resistor
    25
Everything posted by resistor
  1. Thanks TK, i try swap banksticks and was solved :)
  2. Is there any possibility to re-format the Banks sticks to 64k? Thanks :)
  3. Hi everyone, I'm looking for advice regarding the following problem : When I upgraded the 6581 chip to the 8580 and installed the new firmware (v2.040 8580 from v2.034 6581), the MidiBox, it seems, re-formatted the bank sticks. Now it would only load the presets up until #64, so I am guessing the actual format is 32k instead of 64k. Is there any way to format to 64k while using the 8580 chip with v2.040 firmware? Thank you in advance Fernando Argentina I have the followings Banksticks: A1 A2 A3 A7 I have a Stereo Sid Best regards
  4. Please keep 2 8580 for me. Thanks
  5. Please give me the opportunity to buy this pair, i will pay 20 euros for each chip + shipment. 8580 is a extremly rare part to find in argentina :(
  6. is there any possibility to buy a pair? how much is the freight cost to buenos aires argentina? Thanks
  7. It was an Inside Job...
  8. resistor
    resistor - w00dy b0x SID
    TK+Aluminium+Wood = w00dy b0x SID
  9. From the album: resistor - w00dy b0x SID
    Inside the beast...
  10. Thanks to all! Hi antix, was made with 3d modeling and CNC machine. best regards
  11. Hi, im Fernando Dallavalle from Argentina. Finally, after several months of design work I finished the Wo0dy MIDIbox SID . Thanks TK for showing me the light 10 years ago when I was 17 and knew nothing about electronics, the dream has come true, this is a tribute to you. Here some pics. Blessings
  12. Hello arti im fernando from argentina , i want buy you some 8580, can you sell me some chips? How much is the freigh cost to buenos aires argentina?
    Thanks!
    Best Regards
    Fernando
  13. Hello, do you have any 8580 for selling?
    Thanks!
  14. The OSC via Ethernet feature is ready in the STM32 core? Protools can read/send OSC protocol? Thanks! Best Regards. Fernando
  15. Thanks Smithy! Well... i need learn silk screening and buy the tools for this. Best Regards. Fernando
  16. Last render done! :Dual Filter Moog Syle box Best regards! Fernando
  17. Filter enclosure done! Single filter: http://shivatek.com.ar/images/FRONT_FILTER.jpg http://shivatek.com.ar/images/BACK_FILTER.jpg Double filter (serial/parallel option): http://shivatek.com.ar/images/rack_real.png Best regards. Fernando
  18. Of course, my design is based on this filter http://www.uni-bonn.de/~uzs159/rs20.png Best regards! PD: I have some PCB's if you like. Contact me with details.
  19. Yes i made the design in argentina :) Main features: . Multimode Filter LP / BP / HP. . 2 inputs for CV control. . Input for Keytracking (pitch). . Input for Expression pedal. . Line Input. . Line Output. . Cutoff and resonance control. . True Bypass Switch. . Bypass Led. . Vumeter Led (Moog MF-101 style). . Power ON Led . Internal Trimpot for exp pedal calibration. . Internal Trimpot for cutoff calibration. . Internal Trimpot for resonance calibration. . Input Buffer. Shivatek: http://www.shivatek.com.ar http://www.vimeo.com/resistor
  20. In Alibaba.com Search for bakelite knobs. Best regards!
