speedyguitar Posted June 9, 2008 Report Posted June 9, 2008 first of all: hi everybody and thanks for site , project and everything. I build the "old" floorboard ( http://www.ucapps.de/floorboard.html )and it worked right-out-the-box , first power-on :) I will package it VERY small , so small to stick-it outside a guitar ( or , if i find a no-vintage strat ,i will build INSIDE, I'll post pictures, of course ! ;) ) I would like to make a litlle mod: the program-change button marked "0" it would be better to become the "10" button for some midi hardware so for every banks to have from 1 to 10 and NOT from 0 to 9; is it possible ? I got a look inside the source code and I think I have to modify the "button.inc" file, but I'm not an expert in PIC code :-[ ..( ..not yet , i hope to be in future.. ). Anyway , thanks again everybody for the knowledge and the good quality projects I found here around.
stryd_one Posted June 9, 2008 Report Posted June 9, 2008 Hmm... I guess that would leave channel 0 inaccessible, right?
nILS Posted June 9, 2008 Report Posted June 9, 2008 Welcome aboard SpeedyGuitar! ;Dis it possible ? I got a look inside the source code and I think I have to modify the "button.inc" fileYes, definitely possible and yes, "buttons.inc" is the file to modify. I'd suggest you fiddle with it a bit yourself (for the learning and all) and if you run into problems - just ask :-)
speedyguitar Posted June 9, 2008 Author Report Posted June 9, 2008 thanks all for the quick reply.. :)Hi nILS Podewski , ok I'll try ..hoping to do not make too much errors ( i don't like burnin' PICs .. :) ) I was looking the "button.inc" source and I found the routine to modify, "BUTTON_B5_Pressed" ..but maybe also "BUTTON_B5_Pressed_ok" and "BUTTON_B5_Pressed_ok1 and ..ok2. I would change :BUTTON_B5_Pressed_Ok2 movlw 0x00 ... maybe change "0x00" to "0x0a" ( hex of "10" ) but I suspect that I have to understand exacly how the code works when banks goes up and down AND how exacly manage the display ... The final package could be without display ( I will make it VERY small.. :-) ) and so I could forget 'bout the display for now, but i think it's better to care about the banks ..
