Grizz and I are having a few issues with switching patterns while playing live and I can't seem to solve the issue with the Manual alone.
We have a session that has two patterns:
Pattern A is pattern with a track with a length of 12 and a track length of 24. (Essentially, a 3/4 musical phrase with varying measure lengths.)
Pattern B is a pattern with a track with a length of 8, a 3 tracks with a length of 32. (A 4/4 phrase with varying measure lengths.)
The time of transition between these two is improvised because we are playing along with two percussionists. So we typically just use the Mute Menu and Pattern Menu when playing live and that works fantastically. What we realized was happening was when we transitioned between the two patterns the step count would be as such:
Pattern A: 1,2,3...22,23,24, Pattern B: 25,26,27...31,32,1,2,3...
instead of:
Pattern A: 1,2,3...22,23,24, Pattern B: 1,2,3,4...32,1,2...
So that if you were to play the sequences on a keyboard you would be playing in 3/4 and then begin a phrase in 4/4 at the beginning of that phrase instead of near the middle as the SEQ is playing it.
After spending a bunch of time reading the manual and playing with the Options Menu Sync to Change and Sync to Measure in the Clock Divider, I enabled Sync to Measure on all the tracks in both patterns. This created the transition desired and Pattern B began "on the 1" instead of the 13, however it made it so that all of the tracks that were previously 32 steps long are cropped to 24. Also not desirable. If I take Sync to Measure off of Pattern B's tracks it acts the way described above, with the phrase beginning on 13.
Is there as way to have the Step Number reset to 1 upon a Pattern transition for all Tracks regardless of Sync to Change or Sync to Measure? Because at the moment the transition (whether manually timed (by us counting down) or by Sync to Change) is just starting on Step 13 unless the Sync to Measure is engaged and that creates new issues.
I don't know if there's an existing solution already or if it is possible for each individual pattern have a separate, savable "Pattern: X Steps" under the Options menu in future versions?
Any help is tremendously appreciated. It is sort of a confusing problem (or it was for us at first) so I'd be happy to upload some audio if that would explain it better.
Thanks.
-Scott
