Hi, I want to connect a simple 4 character 5x7 dot matrix display to the core. Problem: To read the datasheet and connect the right Pin's to the J15 core.
For example:
Display datasheet says: Pin4 = A1 Digit select
Pin5 = A0 Digit select
Furthermore, is there a Vcc on the core ?? I only knew Vdd and Vss.
Display Name: Siemens DLG1414
=>Sorry there is no direct link to the datasheet possible. <= I put a PDF as attachment, but there is a link:
Datasheet can be found at www.datasheedarchive.com
Then search for "DLG1414"
Then go to "Datasheet Search Results"
Here you find : DLG1414 Siemens Semiconductors.
Just click the PDF Icon to open the document.
It will be great if someone could help me !!! siemens1414_display.pdf
