ksir
    97
    6
Everything posted by ksir
  1. ksir
    Ssd1322
    THANKS . I don't understand the interconnection diagram clearly. My screen has 16 pins not 20 pins and the name of the pins on the seller's diagram does not correspond. hence my confusion ( https://fr.aliexpress.com/item/32414142892.html?gatewayAdapt=glo2fra ) I just tried to match : it's ok ? i can't fide GLCD_SSD1322
  2. ksir
    Ssd1322
    Hello, I have a tw56640320b03 screen, is it possible to make it work with midibox ng? THANKS https://s.alicdn.com/@sc01/kf/HTB19t6LcXkoBKNjSZFkq6z4tFXa3/232025343/HTB19t6LcXkoBKNjSZFkq6z4tFXa3.jpg
  3. I am interested in the 2 white ones with push button
  4. ksir
    Modul Box NG V2
    thank you for your help I tried : #PADS EVENT_BUTTON id= 65 hw_id= 33 fwd_id=RGBLED:137 type=CC chn= 1 cc= 33 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 66 hw_id= 35 fwd_id=RGBLED:138 type=CC chn= 1 cc= 34 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 67 hw_id= 37 fwd_id=RGBLED:139 type=CC chn= 1 cc= 35 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 68 hw_id= 39 fwd_id=RGBLED:140 type=CC chn= 1 cc= 36 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 EVENT_BUTTON id= 69 hw_id= 34 fwd_id=RGBLED:141 type=CC chn= 1 cc= 37 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 70 hw_id= 36 fwd_id=RGBLED:142 type=CC chn= 1 cc= 38 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 71 hw_id= 38 fwd_id=RGBLED:143 type=CC chn= 1 cc= 39 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 72 hw_id= 40 fwd_id=RGBLED:144 type=CC chn= 1 cc= 40 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 #PADS EVENT_BUTTON id= 73 hw_id= 41 fwd_id=RGBLED:129 type=CC chn= 1 cc= 41 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 74 hw_id= 43 fwd_id=RGBLED:130 type=CC chn= 1 cc= 42 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 75 hw_id= 45 fwd_id=RGBLED:131 type=CC chn= 1 cc= 43 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 76 hw_id= 47 fwd_id=RGBLED:132 type=CC chn= 1 cc= 44 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 EVENT_BUTTON id= 77 hw_id= 42 fwd_id=RGBLED:133 type=CC chn= 1 cc= 45 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 78 hw_id= 44 fwd_id=RGBLED:134 type=CC chn= 1 cc= 46 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 79 hw_id= 46 fwd_id=RGBLED:135 type=CC chn= 1 cc= 47 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 80 hw_id= 48 fwd_id=RGBLED:136 type=CC chn= 1 cc= 48 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 doesn't seem to work
  5. ksir
    Modul Box NG V2
    Hello, I haven't studied your answer in depth yet, but here is an example of declaration of my pads in ngc file #PADS EVENT_BUTTON id= 33 fwd_id=RGBLED:137 hsv=50:100:10 type=CC chn= 1 cc= 33 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 35 fwd_id=RGBLED:138 hsv=100:100:10 type=CC chn= 1 cc= 35 button_mode=Toggle label="^std_btn"
  6. ksir
    Modul Box NG V2
    Hello, I have a rebound problem with the sparkfun pads, do you have an idea how to fix this? Hardware? Software ? Thanks The rest works fine
  7. ksir
    Modul Box NG V2
    yes all encoders work, after having pushed the tests a little, I have the impression that it is the accent (é) in the comments of my code which poses a problem and erases lines at the end of my ngc file
  8. ksir
    Modul Box NG V2
    Thank you again for your help I tried : # encode hardware configuration ENC n= 16 sr= 4 pins=5:4 type=non_detented ENC n= 15 sr= 4 pins=7:6 type=non_detented ENC n= 2 sr= 1 pins=1:0 type=non_detented ENC n= 1 sr= 1 pins=3:2 type=non_detented ENC n= 4 sr= 1 pins=5:4 type=non_detented ENC n= 3 sr= 1 pins=7:6 type=non_detented ENC n= 6 sr= 2 pins=1:0 type=non_detented ENC n= 5 sr= 2 pins=3:2 type=non_detented ENC n= 8 sr= 2 pins=5:4 type=non_detented ENC n= 7 sr= 2 pins=7:6 type=non_detented ENC n= 10 sr= 3 pins=1:0 type=non_detented ENC n= 9 sr= 3 pins=3:2 type=non_detented ENC n= 12 sr= 3 pins=5:4 type=non_detented ENC n= 11 sr= 3 pins=7:6 type=non_detented ENC n= 14 sr= 4 pins=1:0 type=non_detented ENC n= 13 sr= 4 pins=3:2 type=non_detented It's encoder 13 that didn't work anymore I moved the encoder hardware config code to the middle of the code, instead of putting it at the end, now it works
  9. ksir
    Modul Box NG V2
    Unable to operate encoder #15 he is detected by mios studio but he answers me: not event assigned, yet I seem to have configured it like the other 15 which works well... Thanks for your help #Modulbox RESET_HW # le SCS doit émuler les fonctions bouton/enc dans la page principale SCS soft1_button_emu_id=2000 \ soft2_button_emu_id=2001 \ soft3_button_emu_id=2002 \ soft4_button_emu_id=2003 \ shift_button_emu_id=2004 \ enc_emu_id=2000 # Contrôlé à partir des boutons SCS à J10 dans la page principale EVENT_BUTTON id=2000 type=Meta meta=SetBank button_mode=OnOnly range=1:1 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2001 type=Meta meta=SetBank button_mode=OnOnly range=2:2 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2002 type=Meta meta=SetBank button_mode=OnOnly range=3:3 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2003 type=Meta meta=SetBank button_mode=OnOnly range=4:4 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2004 type=Meta meta=EncFast:4 button_mode=OnOff range=2:0 # l'encodeur SCS en J10 incrémente/décrémente simplement la banque # fonction redondante - pourrait être modifiée à l'avenir EVENT_ENC id=2000 type=Meta meta=SetBank range=1:4 # le but de cet élément EVENT est d'imprimer la banque chaque fois que l'écran LCD est rafraîchi (par exemple après le démarrage ou le changement de banque) EVENT_LED id=2000 fwd_to_lcd=1 lcd_pos=1:1:2 label="Bank #%q" # ENC 1 - 8 /////////////////////////////////////////////////// # Classical Thermometer Pattern, Jaune #EVENT_ENC id= 1 hw_id = 1 bank=1 fwd_id=RGBLED:2 rgbled_pattern=1 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 # label="ENC #%3i %3d@(1:1:2)%B" # ENC 1 Moving Dot ,jaune EVENT_ENC id= 1 hw_id = 1 bank=1 fwd_id=RGBLED:2 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 1 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 2 Moving Dot , Green EVENT_ENC id= 2 hw_id = 2 bank=1 fwd_id=RGBLED:18 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 2 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 3 Moving Dot , RED EVENT_ENC id= 3 hw_id = 3 bank=1 fwd_id=RGBLED:34 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 3 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 4 Moving Dot , Blue EVENT_ENC id= 4 hw_id = 4 bank=1 fwd_id=RGBLED:50 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 4 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 5 Moving Dot Jaune EVENT_ENC id= 5 hw_id = 5 bank=1 fwd_id=RGBLED:66 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 5 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 6 Moving Dot GREEN EVENT_ENC id= 6 hw_id = 6 bank=1 fwd_id=RGBLED:82 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 6 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 7 Moving Dot RED EVENT_ENC id= 7 hw_id = 7 bank=1 fwd_id=RGBLED:98 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 7 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 8 Moving Dot BLUE #label="Enc%3i&k@(1:4:6)%B&n@(1:19:5)%3d" EVENT_ENC id= 8 hw_id = 8 bank=1 fwd_id=RGBLED:114 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 8 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 9-16 ///////////////////////////////////////////////////////// # Moving Dot Jaune EVENT_ENC id= 9 hw_id = 9 bank=1 fwd_id=RGBLED:146 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 9 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot GREEN EVENT_ENC id= 10 hw_id = 10 bank=1 fwd_id=RGBLED:162 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 10 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot RED EVENT_ENC id= 11 hw_id = 11 bank=1 fwd_id=RGBLED:178 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 11 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot BLUE EVENT_ENC id= 12 hw_id = 12 bank=1 fwd_id=RGBLED:194 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 12 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot Jaune EVENT_ENC id= 13 hw_id = 13 bank=1 fwd_id=RGBLED:210 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 13 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot GREEN EVENT_ENC id= 14 hw_id = 14 bank=1 fwd_id=RGBLED:226 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 14 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot RED EVENT_ENC id= 15 hw_id = 15 bank=1 fwd_id=RGBLED:242 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 15 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot BLUE EVENT_ENC id= 16 hw_id = 16 bank=1 fwd_id=RGBLED:258 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" #bouton poussoir encodeurs 1 EVENT_BUTTON id= 66 fwd_id=RGBLED:1 hsv=00:100:10 type=CC chn= 1 cc= 17 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 65 fwd_id=RGBLED:17 hsv=0:100:10 type=CC chn= 1 cc= 18 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 68 fwd_id=RGBLED:33 hsv=0:100:10 type=CC chn= 1 cc= 19 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 67 fwd_id=RGBLED:49 hsv=0:100:10 type=CC chn= 1 cc= 20 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 70 fwd_id=RGBLED:65 hsv=0:100:10 type=CC chn= 1 cc= 21 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 69 fwd_id=RGBLED:81 hsv=0:100:10 type=CC chn= 1 cc= 22 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 72 fwd_id=RGBLED:97 hsv=0:100:10 type=CC chn= 1 cc= 23 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 71 fwd_id=RGBLED:113 hsv=0:100:10 type=CC chn= 1 cc= 24 button_mode=Toggle label="^std_btn" #bouton poussoir encodeurs 2 EVENT_BUTTON id= 74 fwd_id=RGBLED:145 hsv=00:100:10 type=CC chn= 1 cc= 25 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 73 fwd_id=RGBLED:161 hsv=0:100:10 type=CC chn= 1 cc= 26 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 76 fwd_id=RGBLED:177 hsv=0:100:10 type=CC chn= 1 cc= 27 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 75 fwd_id=RGBLED:193 hsv=0:100:10 type=CC chn= 1 cc= 28 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 78 fwd_id=RGBLED:209 hsv=0:100:10 type=CC chn= 1 cc= 29 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 77 fwd_id=RGBLED:225 hsv=0:100:10 type=CC chn= 1 cc= 30 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 80 fwd_id=RGBLED:241 hsv=0:100:10 type=CC chn= 1 cc= 31 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 79 fwd_id=RGBLED:257 hsv=0:100:10 type=CC chn= 1 cc= 32 button_mode=Toggle label="^std_btn" #PADS EVENT_BUTTON id= 33 fwd_id=RGBLED:137 hsv=50:100:10 type=CC chn= 1 cc= 33 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 35 fwd_id=RGBLED:138 hsv=100:100:10 type=CC chn= 1 cc= 35 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 37 fwd_id=RGBLED:139 hsv=0:100:10 type=CC chn= 1 cc= 37 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 39 fwd_id=RGBLED:140 hsv=200:100:10 type=CC chn= 1 cc= 39 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 34 fwd_id=RGBLED:141 hsv=50:100:10 type=CC chn= 1 cc= 34 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 36 fwd_id=RGBLED:142 hsv=100:100:10 type=CC chn= 1 cc= 36 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 38 fwd_id=RGBLED:143 hsv=0:100:10 type=CC chn= 1 cc= 38 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 40 fwd_id=RGBLED:144 hsv=200:100:10 type=CC chn= 1 cc= 40 button_mode=Toggle label="^std_btn" #PADS EVENT_BUTTON id= 41 fwd_id=RGBLED:129 hsv=50:100:10 type=CC chn= 1 cc= 41 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 43 fwd_id=RGBLED:130 hsv=100:100:10 type=CC chn= 1 cc= 43 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 45 fwd_id=RGBLED:131 hsv=0:100:10 type=CC chn= 1 cc= 45 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 47 fwd_id=RGBLED:132 hsv=200:100:10 type=CC chn= 1 cc= 47 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 42 fwd_id=RGBLED:133 hsv=50:100:10 type=CC chn= 1 cc= 42 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 44 fwd_id=RGBLED:134 hsv=100:100:10 type=CC chn= 1 cc= 44 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 46 fwd_id=RGBLED:135 hsv=0:100:10 type=CC chn= 1 cc= 46 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 48 fwd_id=RGBLED:136 hsv=200:100:10 type=CC chn= 1 cc= 48 button_mode=Toggle label="^std_btn" #switch # SWITCH BANK 1 EVENT_BUTTON id=101 hw_id = 57 bank=1 fwd_id=LED:8 type=CC chn= 1 cc= 49 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=102 hw_id = 58 bank=1 fwd_id=LED:7 type=CC chn= 1 cc= 50 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=103 hw_id = 59 bank=1 fwd_id=LED:6 type=CC chn= 1 cc= 51 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=104 hw_id = 60 bank=1 fwd_id=LED:5 type=CC chn= 1 cc= 52 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=105 hw_id = 61 bank=1 fwd_id=LED:4 type=CC chn= 1 cc= 53 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=106 hw_id = 62 bank=1 fwd_id=LED:3 type=CC chn= 1 cc= 54 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=107 hw_id = 63 bank=1 fwd_id=LED:2 type=CC chn= 1 cc= 55 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=108 hw_id = 64 bank=1 fwd_id=LED:1 type=CC chn= 1 cc= 56 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=109 hw_id = 49 bank=1 fwd_id=LED:16 type=CC chn= 1 cc= 57 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=110 hw_id = 50 bank=1 fwd_id=LED:15 type=CC chn= 1 cc= 58 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=111 hw_id = 51 bank=1 fwd_id=LED:14 type=CC chn= 1 cc= 59 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=112 hw_id = 52 bank=1 fwd_id=LED:13 type=CC chn= 1 cc= 60 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=113 hw_id = 53 bank=1 fwd_id=LED:12 type=CC chn= 1 cc= 61 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=114 hw_id = 54 bank=1 fwd_id=LED:11 type=CC chn= 1 cc= 62 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=115 hw_id = 55 bank=1 fwd_id=LED:10 type=CC chn= 1 cc= 63 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=116 hw_id = 56 bank=1 fwd_id=LED:9 type=CC chn= 1 cc= 64 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" aINSER n= 1 enabled=1 muxed=1 cs=0 resolution=7bit aINSER n= 2 enabled=0 muxed=1 cs=1 resolution=7bit # AINSER BANK 1 EVENT_AINSER id= 125 hw_id = 1 bank=1 type=CC chn= 1 cc= 65 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 126 hw_id = 2 bank=1 type=CC chn= 1 cc= 66 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 127 hw_id = 3 bank=1 type=CC chn= 1 cc= 67 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 128 hw_id = 4 bank=1 type=CC chn= 1 cc= 68 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 129 hw_id = 5 bank=1 type=CC chn= 1 cc= 69 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 130 hw_id = 6 bank=1 type=CC chn= 1 cc= 70 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 131 hw_id = 7 bank=1 type=CC chn= 1 cc= 71 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 132 hw_id = 8 bank=1 type=CC chn= 1 cc= 72 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 133 hw_id = 9 bank=1 type=CC chn= 1 cc= 73 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 134 hw_id = 10 bank=1 type=CC chn= 1 cc= 74 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 135 hw_id = 12 bank=1 type=CC chn= 1 cc= 75 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 136 hw_id = 13 bank=1 type=CC chn= 1 cc= 76 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 137 hw_id = 14 bank=1 type=CC chn= 1 cc= 77 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 138 hw_id = 15 bank=1 type=CC chn= 1 cc= 78 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 139 hw_id = 16 bank=1 type=CC chn= 1 cc= 79 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 140 hw_id = 17 bank=1 type=CC chn= 1 cc= 80 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 141 hw_id = 18 bank=1 type=CC chn= 1 cc= 81 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 142 hw_id = 19 bank=1 type=CC chn= 1 cc= 82 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 143 hw_id = 20 bank=1 type=CC chn= 1 cc= 83 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 144 hw_id = 21 bank=1 type=CC chn= 1 cc= 84 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 145 hw_id = 22 bank=1 type=CC chn= 1 cc= 85 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 146 hw_id = 23 bank=1 type=CC chn= 1 cc= 86 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 147 hw_id = 24 bank=1 type=CC chn= 1 cc= 87 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 148 hw_id = 25 bank=1 type=CC chn= 1 cc= 88 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 149 hw_id = 26 bank=1 type=CC chn= 1 cc= 89 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 150 hw_id = 27 bank=1 type=CC chn= 1 cc= 90 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 151 hw_id = 28 bank=1 type=CC chn= 1 cc= 91 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 152 hw_id = 29 bank=1 type=CC chn= 1 cc= 92 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 153 hw_id = 30 bank=1 type=CC chn= 1 cc= 93 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 154 hw_id = 31 bank=1 type=CC chn= 1 cc= 94 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 155 hw_id = 32 bank=1 type=CC chn= 1 cc= 95 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 156 hw_id = 33 bank=1 type=CC chn= 1 cc= 96 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 157 hw_id = 34 bank=1 type=CC chn= 1 cc= 97 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 158 hw_id = 35 bank=1 type=CC chn= 1 cc= 98 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 159 hw_id = 36 bank=1 type=CC chn= 1 cc= 99 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 160 hw_id = 37 bank=1 type=CC chn= 1 cc= 100 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 161 hw_id = 38 bank=1 type=CC chn= 1 cc= 101 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 162 hw_id = 39 bank=1 type=CC chn= 1 cc= 102 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 163 hw_id = 40 bank=1 type=CC chn= 1 cc= 103 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" # encoder hardware configuration ENC n= 2 sr= 1 pins=1:0 type=non_detented ENC n= 1 sr= 1 pins=3:2 type=non_detented ENC n= 4 sr= 1 pins=5:4 type=non_detented ENC n= 3 sr= 1 pins=7:6 type=non_detented ENC n= 6 sr= 2 pins=1:0 type=non_detented ENC n= 5 sr= 2 pins=3:2 type=non_detented ENC n= 8 sr= 2 pins=5:4 type=non_detented ENC n= 7 sr= 2 pins=7:6 type=non_detented ENC n= 10 sr= 3 pins=1:0 type=non_detented ENC n= 9 sr= 3 pins=3:2 type=non_detented ENC n= 12 sr= 3 pins=5:4 type=non_detented ENC n= 11 sr= 3 pins=7:6 type=non_detented ENC n= 14 sr= 4 pins=1:0 type=non_detented ENC n= 13 sr= 4 pins=3:2 type=non_detented ENC n= 16 sr= 4 pins=5:4 type=non_detented ENC n= 15 sr= 4 pins=7:6 type=non_detented I take this opportunity to share with you a photo of my project
  10. ksir
    Modul Box NG V2
  11. ksir
    Modul Box NG V2
    I use MBHP_CORE_STM32F4. http://www.ucapps.de/mbhp_core_stm32f4.html can i just connect my psu to j2 and remove jumper j17? Is there anything else to consider? Thank you again for your help
  12. ksir
    Modul Box NG V2
    I would need help with the power supply, I want to power at least 264 ws2812b leds, maybe more in the future, several dout modules, in the future surely 8 oled screens, and I'm sure I'm forgetting some. I wonder what power supply to buy and how to connect it.. I thought I would take 5v 10a.. https://secure.reichelt.com/fr/fr/bloc-d-alimentation-d-coupage-ferm-50-w-5-v-10-a-mw-lrs-50-5-p202960.html?&trstct=pol_4&nbc=1 I already have this usb hub: https://secure.reichelt.com/fr/fr/hub-usb-3-0-4-ports-avec-bloc-d-alimentation-en-m-tal-logilink-ua0149-p127833.html?&nbc=1 Thank you for your help
  13. ksir
    Modul Box NG V2
    The project advances
  14. ksir
    Modul Box NG V2
    PCB Module DIN and DOUT: https://drive.google.com/drive/folders/1DXHAs1-3mstAdi4ANFrdSOmo7ZGawffY?usp=sharing
  15. ksir
    Modul Box NG V2
    Thank you for these tips, I modified the files I ordered the uln2803 and the 74HCT1G14GW-Q100H to test the RGB PEL12T encoders, but I haven't managed to solve the problem yet. While waiting to solve the problem with the PEL12T RGB encoders, I developed circuits for the PEC16 encoders that I have in stock. https://drive.google.com/file/d/1HiJ8JmOTWMXAXDr4jsRvSmx43k4zEgOv/view?usp=share_link I also finished the files for the 4x2 silicon sparkfun pads. https://drive.google.com/file/d/1pefRBtEz9XU68osIdfHJXfBManKkIZye/view?usp=share_link I started to document the project https://ksir-diy.blogspot.com/2023/05/modulbox-v2.html?m=1
  16. ksir
    Modul Box NG V2
    potentiometer : https://drive.google.com/file/d/1ThTC36WdYeexnTdHlgVoUhtVUv2OzcR3/view?usp=share_link push button https://drive.google.com/file/d/1pnDtaprQ3Mufdyg4ZW1S13UnAKqt1rC1/view?usp=share_link Fader 1 https://drive.google.com/file/d/1x0nXSRO_pQJPZEVyxlxVWuarjBzKPW2m/view?usp=share_link fader 2 (connect to fader1) https://drive.google.com/file/d/1npn4KlHNovZrZ0nFLKRoN7tZ-Jd0Pf2J/view?usp=share_link all files are here https://drive.google.com/drive/folders/1IZLVG2fVXstxGC9ZCWl0OCMjF7R1GEB3?usp=sharing thanks to you
  17. ksir
    Modul Box NG V2
    Thank you for your involvement in my project. After studying novski's projects https://github.com/novski/Midibox/tree/master/VLR-8Enc It uses an uln2803 for the switches. I reproduced its layout, but I don't really understand how Darlington transistor arrays work. https://drive.google.com/file/d/1EW-IxclCJ1_cOeau-bTUnaOuSZ5eGdsN/view?usp=share_link I will study the solution you propose with 74HC1G14. you are right and will try to take your remarks into account. although I don't have a solution yet. the alps caps are pretty and I couldn't find a smaller equivalent. thank you again for your involvement The encoders and silicon pad modules are far from finished. the other modules are almost ok for me, I should check them again. maybe you can watch this if you want. but if you have little time, I would not like to waste it and keep the time you can give me to really check the modules that I think I have completely finished
  18. ksir
    Modul Box NG V2
    hello, always about 4x2 Enc RGB SW Led ring Rgb I abandoned the idea of a matrix for the rgb leds of the pel12t encoders. this simplifies the diagram. for the common anode I read here: http://midibox.org/forums/topic/20713-how-to-connect-common-anode-rgb-leds/#comment-180389 just connect the cathodes to the DOUT pins. 595s can sink current, which means they "can supply ground/0V". Thus, the output is "reversed" for common anode parts. This can be specified in MB_NG. When the 595 output is high, the LED is off. When low, the LED is on. On the other hand I still do not know how to connect the switch of the pel12t encoders to the 74hc165. normally a switch is connected between VS and D* with its switches the contact is between VD and D*. Is there a way to solve this problem in a software way? should I use a bc547 for example or other hardware solution? another possible solution? https://drive.google.com/file/d/1kLTryPKwxlgYORO9NTeJ00XRjq4Sl2w4/view?usp=share_link Thanks for your help
  19. ksir
    Modul Box NG V2
    The module that gives me the most problem is the 4x2 Enc RGB SW Led ring Rgb https://drive.google.com/file/d/1kLTryPKwxlgYORO9NTeJ00XRjq4Sl2w4/view?usp=share_link I'm trying to use Bourns RGB + Switch Pel12T Encoders https://mou.sr/3zJilbU https://www.mouser.fr/datasheet/2/54/PEL12T-777462.pdf But the wiring diagram of the leds and switches of these encoders is a challenge for me: the RGB LED matrix is also difficult. Maybe it's not possible with a matrix because of the switch ? Help and advice are always welcome. and the lack of space on will also be a PCB challenge, I may be forced to add a third sandwich panel.
  20. ksir
    Modul Box NG V2
    For fun, an overview of the modules already developed and under development
  21. ksir
    Modul Box NG V2
    Thanks It's mostly to look at how you designed it. I would adapt it for the sparkfun 2x2 pads i would like to use it with rgb leds
  22. ksir
    Modul Box NG V2
    Good morning; Thank you very much for your answers and your help which are very precious to me. I tried to correct my files according to your advice. (in the previously shared folder https://drive.google.com/drive/folders/1IZLVG2fVXstxGC9ZCWl0OCMjF7R1GEB3?usp=share_link) (I upgraded to version 7 of kicad). I'm also trying to make a PCB with silicone buttons, (see in the TO_DO folder in the folder I shared) how to create a footprint in kicad for silicone buttons, (like you did here: http://wiki.midibox.org/lib/exe/fetch.php?w=600&tok=c1a13e&media=phatline:blm16x16-pcb-3d-front.jpg) Would you be willing to share your footprint? The files you will find in the TO_DO folder are in progress, full of errors and far from finished .... if you look at them, your advice is always welcome for fun, a vision of what my future controller could look like, disregard the screen at the top right, it could have a series of oled on the top
  23. ksir
    Modul Box NG V2
    here is where I am at the moment: https://drive.google.com/drive/folders/1IZLVG2fVXstxGC9ZCWl0OCMjF7R1GEB3?usp=share_link i am looking for rgb leds it is listed here: http://www.ucapps.de/midibox_ng_manual_hw.html you need an external power supply. how to handle this? Thanks for your help
  24. ksir
    Modul Box NG V2
    thank you for your reply I'm working on it : I noticed you don't like the MEC buttons, I'm looking at the alternatives. maybe cherry switches, I need to find some nice caps (any suggestions?) I want to merge 2 footprints for the potentiometers: (so that I can use different potentiometers) Is this a bad idea? should I connect pads 4 to the -? thank you for your help
  25. Hello, I am currently thinking about a version 2 of my modulbox circuits V1: the objectives are: Have the circuits manufactured by a professional (for example: https://jlcpcb.com/). Have the fronts made by a professional. -Be able to more easily share the circuits created with the community The design rules remain the same: circuits of 50 x 100 mm or 100 x 100 mm max For the potentiometers I used: RK09L1140A2U ( https://www.mouser.fr/ProductDetail/Alps-Alpine/RK09L1140A2U?qs=6EGMNY9ZYDShe59Bf8g9AA%3D%3D ) paid 0.70 euros each at the time, they cost 2.80 euros today, I'm thinking of replacing them with RK09D1130C1B ( https://www.mouser.fr/ProductDetail/688-RK09D1130C1B ) they are cheaper. Do you recommend another model / brand? I'm thinking of trying to make a footprint that accepts several kinds of potentiometers. it's possible ? does it already exist? (I work with kicad) (for caps: https://www.mouser.fr/ProductDetail/Eagle-Plastic-Devices/450-4760?qs=J4wJDGtbthoFgTzq4MR8dw%3D%3D) For the faders I used: RA6020F-10-15F2-B10K ( https://www.mouser.fr/ProductDetail/Alpha-Taiwan/RA6020F-10-15F2-B10K?qs=6TczTpqoAMVgxoAgFDSJ8A%3D%3D ) It may not be the best choice. Do you recommend another model / brand? For the push buttons I used: MEC 3FTH9 https://www.reichelt.de/fr/fr/bouton-multimec-sans-clairage-connecteur-circuit-imprim--taster-3fth9-p156904.html?GROUPID= 7587&SHOW=1&OFFSET=16&&r=1 Do you recommend another model / brand? It also remains to update the standard control surface: I'm also thinking about possibly making a 4 x 2 sparkfun pads with RGB led ( https://www.sparkfun.com/products/7836 ) I still have a lot of work. Anyone interested in this project? People who would like to help me or simply control my work? or do you have any advice or suggestions? Thanks
