Hi there,
Firstable, please excuse my poor english, I'm french and actually doing my best to be understood ;)
I run my own project (not midibox-based, its a DMX lighting desk) which uses a motorfader module. I began working on this ages ago, and the only useful documentation about how to control motorfaders was here, on ucapps.de
Ucapps.de really "pulled the trigger" and convinced me that starting my own project would be possible ; I think it's fair to give my work on motorfaders control to midibox community.
I've made several improvements, which I think could be useful for any midibox using motorfaders:
- (hardw) LM317 + its trimmer for each channel, allowing sort of "fine tuning" for each motor
- (hardw) Added capacitors on ADC inputs to improve stability
I actually didnt read mios sourcecode, maybe the following points are already ok
- (softw) Dynamic "slow pwm" band (barely based on distance) to avoid oscillations around target values
- (softw) Auto-test / Auto-detect driver type (TC4426 / TC4427 / TC4428 can be used, just put whatever you have and launch autotest)
- (softw) Dynamic "hold range" (after a fader is moved by software, no "value change message" will be sent if change < abs(target value - actual target value) + 2, preventing unwanted value changes if the faders stops near an "unstable" area)
I have to adapt my schematics and draw a new PCB to be 100% midibox-compatible, and also translate my notes to english. I use a parallel 6-bit-wide bus while midibox uses serial data, etc. That's why I ask if you are interested about this stuff, actually making all this midibox-compatible is a lot of work, I'll be glad to do it if you are interested.
Regards,
Tristan
