97 -
6
Everything posted by ksir
I don't know if this is suitable: https://a.aliexpress.com/_EGKO7CC
From the album: ModulBox Ng V2
Can I have access to edit the wiki? I would like to complete this page: http://wiki.midibox.org/doku.php?id=mb-modulbox-ng THANKS
I now have to manage to turn off and on the rgbled under the switches. I succeeded with something like:
I understood I have to use set_active . I managed to make it work on encoder and push button set_active (id)ENC:10 1 set_active (id)BUTTON:117 1 I didn't succeed on Ainser, I tried: set_active (id)AINSER:133 1 #EDIT: There were errors in my code. It works now. The code below works
Good morning SetBankOfHwId only works on encoders? I tried on fader and Switch without result
J'ai approfondi mes tests. Si je ne connecte pas l'alimentation externe, je n'ai pas de problème avec le clignotement des LED. si j'ajoute de l'alimentation les LED clignotent voici comment je branche l'alimentation : (après avoir déconnecté le j17) le câblage est-il correct ? j'ai lu ici : http://www.ucapps.de/midibox_ng_manual_hw.html dois-je connecter j4.vs à une alimentation 0V ? et j4b.5v à 5v psu ? ( i use this PSU : https://secure.reichelt.com/fr/fr/bloc-d-alimentation-d-coupage-ferm-50-w-5-v-10-a-mw-lrs-50-5-p202960.html?&trstct=pol_4&nbc=1 )
I tried adding a 10uf capacitor every 128 LEDs. I tried to connect dout of the last led to gnd. I tried to connect the end of the last LED to a 120 homs resistor. the last LEDs still flicker ( just for information I specify that I modified mios32\apps\controllers\midibox_ng_v1\src\mbng_rgbled.c line 116 : u32 num_leds = 15; // TODO: we could make this configurable! )
hello, I use my controller with fl studio with which it is possible to create python scripts. https://www.image-line.com/fl-studio-learning/fl-studio-online-manual/html/midi_scripting.htm I have already tried with a small script which allows you to create a “learn” mode Would it be possible to display the name of the parameter that I can retrieve with "getParamName" to display them on the screens of my midibox ng? I think that fl studio's python scripts can be a very powerful tool combined with midibox ng. but I have no other idea of what could be interesting. If you have any suggestions thank you # name=ModulBox # définir les variables # Importer les modules nécessaires pour utiliser les fonctionnalités de FL Studio import midi import device import playlist import channels import mixer import patterns import arrangement import ui import transport import plugins import general import launchMapPages # Définir le numéro du contrôleur MIDI que vous souhaitez utiliser pour le bouton Learn BoutonLearn = 31 # Initialiser la variable Mode_Learn avec une valeur booléenne, Cette variable indique si le mode Learn est actif ou non ModeLearn = False # Fonction appelée lorsqu'un message MIDI est reçu par FL Studio def OnMidiMsg(event): # Utiliser la variable globale Mode_Learn dans la fonction OnMidiMsg global ModeLearn # Indiquer que l'événement n'a pas encore été traité event.handled = False # Afficher des informations sur l'événement MIDI reçu print('MidiId: ', event.midiId, 'EventData1: ', event.data1, 'eventData2: ', event.data2,'eventMidiChan', event.midiChan, 'eventMidiPort: ', event.port) # Si l'événement correspond à l'appui sur le bouton Learn, activer ou désactiver le mode Learn en fonction de la valeur de l'événement if event.data1 == BoutonLearn and event.data2 == 127: ModeLearn = True print(ModeLearn,"Mode Learn actif.") elif event.data1 == BoutonLearn and event.data2 == 0: ModeLearn = False print(ModeLearn,"Mode Learn Inactif.") # Si la valeur de l'événement est supérieure à 0 et que le mode Learn est actif, lier le dernier paramètre modifié au contrôleur MIDI utilisé et désactiver le mode Learn if event.data2 >0 and ModeLearn==True and event.data1 != BoutonLearn: # Utiliser la fonction device.linkToLastTweaked() avec les arguments appropriés device.linkToLastTweaked(event.data1, event.midiChan+1,) ModeLearn = False #test extinction led #device.midiOutMsg(176, event.midiChan, BoutonLearn, 0) device.midiOutMsg(176, 15, BoutonLearn, 0) print(ModeLearn,"Mode Learn Inactif.") # Indiquer que l'événement a été traité par le script en mettant la valeur de event.handled à True event.handled = True # Indiquer que l'événement a été traité par le script en mettant la valeur de event.handled à True #event.handled = True ''' '''
Hello, first of all thank you for your previous answers. I haven't fixed the problem with the pads yet. I'm focusing on another problem for now: with the LED rings. with 16 led ring of 16 led no problem. when I add more, the LEDs flicker. https://youtu.be/HyLkVeFtALw?si=gT09lbCxEwLRmHt8 I read here: http://midibox.org/forums/topic/21095-lre-4x1-breakable-rgb-led-ringrotary-encoder-pcb-bulk-order/?do=findComment&comment=184155 FantomXR had flickering problems, solved with a 10uf capacitor. Should I add a 10uf capacitor at the input of my LED ring cards? (as in the image below) (C129) To understand my configuration see the pdfs: LEDRING: https://drive.google.com/file/d/1XpDQBUE42IqXpXicO--B2gfIoNQDh5ga/view?usp=drive_link “power card”: https://drive.google.com/file/d/1NJ-H-QXD-tl9rU6nbYdEh2Q4jFqjWt6b/view?usp=drive_link I made a PCB that I call a “power card” that I supply with 5v 10 amps. The J2 connector of the "power card" is connected to J4b of core 32. Connector J44 of the first OLED card is connected to J3 of the “power card” Connector J45 of the first OLED card is connected to J4 of the “power card” Connector J44 of the second OLED card is connected to J5 of the “power card” Connector J45 of the second OLED card is connected to J6 of the “power card” etc.. Thank you
