LCD and SID problems
Hi guys!
I've changed MIDI interface to working one, and I'm possible continue creating my MB-SID.
Let's begin from LCD:
When I power everything on, black bar appears on LCD and after some time it goes blank or...
It displays something what's on the photos.
Datasheet: http://sklep.avt.pl/photo/_pdf/BTHQ_22005VSS.pdf
And SID:
I've napierzaza Double SID module with 2x8580's.
Testtone runs well, sounds clear, has 1kHz. But if I change app to sid synt, and play something on keyboard it sounds strange. In sounds.mp3 I've attached recording which contains 6 ocataves played from low to high.
Have anybody has any idea?
sounds.mp3
sounds.mp3
Both is strange.
LCD: you considered the 4bit interface (D0-D3 should not be connected)?
LCD interconnection test done?
Strange Sound: it's interesting that the waveform and volume (or ADSR setting?) changes while you are playing different notes. It could either be a powering problem, connection problem or firmware upload problem - hard to diagnose via remote, but let's start with the power problem: does it also sound so strange when the LCD (and especially the backlight) is *not* connected?
Best Regards, Thorsten,.
Ok, LCD problem solved. E pin was partly disconnected in some way.
On LCD interconnection test, after going out from E line test, LCD goes blank.
After fixing second SID audio channel, I was going to check how this one sounds.
Checked testtone - clear.
If done SID interconnection test, i've lower volatages on A3 and A4 (3,5V, but I've uncalibrated multimeter...) , +5 at rest.
Unfortunately when I'm trying to start MIDIboxSID app, it restarts on "Launching CS".
Thanks for help ;)
EDIT:
Same without SIDs board.
