11k resistor - but then: electronics is a huge new field for me... ...i'll let you know if it works out with the un-altered joysticks - unfortunately i will not have it ready until mid october (you know :ahappy: ) to let you have a try... cu
  4. ...attn: electronic&MIDIbox-dummy question...i have browsed backwards to find an answer, but did not find anything suitable... ...i'd like to use a joystick as input for a MIDIbox 64 - unfortunately that joystick is just available with two 100kOhm poti installed; now i assume that the AIN-module should work with those also - in terms of: not requiring 10kOhm - but i am not sure... ...could someone either confirm that it would work (even with less accuracy) or tell me if i have to solder a 11kOhm-resistor in parallel to get almost 10kOhm?... TIA.
