Hi! Just wanted to know is there any kind of connectivity possibilities with OSC on midibox-projects?
I might have an idea for a controller if the connection is possible.
There is a nice thread around here dicussing the problems and possible solutions of OSC.
We managed to involve TK in the discussion.
So far the best solution is to use a separate board/"piece of hardware" that will convert MIDI messages to OSC.
This way it would also be quite universal...maybe built with a midi merger would be a MIDI to OSC patchbay of some kind(....and one to Ethernet'em all....).
Possible? Yes. Already done? No.
You should try the search engine!
I tried, oh high and mighty Stryd_one!!!
Didn't just find the correct search words. :( Sorry, my bad.
OK someone asked about how to use the tags and I thought this was a prime example of a frequently asked question which was hard to find, and often had interesting information in the threads, and most of all it was hard to find in a search... so it would benefit from tagging
I searched for
OSC
and got hits for all kinds of things (*try it) so i narrowed the search to
osc -oscil
(Now I don't get hits for the word oscillator)
and ticked 'show results as posts' so I see some text.
11 pages of hits, scrolled through and ctrl+clicked the relevant ones to open in new tabs, then went through the tabs one at a time, tagged them all with 'opensoundcontrol'. Why not 'osc'? because there are obviously* other uses for that term ;)
Enjoy the tag! (You'll be reading for a day or two I guess heh)
