leaphion Posted May 24, 2008 Posted May 24, 2008 Hi! Just wanted to know is there any kind of connectivity possibilities with OSC on midibox-projects?I might have an idea for a controller if the connection is possible.
stryd_one Posted May 24, 2008 Posted May 24, 2008 Possible? Yes. Already done? No.You should try the search engine!
tos Posted May 24, 2008 Posted May 24, 2008 There is a nice thread around here dicussing the problems and possible solutions of OSC.We managed to involve TK in the discussion.So far the best solution is to use a separate board/"piece of hardware" that will convert MIDI messages to OSC.This way it would also be quite universal...maybe built with a midi merger would be a MIDI to OSC patchbay of some kind(....and one to Ethernet'em all....).
leaphion Posted May 30, 2008 Author Posted May 30, 2008 Possible? Yes. Already done? No.You should try the search engine!I tried, oh high and mighty Stryd_one!!!Didn't just find the correct search words. :( Sorry, my bad.
stryd_one Posted May 30, 2008 Posted May 30, 2008 OK someone asked about how to use the tags and I thought this was a prime example of a frequently asked question which was hard to find, and often had interesting information in the threads, and most of all it was hard to find in a search... so it would benefit from taggingI searched forOSC and got hits for all kinds of things (*try it) so i narrowed the search to osc -oscil(Now I don't get hits for the word oscillator)and ticked 'show results as posts' so I see some text.11 pages of hits, scrolled through and ctrl+clicked the relevant ones to open in new tabs, then went through the tabs one at a time, tagged them all with 'opensoundcontrol'. Why not 'osc'? because there are obviously* other uses for that term ;)Enjoy the tag! (You'll be reading for a day or two I guess heh)
