maxx11
    6
Everything posted by maxx11
  1. looks like it might be a bad uln2803, new ones on order
  2. I have a core and 2 DOUT modules to midify a band organ. When the core is powered up midi note 45 is always on ( LED shows 1|note C_2 Oo) With no midi input connected to the core the note is on, if I connect my midi file player and play a tune it will play all notes just fine BUT midi 45 will always be on. Any suggestions please? I'm stumped.
  3. Thanks Tim for the clarification on the DOUT board. Wellll I connected the ULNs to ground and +12 common ( pins 9 & 10 ) and DOUT Vs to ground. All pipes play BUT there are always 2 that don't,always different ones. At first group 7 D4 and D7 were dead. Tested with LED's and reconnected and they worked,but then group 6 D6 and D7 were dead. Checked with LED's, reconnected and they worked but 2 others were out. Maybe it's a software bug and I need to reload? Occasionally a note will not turn off when hitting stop. A pause command will usually do it. Don't know if it is midio or my player. Will have to hook up my LCD to the core and see if I can see anything. Any suggestions? Thanks!
  4. Thanks Lyle, was going to try this today but got more confused, using a DOUT board from smashtv but don't see any connections for pins 9 and 10 of the uln which is mounted on the board. There is a Vs pin on the J3-6 output connectors but I read .7 volts between this pin and power supply ground. Is it ok to tie the Vs pins from J3-6 to supply ground? Thanks for your help!
  5. More info: core 8 with 18F452 PIC,ULN's mounted on DOUT board, relays and core powered separately from a 12 volt motorcycle battery, relays are 90 ohm 133ma at 12 volts,each relay has a flyback diode and series diode to isolate 2 ranks. Tried a couple of things: moved the outputs of DOUT group 3 01,02,04 05 that didn't work to group 4 01,02,04 05 and sent each a midi signal separately and they worked, tried again and they didn't work. Some,but not all, of the outputs feed 2 relays each with a separate +12 common buss. For now these are tied together, I will see what happens if I remove one, but since some of the outputs that don't work only feed 1 relay I can't see that it would make a difference. Thanks for your help.
  6. I am building a band organ with a core and 2 DOUT modules feeding relays thru uln2803a's. The midi in is fed from a palm vx running ittymidi software. When first tested with a song not all notes played.I have a midi file where you can play each note separately and found 10 midi channels not firing(out of 64). I disconnected everything and hung LED's on the DOUT outputs. When I send a midi note signal from the player,the respective LED lights for each channel, so this should be telling me that everything is working correctly? I have a LCD connected to the core and when I send a note (say C) the LCD shows note C. So I hook everything back up and send single note commands to the organ relays as I did with the LED's,only again I have 10 or 12 channels not firing,some the same as not firing previously, some different. I hook the LED's back up to the channels that are not firing and they light right up. Any suggestions? I am totally confused. One other issue is that the LED's sometimes don't turn off when I hit stop but I think that my player is not always sending a note off command. Appreciate any help you can give me. Thanks.
