IMO this PCB is unuseful.
You can achieve this by using a 17 wires ribbon cable and 3 HE10 connector.
You do the same as IDE ribbon for Harddrive : the only difficulty is to rearrange the wires on the Core connector ( I did it for my SEQ)
You forgot the 2nd enable line....of course, one could do as you said and cut the enable line to the 2nd connector and run one extra wire.
