Fred
    7
  • Gender
    Male
  • Location
    Hungary
Fred's Achievements
MIDIbox Newbie
  1. Hi! My MIDI DJ CJ controller was made ready. I need your help! MIDI OUT port does not work! USB port and all functions works well. PCB double check! ATMEGA16 pin15 (PD1) always is in a logic high state.
  2. I was building first a MIDIbox FM. (New full SMD PCB with own planning.) My second work a sammichSID clone. (Not kit, own pcb.) I built it up yet a MBHP USB-PIC module. (Totally new own pcb.) I would like soon a MIDI DJ CJ CONTROLLER... I like it better the ATMEL AVR. In Hungary expensive the PIC... I was looking the 808. A drum seqeuncer would be good for me... Return to the MIDI DJ CJ CONTROLLER! Will a newer controller be next? (For example instead of a potentiometer rotary ecoder.)
  3. Thank you for the answer! Like this already understandable for me. (I learned a Russian language little...) I would like to build the controller. But sliding potentiometer I would like it... Very good the software! There will be a newer hardware version? Newer plans?
  4. HI! Very good project! I would have a question: LED1-LED6 (6 piece) S1-S5 (5 piece) Which LED to belong to which switch?
  5. Thanks nILS! What's the function of the encoder button? Sorry about the many matters...
  6. Hi! Thanks Wilba! OK! I may to ask more PCB photos... (base PCB bottom,control surface PCB bottom) :rolleyes: Question again: 'E1' rotary encoder only or encoder + switch? (Part list: E1 -> 16mm detented rotary encoder, PCB footprint -> rotary encoder + switch...)
  7. Hi! I want ask you... What's dimensions of the case? Will be sometime available schematic? (Sorry, I little speak english...)
