I am still new to sammichSID. I am not sure how to play the two SIDs in a multi-timbral mode across different MIDI channels.
Reading the manual online, I found the explanation of "instruments" and "channels" confusing. It lists three instruments: "lead", "bassline", and "drum". Then it says that the fourth instrument is "multi" where all six instruments are used. But only see three possible instruments.
By default, Instrument 1 was set to channel 1. All the other instruments are disabled.
So if I set up in my custom ensemble E002 the following:
INS 1 CHN 1
INS 2 CHN 2
INS 3 CHN 3
INS 4 CHN --
But when I send MIDI data out of channel 2 and 3, nothing happens. Channel 1 sends output and I can hear audio. The way the manual reads, channel 2 should be triggering the Bass instrument, and channel 4 should be triggering the drum instrument, but I don't get either - just response from sending MIDI out from sequencer to sammichSID.
Also, a point of clarification, my sammichSID lists only SID1 as available ( "1***" ), though I have two 8580s installed.
Thanks
