Guest Posted May 11, 2008 Report Share Posted May 11, 2008 hi everyone,i just got a set of second hand motorfaders. now, if i look on the lower side of these faders, i can see two little black numbers printed there. on some faders 914k and 10kb and on the others 303k and 10kb. can anyone tell, what those numbers mean?thanksgreetingsjohn Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted May 11, 2008 Report Share Posted May 11, 2008 Don't you have any brand information (or even type)?Possibility:It seems, that those faders have a 10k (propably linear) taper, which would make them usable for a MB-LC/64.The other numbers could be the rating of a log-taper for audio use. - 303k could very well be used for audio applications... I don't know about the 914k.Hope it helpedGreets, Roger Quote Link to comment Share on other sites More sharing options...
/tilted/ Posted May 12, 2008 Report Share Posted May 12, 2008 Do the 914ks look like this:http://www.tkd-corp.com/02_products/pdf/p02_mf-914.pdf303ks: no idea. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2008 Report Share Posted May 12, 2008 hi, thanks.i forgot to mention, that these are alps faders. i think they are both RSAON11M9 and i found some datasheets for different RSAON11M9 types, but the connecters do not match any of these sheets.the 10k i figured out by now, thanks again. but the other number ??? there isn´t any fitting describtions to that.could it be possible that the motors of the different types i got have to be driven with different voltage, so the numbers refer to a resistor before the motors. (just a theory though)again, thanks a lot.greetingsjohn Quote Link to comment Share on other sites More sharing options...
/tilted/ Posted May 16, 2008 Report Share Posted May 16, 2008 the numbers may be as mundane as a batch number, or manufacture date... Quote Link to comment Share on other sites More sharing options...
stryd_one Posted May 16, 2008 Report Share Posted May 16, 2008 batch was my guess too... Quote Link to comment Share on other sites More sharing options...
