drumwide Posted June 10, 2003 Posted June 10, 2003 any plans for a virtual midibox lc, or help for trying to program one?
serge Posted June 10, 2003 Posted June 10, 2003 what do you mean by v.midibox.lc ?midibox ng ?regsSer
drumwide Posted June 11, 2003 Author Posted June 11, 2003 I mean the logic control clone.v.midibox.lc = virtual midibox logic controlI want to have a virtual midibox designed to look like a logic control/mackie control.I don't know if I can edit the v.midibox.64 for this.
pilo Posted June 11, 2003 Posted June 11, 2003 I don't konw much about the virtual midibox, but I don't think it's hard to make!why not a Midibox emulator? with a PIC emulator and some mods to get it use the MIDI...
serge Posted June 12, 2003 Posted June 12, 2003 Drumwide,ah the LC is an application for the MIOS platform.I have no plans to make a virtual midibox editor for this platform at the moment. (There is currently no sysex spec for MIOS ?? )Pilo,yes that would be cool to see a true midibox emulator,using a pic emulation engine. Let us know if you have a working prototype !! ;)regsser
pilo Posted June 12, 2003 Posted June 12, 2003 what I mean by emulator, is that you run the pic code on the computer, use the same interface as the currently existing virtual midibox, just run the program on PC.yes I konw that now we can upload the program via Midi, but maybe it can help in testing some design (for example, if you want to make weird design, I have no idea but...), so you don't have to build everything...A pic emulator is maybe easy to find in open source... I found a compiler for linux... and the guys are also making an emulator (try a search with gpasm)
