igi
    109
Everything posted by igi
  1. coool! :smile:
  2. igi
    Funky Patch Bank
    HI! I can't upload funkybank into my MBFM with electron C6. (even with 500ms delay time). Patch names is showing on display, but program number is always the same. I can upload "GM" bank with same program without any problem. Anybody can help? Best regards, IGI OH!!! Patches is stored in bank C :smile: And they are great!!!!!!!!!!!!! Thanks, IGI
  3. igi
    DARK MATTER
    WOA!!! That's great news! Now I have to take my Dark matter from dust :) Best regards, IGI
  4. HI! Some pictures from inside MBAY: No, I didn't change program for 20x4 lcd. Just change lcd type from 4x16 to 4x20 in setup. Best regards, IGI
  5. HI! Works great! :rolleyes: Thank you and Best regards, IGI
  6. HI! Thanks for new version, but my MBSEQv4 (lpc core) show that last version is 4.068. I think it is V4.69 (because there is session delete option in main menu), but just checking. MIOS studio also showing V4.68. Another question: Is there a way to change shortcut MENU+SYSEX to shortcut for Euclidean Rhythm Generator?(for dummies :) Thanks and Best regards, IGI
  7. Hi! I'm from Slovenia, so send me PM if you want PIC with bootloader! :thumbsup: Best Ragards, IGI
  8. HI! This Euclidean Rhythm Generator it's great! :frantics: Thanks and Best Regards, IGI
  9. HI! Here is: http://www.forum64.de/wbb3/board65-neue-hardware/board288-sid-co/board294-swinsid/36481-swinsid-atmega88/ Best regards,IGI
  10. Hi! I'm using all 4 tracks for one drum pattern. For example: Trk1: BD Trk2: hihats Trk3: snare Trk4: percussion I like this way for simpler muting/unmuting. :thumbsup: Best Regards, IGI
  11. Hi! I have no such problem with latest firmware (LPC core, V4.058)anymore, but on earlier versions was a lot problems with "hard faults". Latest version works great by my side. Best Regards, IGI
  12. igi
    DARK MATTER
    HI! Same problem also with V2_040 and AoutLC. Best regards, IGI :huh:
  13. igi
    setup V2_040
    O! Thank you! Best regards, IGI Works! :thumbsup: Thanx again.
  14. igi
    setup V2_040
    Hi all! I have problem with compiling midibox SID V2 setup. Problem is just with V2_040, no trouble with earlier versions. look's like this: Microsoft Windows XP [Version 5.1.2600] © Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Igor>cd c:\mios\midibox_sid_v2_040 C:\mios\midibox_sid_v2_040>make rm -rf *.cod *.lst *.err rm -rf *.hex gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_ io -I ./modules/aout setup_6581.asm src/main.inc:25:Warning [209] Missing quote. src/main.inc:25:Error [103] syntax error ./include/asm\macros.h:188:Error [113] Symbol not previously defined (MBSID_VERS ION_STR). make: *** [setup_6581.hex] Error 1 C:\mios\midibox_sid_v2_040> Thanx in advance and Best Regards, IGI
  15. HI! Works's great! :thumbsup: ,but.... ....a lot to learn (again)!!! Thanks TK, just great :flowers: Best regards, IGI
  16. HI! Same problem like Param1. I use winXP 32bit. Ctrlr 934. I can access SID1, Lead engine... with arrow keys, but not with mouse.(is the same on MBFM editor). But MBFM editor workin good, MBSID editor almost not working for me. Best regards, IGI I have 833 stable version on HD, but not working.
  17. Hi! Great, but I have some problem again. When I receive patch from MBFM then operator waveforms and patch name is not displayed on editor. I also cant't change patch name from editor. Everything else works fine. I'm using winXP, and Windows stable version Revision: 934. Best regards, IGI
  18. Hi! Good news! :twitch: Seems everything is working fine. No problems with Sysex, No problems with "Hard foults", No problems with note lenght!(I have this problems just with V4.057.Earlier versions OK, V4.057_3 OK :thumbsup: ) Thanks TK, for this really great Sequencer and for your help and support!!! :flowers: Best Regards,IGI
  19. Hi! Here is another problem with MBSEQ V4 (LPC core, V4.057) Note length in editor is not working. Recording is OK, but in edit mode length has no effect. And as I was mentioned before, there is still some problem with sending sysex through SEQ. (all that works fine on V4.055. I don't know about V4.056, because I can't test this version. Reason? Hard fault at PC.....) Best regards, IGI
  20. igi
    DARK MATTER
    Hi! At least I foud some time to test Aout module, but with same results like Strophlex. I get 0 to 6,1 V with external controller volume control or with "Knob assigement to volume. With EG or LFO i get just 0 to 3,02V. (All depth's set to full (127)) So, problem is not in Aout or AoutNG module, but I also think in software. Best regards, IGI
  21. Hi! I have strange problem with sending sysex thru MBseq V4 (LPC core,V4.057) I cannot access MB SID with MIOS studio via router on MBseq4. When I start MIOSstudio MBSID is reboot and I have no response from core. I also try sending sysex to other devices, but nothing happend. If I try send some sysex to MBseq and back to midiOX then sysex is displayed. Everything works normally with another midi interface. Work's that way normally before V4.057. Any Ideas? Thanx and Best Regards, IGI
  22. Yes, just 5V.
  23. igi
    DARK MATTER
    HI! I have MBSID almost a year now, but I didn't know that I can adjust modulation depth. :whistle: (please, don't call me stupid :)) This box is really full of nice surprises! I can't test right now, but if TK say so, then should work. :thumbsup: I will report next week about results. TK, many thanks for your support!!! Best Regards, IGI
  24. Hi! Try burn bootloader again if you have PIC burner. Then upload some "trusty" firmware to test the pic. That's works for me with similar problem. Check also midi connection. Best regards, IGI
  25. igi
    DARK MATTER
    HI! @nebula: VCA voltage for CEM3394 is 0 to 4V. Problem is not CEM, but voltage from Aout. Yes, CEM sound is really nice :thumbsup: I also have some problem with pitch voltage stability. (not because MBSID) @strophlex: same problem with LFO's, but EG full voltage range for VCA is must. I cannot live without it. :wacko: We still waiting for TK!(I think :) Best regards, IGI
