109 -
Everything posted by igi
Hi there! I really, really like it!!!!
From the album: igi - MY MB MACHINES
© SWINSID X22
Hi! Like I'm from 18th century!!! Thanks, file is attached. IGI
Hi! Here is pdf. and Eagle PCB file for MIDIBOX SWINSIDx22 pcb. Pcb can be connect directly to core module, just CS line for second SWIN is outside connector. There is not shematic, just Pcb, but is actually MIDIBOX SID module and SWINSID X2 together on same board. Here is some links for original SWIN shematic and newest firmware, witch is really fantastic!!! Swinkels, thanks again!!!!! http://www.swinkels.tvtom.pl/swinsid/ http://www.forum64.de/wbb3/board65-neue-hardware/board288-sid-co/board294-swinsid/33292-swinsid-firmware-updates/index2.html Sound demos comming soon. !!! There is wrong MCU in shematic!!! ATmega8515 should be used, not ATmega8535!!! IGI SWiNX22.pdf SWiNX22.rar
front panel detail -
detail from back side -
fixing PCB's -
CS other side -
CS one side -
four cores, two on bottom, two on top -
Originals!!! -
Aout_LC 2X -
MIDIBOX SWINSID X22 -
side wiev -
Hi ! Every engine has a bit different sound, so all sounds came from same galaxy, but every engine from different planet, so I can make a little different sounds. I really like 6581 sound with external filter.(I use CEM3389) I use 8580 setup for all engines. I will try make some detailed photos from inside.
Hi! The case is actually made from aluminium installation conduit made by ITEM, (http://www.item24.com/en/products/product_groups.html) so can be cut to any length you like.( my is 430 mm). Side caps is also available. Front panel is made with LAZERTRAN (http://www.lazertran.com/products/lazertran_products_original.htm). Really great stuff, but be careful, that only LAZERTRAN for laser printers it can be baked on the surface. My MB SID is complete DIY (even PCB's) and it's stuffed with full CS,two Aout_LC (with unipolar power supply), two 6581, two 858 and, four SWINsids with latest firmvare (not midibox version)with (almost)full compatibility with 8580 (All filter modes, multi state filter, sync and ringmod.) Thanks Swikels!!! Best regards! IGI
Hi all! I just want to thanks T.K. for really great work, and everybody for help and support. My new beast (MB SID) is finished and works really great!!!! Thanks! IGI
left!!! -
right!!! -
MY new beast2!!! -
MY new beast!!! -
Back -
Inner life
