I guess this must have been asked numerous times, so sorry for me asking this again...
What I would like to do is this:
When I move or turn a fader or pot, I want to display a short message on the LED that says which pot was turned. So I have created a table that contains 64 message texts to displaying a short info on LED about which AIN pot was moved.
For doing that I started adjusting the ain64_din128_dout128_v2_0 main.c file.
The messages are stored in a variable like this:
code char * pot_text[]={
    "U. Draw. 16\0"   , // 1 - Drawbar 1
    "U. Draw. 5 1/3\0", // 2 - Drawbar 2
    "U. Draw. 8\0"    , // 3 - Drawbar 3
    "U. Draw. 4\0"    , // 4 - Drawbar 4
    "U. Draw. 2 2/3\0", // 5 - Drawbar 5
Call to display text:
MIOS_LCD_CursorSet(0x00);
MIOS_LCD_PrintCString(pot_text[last_ain_pin]);
When I try to implement the variable pot_text as a global variable inside main.c, it does not work. The displayed text is garbled and consists of garbage. But when I declare the pot_text variable as a local variable in DISPLAY_tick it works if I have a rather short pot_text table (not 64 entries but maybe about entries).
Is there a limit in size for variables for MIOS_LCD_PrintCString?
What is the recommended way for creating a message text table and displaying one of these messages on the LCD?
Thx for any help,
Crypto.
looks like the old max 256 bytes to an array in sram issue.
Try using the 'const' keyword to store the array into flash memory rather than sram.
You'll know if you hit that, cause the linker generates an error
Definitely. If the values don't need to change.....
Here's what works for me:
// the "\0" character gets added automatically, so defining
// a length of 8 gives you 7 characters to work with
const char strings[3][8] = {"SomeStr", "MoreStf", "1234567"};
void DISPLAY_Init(void) __wparam
  MIOS_LCD_Clear();
  MIOS_LCD_PrintCString(strings[0]);
  MIOS_LCD_CursorSet(0x28);
  MIOS_LCD_PrintCString(strings[2]);
}[/code]
I fixed the length of the two dimensions of the array for two reasons:
1) it doesn't work like that if you don't
2) the compiler generates warnings if you mess up the indexes/indices
Hi again,
thanks a lot for Your help. It is working now  :D
I added the "constant" type and also increased the size of the array by one to implement the /0 null termination of the chars.
In the call to MIOS_LCD_PrintCString I added a (code const char*) type conversion to avoid any compiler warnings concerning wrong types.
Regards,
Crypto.
