birdsofmyneighborhood Posted June 10, 2008 Posted June 10, 2008 Hi guys,I'm about to order all of my led switches (100 of them), and so far, I though of going with these: http://www.nkkswitches.com/pdf/JBilluminated.pdfHowever, I have been eyeing these from rapid: http://www.rapidonline.com/productinfo.aspx?tier1URL=Electronic-Components&tier2URL=Switches&tier3URL=Tactile-Switches&tier4URL=LED-Illuminated-PCB-switches&moduleno=72855Has anyone ordered these? Are the caps soft? If so, that's what I want to go with. I would just order a sample of course, but the shipping is like $70 even just for one switch lolAlso, is it being DPDT a problem? I thought we should be using SPST.
stryd_one Posted June 10, 2008 Posted June 10, 2008 Have you priced the NKK's yet? I think you might be surprised at the difference ;) (although they are tacts so it shouldn't be too bad)I doubt the caps will be soft on either of these. In fact, that would be such a special feature that I'd say you'll be made well aware of it if they are.
DavidBanner Posted June 10, 2008 Posted June 10, 2008 I've used them.The caps are hard plastic.Also there are a few types of switches supplied by rapid, make sure you get the momentary ones.
birdsofmyneighborhood Posted June 10, 2008 Author Posted June 10, 2008 I've used them.The caps are hard plastic.Also there are a few types of switches supplied by rapid, make sure you get the momentary ones.aha ok, I'm just gonna stick with the NKK's then, since I have already tested them.The NKK ones are $2.30, while these are $1.78. But with shipping, the order total comes out to be the same.Thanks!
