gianluki
    7
Everything posted by gianluki
  1. I'm working with a direct USB connection from the Core (LPC1769) to the mac. But one more thing to have to know :smile: !!! thanks!!!! cheers gianluki
  2. Doneee!!!! thanks a lot for the link!!...more then usefull!!!..I don't tell you how many "key" words I tryed before you came with the right link. I'm able again to re-upload an application, as personal experience (Mac user), I notice that the sequence of "powering off-on" the core and "quit-open" the Mios Studio software influence a lot the success of this procedure...I got the concept of "how it works"...but I had to try/repeat it different times until it really worked :smile:....or maybe Im just too newbie :smile: . thanks again! best regards gianluki
  3. Hello, I'm stocking on the same problem... A bit embarassing but...could you explain me how to do that please? I mean, what is the "bootloader hold strap"? Right now I have the "NG application" installed, I tryed to upload a new application but it always appear the same message like you, even when I try to upload the "bootloader update v01.010, do I need another software aside Mios Studio to "reset" it? Should I go back to the LPC Expresso starting procedure? thanks in advance best regards gianluki
  4. I don't know how to check it.. :ermm: I run the file serching it through the finder and then double clicked on it....here a copy of my terminal msg...which automatically opened after double-clicking on the file TermMsg-anegcc.txt I also found a similiar one called "arm-none-eabi-gcc-4.5.1"..run it by double clicking...and got the same msg like for the "normal" one. I was also tryng to repeat the process on a Windows Xp machine...in that case I get blocked in the step: "Under User variables, select the variable 'PATH' and click 'Edit' My user variables just have 2 strings, one is called TMP...the other I don't remember...but sure nothing which start with PATH.. Again, really thanks a lot in advance to all of you which are supporting me! I really hope that after this problem...I will start to use the forum to support too...of course with other skills I have..ehehehe gianluki
  5. Hello and really thanks all for your support! For Shuriken: I did it,I checked my path and seems ok ...I even see the file arm-none-eabi-gcc but nothing work,always the same error message I did all the process again just right now, Toolchain freshly dowloaded,etc..but nothing changed, still missing that file, even if its there.TermErrMsg3.txt Any suggestion? from my side... I just feel soo stupid but I really don't know what is wrong. Thanks again to all of you. gianluki
  6. Hi Phil, and thanks for your support! Yes at that time I did it, but to be sure, I deleted everything and I'm repeating the installation now again...in real time :)...I will just jump the part concerning the "svn" command which I already did following the tutorial at "rubyrobot.org". Step by step: I create the "svn" directory and went in with cd svn I moved Inside this directory and checkout the repository After his process, I got the msg "Checked out revision 1351" Now, my mios32 folder is inside the svn folder I created before Downloaded the toolchain,extracted and moved it under svn/mios32/trunk Tested with the example "export MIOS32_PATH=~/svn/mios32/trunk" and the echo.. Set up the path variables...in my case I would like to use the LPC17 so I exported this "export PATH=$PATH:/usr/local/mios32_toolchain/bin"...and then the others from the lpc17 group at the bottom of the tutorial page. Tryed to run the tutorial... Got another..new error...see my "terminal" text file I attached... :cry: TermErrMsg2.txt The different things I did during these steps was to delete the empty "include" and "bin" folders before I moved the mios32 toolchain under svn/mios32/trunk.....I think my mac overwrite the folders...result...they where then empty...no common.mk file inside...now is there :) At this point looks like I should not have anymore the problem with the make file...but something with the "arm-none-eabi-gcc" folder. Any tips please? thanks a lot and sorry for my English. gianluki
  7. Hello everybody, First of all, I'm not a beginner programmer....more :) . I was trying to setup and install the toolchain following the tutorial I found here Mios32Mac but unfortunately at the end of the setup, I tryed to run the Tutorial (midi_forw) with a nice, bad surprise. I attached a txt file of my terminal error msg...hope it can help TermErrMsg.txt I was searching a bit on the forum but I found topics more for Windows user..I have a Mac Os X 10.6 system. Really hope in your help! thanks in advance greetings gianluki
