40 -
Everything posted by cd_reloaded
Hello, I'm trying to to flash my LPC-1769Expresso-Module but I'm obviously not able to. I downloaded the necessary software from Code Red Technologies. Installation and authorisation went without problems. The trouble starts with the fact that my WindowsXP as well as the CR-programm don't find the new hardware and they are supposed to do so. I run VirtualBox with WindowsXP SP3 on a 27"-iMac under OSX 10.7. – and I did activate the USB connection between VirtualBox and WindowsXP. Does anybody know a solution for the problem? Is it possible to flash a LPC1769 with a system configuration like mine? Thx very much Christian
That's very likely.
Yesyesyes! Looks very clean! Nice colour. I'm really looking forward to having my PCBs in my hands and to get that thing running. Yes, there will be something like a ponoko-case. The Illustrator eps File is already existng. But I plan to built a very simplified case. with no sides, just the front- and the backside made of transparent acrylic material. I will post the file for download as soon as I have my pcbs to judge if everything s alright. If you want to do any modifications on the EPS-File, feel free to do so. I will only do what it thin is needed to fulfill my needs. It will look similar to a little tool I built a few years ago. I will post a picture of it later since I'm in a hurry now ...
The prototype is USB powered and working.
More precise: There is a USB connector on the LPC17 Core board, as you can see on the first picture of this thread. You can use this conection for power supply of the SEQ. If you don't like that you can use a normal external power supply instead. The LPC17 core offers you the possibility you want. As you see on the prototype picture. We use USB as the power connection.
The SEQ is USB-powered as well
Just a little teaser: PCB – work in progress:
Very cool idea! The PCB will be much smaller than the prototype. @ Thorsten: I will be working on the pcb on sundy night. I've got my new Mac. And it works perfecly and its about time to continue that project ....
:thumbsup: I love it! any comments? no? It will be the ultimate live-tool. Think about it: 1 SEQ for 1 Synth. Editing is easier tham a 101 Sequencer and way more flexible and versatile. The aim is to keep it simple and to be able to generate cool patterns and alternations of patterns within just a few seconds (and less) without having to dive deep into menues .... Anybody here who thinks like me? Any suggestions ....
I'll take 2 – but you know rhat already ...
Ich bräuchte einen speziellen Sequenzer – sowas gibts bisher nicht
cd_reloaded replied to cd_reloaded's topic in Deutsch
DankeDankeDanke - ich beeile mich, wird aber noch ein bisschen dauern. Dann mache ich mir mal übner die Hardware Gedanken. Könnte sein, dass Fragen auftauchen. Darf ich Dich per mail konsultieren? 1000 Dank schon mal jetzt. Grüße Christian -
So sieht der Mockup aus – eigentlich selbserklärend, oder? Midi-Channel-Anwahl durch Drücken im Stand, so lange bis im Lauflicht die entsprechende Nummer aufleuchtet. 2 Midi-Ins mergen Clock und Events, die eventuell von unterschiedlichen Quellen kommen. Die Delete-LED blinkt als bestätigung nur kurz auf. Rec./Overdub lässt sich im laufenden Betrieb ein und ausschalten – LED zeigt Status an. So siehts aus – irgend ein Denkfehler direkt sichtbar? Grüße Christian PS: das Ding muss sich nach dem Ausschalten der Power nix merken müssen – kann mit gutem Gewissen dümmer sein als ich .... (ich denke immer noch an das Kellerfenster) -
ojeh – das Kellerfenster ruft .... -
Das ist genau das Thema! Wer ist denn hier ein Programmierexperte und kann mir sagen wie sehr das Ganze – im Rahmen der vorhandenen Ucapps Anwendungen – denn von Grund auf wäre. Und in wie weit es Anpassungen vorhandener Scripte wären? Ich kann es nicht beurteilen und bin von daher auf Eure Aussagen angewiesen. Im allerschlimmsten Fall: Kann man das sogar lernen? Oder werde ich mich aus Verzweiflung aus dem Kellerfenster stürzen? Ich bin Grafiker und kein E-Techniker .... -
Das ist ja genau das, was ich nicht möchte – Kompromisse eingehen. Ich habe den Midibox SEQ_V3 und bin eigentlich damit sehr zufrieden – hätte es aber eben gerne für eine ganz bestimmte Anwendungen wesentlich einfacher und intuitiver ohne in ein Display schauen zu müssen um zu wissen, was ich gerade mache. Meine Prioritäten habe ziemlich genau beschrieben – geht eigentlich gar nicht genauer (und lieber Transpose als LCD!) -
Hallo und schönen Tag – für alle, die mich unter dem namen cd_cd kennen, erstmal ein freundliches Hallo – der Account hat mich nicht mehr reingelassen – warum auch immer. Deshalb bin ich mit neuer Identität ab jetzt hier. Vorweg: Ich habe keine Ahnung vom Programmieren. Ich kann Schaltungen zusammenlöten nach relativ genauen Angaben und dann geht das schon. Aber ich beschreibe vielleich erst einmal, was ich bräuchte und wie ich da dran komme wird man sehen – ich bin auf Eure Hilfe angewiesen ... Also – nachdem ich ausschließlich live spiele und absolut stocksimple Kisten liebe, hätte ich gerne einen Sequenzer, der folgendes kann: • Midi In/Out – eventuell Thru um Clock weiterzuschleifen – ist aber nicht unbedingt nötig. • Bedienung funktioniert komplett ohne Display für jede Funktion gibt es einen Taster, der nur für die Funktion da ist. Keine Potis oder Encoder. • Alle Operationen laufen in Echtzeit ohne, dass Start/Stop gedrückt werden muss (aber kann) – sowohl als Master als auch als Slave. • 1 Einstellbarer Midi-Kanal für die Ansteuerung von 1 Instrument (z.B. über mikroschalter wie beim Döpfer – oder wie auch immer das dann gelöst würde) • Es reichen 2 aufnehmbare, loopende Sequenzen, die man hin- und herschalten kann. (Knopf: Seq1 – Seq2) die Sequenzen müssen nicht gespeichert werden sondern können flüchtig sein. • Einen Sequenz-Delete-Knopf, den Inhalt der Sequenz sofort löscht • Eine Record-Knopf, mit dem man sofort wieder etwas einspielen kann (automatisch im Overdub) • Automatische Quantisierung auf 16-tel (Swing nicht nötig) • Sequenz-Länge einstellbar in 16-tel-Beats bis maximal 4 Takten. Wie man das nur mit Tastern vernünftig geregelt bekommt, weiss ich noch nicht. • Sequenzer startet im Slave-Betrieb immer in die laufende Midi-Clock auf die 1 • Nimmt alles auf (Polyphon, Prog-Changes, Controller etc....) • Schalter zum hin und herschalten zwischen Echtzeit-Aufnahme und Step-Aufnahme • Step-Aufnahme-Taster nimmt den Sequenzer automatisch aus der Clock heraus, die aber als Metrum im Hintergrund weiterläuft – Start wieder durch erneute Betätigung des Step-Aufnahmetasters auf die nächste Eins. Die Sequenz-Länge stellt sich automatisch auf Anzehl der eingespielten Steps ein. • Eingang eines Events schaltet auf den nächsten Step (16-tel) – Gate-Länge wie gespielt – einen Taster für Leersteps • Taster zum Tempo-Eintappen (statt Poti – absolutes Tempo in BPM ist mir egal, da die Kiste fast nur als Slave laufen würde) – 2-farb LED zeigt Beats und 1 an • Knopf, der eine Transpose-Funktion aktiviert bei eingehenden Midi-Note-Events – sofortige Rücksetzung des Transposes bei deaktivieren des Knopfes. • Alle wichtigen Zustands Indikatoren bekommen eine LED. So, das wars auch schon. Ist das verständlich? oder habe ich 'nen Denkfehler drin? Kann man sowas machen? Gibt es jemanden, der so etwas easy programmieren kann, eventuell aus bestehenden Bausteinen? Was wäre an Hardware nötig? (Core, DIN, DOUT) Oder ist das zu dreist so wieder hier aufzutauchen? .... Trotzdem schon mal jetzt 1000 Dank Grüße Christian
