vix Posted June 21, 2008 Posted June 21, 2008 hi guysi don't understand why when i boot my MBFM, i got this screen :i saw in the FM Manual, that i should have this one :i got a bankstick (fully tested and formatted) but i can't upload patchbanks from JSynthLib : each time i try, the core reboots several times during the upload (store) then starts normally but shows the same screen, no patch.i tried to upload the file bankstick.syx (in the FM setup folder) but same result.what is wrong here ??? why the Midi Channel is set to 0 ?
TK. Posted June 21, 2008 Posted June 21, 2008 It seems, that the EEPROM content (which stores the default ensemble, drum and patch) is corrupted. This can lead to such effects. Other problems could be related to an incomplete application upload as well.Therefore I propose to upload the application via MIOS Studio again. Error messages during the upload will indicate, that something is going wrong (again)...Best Regards, Thorsten.
vix Posted June 23, 2008 Author Posted June 23, 2008 i did the upload with MIOS Studio (i thought there were no mac version...) in smart mode, and it worked. i uploaded the patchbank and it worked !but now, as explained in this topic http://www.midibox.org/forum/index.php/topic,11668.0/topicseen.html, i can't generate any sound with only one YAC (cause it's in the "optional" place) so i'm waiting for my second one ::)Thanks for your help Thorsten , and for all the work you did (and will do) with ucapps !
